How to display the real frequency for an AD9850
Results 1 to 7 of 7
    Jun 2008
    Varese , Italy
    Default Re: How to display the real frequency for an AD9850
    I am just a little bit puzzled: if the alorithm is the following: ( this is an example )
    Tuning word for 500kHz = 500000*2^32/125000000 = 17179869 or, in HEX, $010624DD
    How could I display 500,000 Hz on the LCD ?
    Thanks for helping.
    regards,
    Ambrogio
    Well, the basic answer is to take the tuning value and divide it by 2^32/125M or, in this case 17179869/(2^32/125000000) or, in short, 17179869/34.359738 = 500000.
    Now, how to do this in PBP depends on if you're able to use LONG variables or not and to what accuracy you need the result. I don't know if you've seen my Wiki-article regarding the AD9850 or not but it describes two possible ways to calculate the tuning value when you know the frequency, it should be pretty straight forward to adapt any of the two methods to do the reverse.
    Apr 2011
    If you are using keyboard input for frequency selection just port the keypresses directly to the display at the same time you use it in the calculation for register coding.
    Jun 2008
    Varese , Italy
    Kellyseye,
    if I enter the output frequency then I have to compute the Tuning word.
    If I enter the tuning word I have to compute the frequency to be displayed .
    Tell me if I am wrong .
    Ambrogio
    Jun 2008
    Varese , Italy
    Thanks Henrik for having understood my problem.
    I have seen all your implementations: they are great.
    Congratulation.
    I can use the LONG variables in PBP.
    Ambrogio
    IW2FVO
  1. Real Ice and PBP
    By MikeBZH in forum General
    Last Post: - 25th November 2019, 22:21
  2. Display real clock and date by using pic16877a on lcd
    By eepro in forum mel PIC BASIC Pro
    Last Post: - 11th August 2008, 07:06
  3. Me again, but need REAL help now
    By gringobomba14 in forum General
    Last Post: - 19th June 2008, 20:51
  4. Real time the right way?
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 1st March 2007, 18:38
  5. Real Time Clock
    Last Post: - 8th December 2006, 02:02
