Wireless modules and simple setup, what is required?
Results 1 to 18 of 18
Threaded View
  1. #12
    SWITZERLAND (french speaking)
    Default Re: Wireless modules and simple setup, what is required?
    Hi Tasmod,
    I'm finishing a similar project to yours with LINX RF modules.
    I choose the 433MHz version to ensure better distance; I tested with a "Splatch" (from LINX too) antenna and reached easely 70 meters. I paid $13.- for the receiver (RXM-433-LR) and $8.- for the transmitter (TXM-433-LR) module.
    These RF modules are super-simple to use and it took me less than an hour from unpacking them to have sent the first data
    I made this short (simplified testing) code fot the Transmitter:
    ' Fuses  PIC12F675 - 4MHz XTal
    @ __CONFIG _CPD_OFF &_BODEN_OFF &_MCLRE_OFF &_PWRTE_OFF &_WDT_OFF &_XT_OSC
    ' Registers   76543210
    OPTION_REG = %10000000 'GPIO Pull-Ups disabled
    INTCON     = %00000000 'Set Interrupts
    ANSEL      = %00000000 'Select analog inputs
    WPU        = %00000000 'Weak pull-ups (check OPTION_REG)
    GPIO       = %00000001 'Set PORTS
    TRISIO     = %00000010 'Set I/Os
    CMCON      = %00000111 'Comparator Module settings
    ' Program
    MAIN:
        SEROUT2 GPIO.0, 813,["TEST",1] '1200bps
        PAUSE 00
        GOTO MAIN
    ...and the Receiver's code:
    GPIO       = %00000100 'Set PORTS
    TRISIO     = %00000000 'Set I/Os
    ' Variables
    Led   VAR BYTE
    Led   = 0
    ' Program
    MAIN:
        SERIN2 GPIO.2, 813,[WAIT("TEST"), DEC1 Led] '1200bps
        GPIO.1 = Led
        PAUSE 500
        GOTO MAIN
    Roger
  1. Low latency Wireless RF transceiver modules?
    By mark155 in forum General
    Last Post: - 4th March 2010, 05:20
  2. Wireless modules FCC approved
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th September 2008, 02:23
  3. Software RS232 and wireless modules
    Last Post: - 17th August 2008, 05:27
  4. CM02 and RF04 wireless modules problem
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 14th December 2006, 10:32
  5. Wireless comms with Linx LR modules
    By telemark in forum mel PIC BASIC Pro
    Last Post: - 2nd July 2006, 01:58
