SEROUT2 and TRISIO - trash leading characters
Results 1 to 5 of 5
    SWITZERLAND (french speaking)
    Default SEROUT2 and TRISIO - trash leading characters
    Hello,
    This is a small code to transmit data from a PIC to another via serial RF link using LINX RF modules.
    The transmitter is powered-up only when data needs to be sent (like a simple remote control).
    After power up, there is always trash data like "UÔ*u˜" sent by the PIC before a correct message is transmitted. As long as the PIC is powered, all messages will be correct.
    I found out, to avoid this trash data, I need to comment the TRISIO statement like in the code hereunder (?!).
    But doing so, the command Led = CMCON.6 will stop working and I need a workaround like the IF..THEN commands for the Led.
    Any idea what I'm doing wrong?
    ' Fuses  PIC12F675
    @ __CONFIG _CPD_OFF &_BODEN_OFF &_MCLRE_OFF &_PWRTE_OFF &_WDT_OFF &_XT_OSC
    ' Registers   76543210
    OPTION_REG = %10000000 'GPIO Pull-Ups disabled
    INTCON     = %00000000 'Set Interrupts
    ANSEL      = %00000010 'Select analog inputs
    WPU        = %00000000 'Weak pull-ups (check OPTION_REG)
    GPIO       = %00000000 'Set PORTS
        '//TRISIO     = %00000010 'Set I/Os
    CMCON      = %01000100 'Comparator Module settings
    VRCON      = %10001011 'Voltage reference
    ' Defines
    ' Variables
    D_Out   VAR GPIO.0  'Serial Data Out
    BattLvl VAR GPIO.1  'Analog Input
    Led     VAR GPIO.2  'Led is ON if battery level is low
    ' Program
    PAUSE 500   'Delay for VREF to settle
    MAIN:
        IF CMCON.6 = 1 THEN
            HIGH Led
            LOW Led
        '//Led = CMCON.6
        SEROUT2 D_Out, 813,["TEST", DEC1 CMCON.6] '1200bps
        PAUSE 1000
        GOTO MAIN
    Roger
    You just need to initialize the pin to "Idle Level" at the start of the program.
    Add a ... HIGH D_Out ... statement before the ... PAUSE 500.
    You don't really need that much pause time for the initialization, but it's already in the program so you might as well use it.
    Default Re: SEROUT2 and TRISIO - trash leading characters
    Thanks Darrel,
    I'll try this tonight - I'm at work now :-/
    You're right, the PAUSE is not necessary - I'll take it off.
    Can you please explain why the D_Out pin has to be set HIGH?
    Roger
    The START bit of the first character begins with a transition from High to Low (with TRUE levels).
    If the pin is not in the High state, the start bit will be missed and the first data sent will be out of sync.
    It will be able to sync up after any pause in the data stream greater than 1-byte in length.
    To initialize the pin, you should set it to output, in the "Idle State" for at least 1 byte length (8.3 mS for 1200 baud).
    So just set the pin high, pause 10 mS and you should be fine.
    Hi Darrel,
    It works ;-)
    Thanks a lot.
    Roger
  1. Serout2 on LCD Shows Junk Characters
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 14th January 2013, 16:51
  2. Gpio ? Trisio ?
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 15th October 2008, 15:38
  3. Pic12f683, Trisio, High Z, A2d
    By jmbanales21485 in forum Schematics
    Last Post: - 5th July 2007, 20:34
  4. Leading 0's or BCD
    By RYTECH in forum mel PIC BASIC Pro
    Last Post: - 28th December 2005, 02:06
  5. Leading/Trailing Edge
    By DelBoy in forum mel PIC BASIC Pro
    Last Post: - 23rd March 2005, 13:29
