Hello from a complete newbie to PICs
Results 1 to 8 of 8
    Default Re: Hello from a complete newbie to PICs
    Now for the first really stupid question.
    I "think" I've got the USB issue sorted out as Windows 7 can now see my EasyPIC v7 board.
    I'd like to use PBP Basic as it seems far more intuitive to me than MikroBasic.
    PBP Basic calls upon MPLAB IDE v8.85 which doesn't appear to support the EasyPIC v7 board.
    I've also got MPLAB X IDE v1.70 which does support the EasyPIC v7.
    Am I correct in assuming that PBP Basic will output some form of HEX file that any IDE program can then download into a PIC ?
    As I said, I'm new to this - just playing at the moment
    Andy
    The EasyPIC7 is basically 3 things in one.
    1) A general purpose development board. This is just hardware, chips, LEDS, buttons, jumpers, displays, sockets etc - doesn't know or care what compiler you're using.
    2) A PIC Device programmer. This is used with the MikroE programmer application to program the .hex file into the actual PIC on the board. The programmer application doesn't care what compiler you used to create the .hex file.
    3) A debugger. This works as an integrated part of the MikroE IDE so you can not use it with PBP. You mention MPLAB X but IF the debugger IS supported from within MPLAB X (which I doubt) you'd still have to use the MikroE compiler as a tool inside MPLAB X.
    Now, PBP3 compiles your BASIC program and then uses the assembler from MPLAB v8.85 to assemble the program into a .hex file which you then programmed into the PIC in whatever suitable way. Neither PBP3 or MPLAB knows or cares about the EasyPIC7 board or its device programmer - all they do is generate the .hex file. You simply load the .hex file into the MikroE programmer application and program the PIC.
  1. Complete Keypad Example
    Last Post: - 27th July 2011, 19:09
  2. I2C between pics..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 10th June 2008, 04:16
  3. Serial Port Complete 2nd Edition
    By Bruce in forum Serial
    Last Post: - 8th November 2007, 15:28
  4. USB Complete by Jan Axelson
    By TonyA in forum USB
    Last Post: - 6th May 2006, 00:30
  5. Replies: 1
    Last Post: - 2nd May 2006, 00:28
