Strange compile error? "Could not spawn language tool. "
Results 1 to 2 of 2
    Default Strange compile error? "Could not spawn language tool. "
    Not sure if anyone can help here. I did try Google and not very much came up so I thought maybe ask here.
    When I compile in MPLAB 8.85 I get the following line in the Build window -
    "Could not spawn language tool. Check command-line options. (2)"
    It does say the build succeeded(and I've confirmed this by making changes, recompiling and downloading) but I just want to be sure things are happening correctly.
    Any ideas?
    Thanks.
    Ian
    Feb 2010
    USA, New England
    Default Re: Strange compile error? "Could not spawn language tool. "
    Hello Ian,
    Have you seen this thread? http://www.picbasic.co.uk/forum/showthread.php?t=14932
    Best Regards,
    Paul
  1. Replies: 5
    Last Post: - 28th February 2011, 16:33
  2. Compile error & syntax error on the word "loop:" as a label?
    Last Post: - 7th March 2010, 05:14
  3. The dreaded "No Device Detected" error
    Last Post: - 11th January 2010, 21:24
  4. "Program Memory Error" with MPLAB IDE (PBP)
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 13th November 2007, 20:27
  5. Replies: 3
    Last Post: - 16th September 2005, 08:40
