Can someone cast an eye over this code please.
8mhz pic. Trying to generate 200hz HPWM.
Duty seems stuck at about 60% whatever I try even when it's supposed to be off and idling high with
Duty set at 255. Scope shows pwm is working at 200hz but I can't vary the duty.
Does the Duty variable have to be a WORD?
Confused.
Code:#config __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _FCMEN_OFF __config _CONFIG2, _PLLEN_OFF & _LVP_OFF #ENDCONFIG DEFINE OSC 8 'Set PicBasic Pro processor speed to 8 Mhz (Must match oscillator value) OSCCON = %01110010 'Set osc 8mhz and stable TRISA = %00101001 'PortA Output on Pin A1,A2,A4 & Input on A0,A3,A5 ANSELA = %00000000 'All Digital I/O APFCON = %10000100 'Set Tx/Rx function to RA4 & RA5 ADCON0 = %00000000 'ADC Disabled OPTION_REG = %01111111 'Global Enable Weak Pull Ups WPUA = %00011011 'Weak Pull Up enabled on Ports A0 A1 A3 A4 DEFINE HSER_BAUD 10400 'Set Baud rate to 10400bps DEFINE HSER_BITS 9 'Set to 9 bit mode DEFINE HSER_EVEN 1 'Set Even Parity DEFINE HSER_CLROERR 1 'Clear overflow error automatically DEFINE CCP1_REG PORTA 'HPWM channel 1 pin Port A Fan PWM Driver DEFINE CCP1_BIT 2 'HPWM channel 1 pin Bit 2 '******************************************************************************* 'Variables Constants and I/O definitions '------------------------ Variables 16bit -------------------------------------- FanSpeed var byte 'Ipu Fan Speed Pwm Setting Start: FanSpeed = 255 HPWM 1, FanSpeed, 200 'Change/Start 200hz HPWM 'Set Duty 0 = Off 255 = FullOn end
