LCDOUT with a 12F683
Results 1 to 4 of 4
    Default Re: LCDOUT with a 12F683
    You cannot tie the LCD's RS and E to +5V.
    RS is the "Register Select", and it needs to select between Command and Data registers for the LCD to work.
    E clocks in the data nibbles, without the clock the LCD never receives data. It is not just an "Enable" pin.
    GPIO.3/MCLR/Vpp when not used as MCLR, is an Input Only pin. You cannot use it for the data bus output.
    There just aren't enough pins on a 12F683 to drive an LCD directly.
    You can do it with a shift register, or port expander. But if you are going to have two chips ... you might as well just use a bigger PIC to begin with.
    Mike did a strange little circuit here that uses the serial data to control the RS bit. Which means you have to send two byes serially for every byte sent to the LCD, and you have to bit-bang the LCD routines since LCDOUT will not work.
    But then again ... WHY? When you can just use a bigger PIC.
    Sep 2010
    Las Vegas, NV
    Thanks for the input and sorry for showing so much ignorance. I didn't even have to be connected to +5 to learn something. Usually it takes 220V or higher to get my attention;-)
    Going with a bigger PIC appears to be my only option. I just wondered if it were possible, thought I'd ask and I found a butt load of them in the shop.
    Thanks for your time and willingness to impart your knowledge.
    That link to Mike's project posted by Darrel Taylor has been updated.
    here
    no longer needs 2 bytes and is serout, debug, etc compatible!.. pretty slick actually (My opinion)
    (is there still a "buttload" in a shop? lol)
  1. LCDOut Woes
    By LetTheSmokeOut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 01:45
  2. LCdout
    Last Post: - 3rd December 2006, 16:14
  3. 8bit LCDout vs 4bit LCDout
    By keithdoxey in forum mel PIC BASIC Pro
    Last Post: - 24th May 2006, 12:16
  4. Lcdout
    Last Post: - 11th February 2006, 01:39
  5. LCDOUT help
    By f6ggy in forum mel PIC BASIC Pro
    Last Post: - 6th October 2003, 12:51
