4-20mA using SPI Interface
Results 1 to 4 of 4
    Sep 2005
    Post 4-20mA using SPI Interface
    Hi All,
    I came across a 4-20mA board from MicroElektronika which uses the SPI to control the device, has anyone used such a board before?, I am looking for Code Examples, would anyone be able to assist?
    gavo
    Default Re: 4-20mA using SPI Interface
    Is it too much to ask to at least post a link to the board in question?
    I could try to find it on their site but I won't so the best answer *I* can give you is that you can use SHIFTOUT to do bitbanged SPI or use the MSSP module (if the PIC has one) to do it "in hardware".
    Feb 2005
    brookfield, ct, usa
    Hi
    This is some code I wrote to use that board as a basic loop calibrator. Worked OK for me.
    Take care
    Alec
    '*  Name    : Encoder test                                      *
    '*  Author  : alec noble                                        *
    '*  Notice  : Copyright (c) 2012 alec noble                     *
    '*  Date    : 9/27/2012                                         *
        __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    'DEFINE OSC 20
    '************************** setup LCD ****************************
    	DEFINE	LCD_DREG	PORTB		' Set Data to PortB
    	DEFINE 	LCD_DBIT	0			' Set starting Data to Bit4
    	DEFINE 	LCD_RSREG   PORTB		' Set Register Select to PortB
    	DEFINE 	LCD_RSBIT   4			' Set RS line to PORTB.4
    	DEFINE 	LCD_EREG	PORTB		' Set Enable to PortB
    	DEFINE 	LCD_EBIT  	5			' Set Enable line to PortB.5
    	DEFINE 	LCD_BITS	4			' Set for 4 bit Bus
    	DEFINE 	LCD_LINES	2			' Set number of lines to
    CMCON = 7           'comparaters off - digital I/O on port A
    trisb = 0           'all bits outputs
    trisa = %00000111   'porta.0, 1, 2 input, all others output
    cntr    var word
    cntr_1  var word
    cntr_2  var word
    preset  var byte
    sck var porta.6
    sdi var porta.7
    cs  var porta.4
    cntr = 200
    preset = 0
    cs = 1
    lcdout $FE, $01
    pause 5
    lcdout  "ahn_loop_cal"
    pause 5000
    lcdout $FE, $01
    pause 5
    lcdout dec cntr
    '************************  Program **********************************
        if porta.2 = 1 then set
        if porta.0 = 1 then CW
        if porta.1 = 1 then CCW
        set:
        pause 5
        if porta.2 = 0 then main
        preset = preset + 1
        while porta.2 = 1 : wend
        if preset  > 4 then preset = 0
        lookup2 preset, [200, 400, 600, 800, 1000], cntr
        goto display
        CW:
        pause 5
        if porta.0 = 0 then main
        if cntr = 1023 then main
        cntr = cntr + 1
        goto display
        CCW:
        pause 5
        if porta.1 = 0 then main
        if cntr < 190 then main
        cntr = cntr - 1
        goto display
        display:
        cntr_1 = cntr * 4
        lcdout $FE, $01, dec cntr_1, " mV"
        pause 5
        cntr_2 = cntr_1/2
        lcdout $FE, $C0, dec2 cntr_2/100, ".", dec2 cntr_2//100, " mA"
        goto DAC_out
    DAC_out:
        cntr_1.15 = 0
        cntr_1.14 = 0
        cntr_1.13 = 1       'GAIN OF 1
        cntr_1.12 = 1       'turn on DAC output
        low CS
    '    pause 5
        shiftout sdi, sck, 1, [cntr_1\16]
        high cs
        while porta.0 or porta.1 = 1
        wend
    Sep 2005
    Hi Alec,
    Many Thanks!, will try it!,
    Hendrik the link is http://www.mikroe.com/click/rs485-5v/
    Gavin
  1. Creating 4 to 20MA ?
    By amgen in forum Off Topic
    Last Post: - 3rd May 2014, 22:45
  2. question about the pin to pin connections on a SPI interface
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 13:03
  3. Need to use SPI but I'm already using the SPI port
    Last Post: - 30th December 2012, 09:52
  4. 4-20mA output using PWM
    By gavo in forum mel PIC BASIC Pro
    Last Post: - 8th December 2007, 09:45
  5. 4-20mA to 0-5V configuration
    By leonel in forum General
    Last Post: - 31st August 2005, 12:33
