Power Control (PCON) Register
Results 1 to 6 of 6
Threaded View
  1. #3
    Default Re: Power Control (PCON) Register
    The following code modification fixes the problem. The idea is a double set of the MCLR reset flag. Electrical noise tends to disrupt the initial condition of the MCLR bit so a double set is needed:
            if PCON.1 = 0 then      'when por reset has occurred
            PCON.3 = 1              'set mclr flag
            PCON.1 = 1              'set por flag
            if PCON.3 = 0 then      'when mclr reset has occurred
            goto current            'jump over data display
    This is working nearly 100% of the time, unless the noise environment is very,very severe.
    The fix is posted here for future reference.
  1. Power multiple electronics from 1 power source
    By koossa in forum Off Topic
    Last Post: - 2nd September 2010, 08:49
  2. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 15:40
  3. CCP vs power control PWM
    By luminas in forum mel PIC BASIC Pro
    Last Post: - 4th September 2008, 03:09
  4. Replies: 4
    Last Post: - 16th May 2008, 14:35
  5. How do I to set one bit in a register?
    Last Post: - 11th February 2006, 08:43
