removing pbp3 from xp machine to windows 7 machine
Results 1 to 5 of 5
    May 2009
    Default removing pbp3 from xp machine to windows 7 machine
    How do I remove pbp3 from an xp machine and reinstall an a windows 7 machine?
    I have installed on a new windows 7 machine but it installs as a trial version. how do i get licence transfered to new machine?
    Default Re: removing pbp3 from xp machine to windows 7 machine
    If it is indeed a licensed copy you should have the license key codes.
    EN82fn
    Oct 2009
    Utah, USA
    You can also contact melabs.com and provide them with documentation and/or information on where/when you aquired PBP and they can generate or re-send your license key.
    Dwight
    On the XP machine, run the meLabs PICBASIC Pro Activation manager (meLabsReg.exe in the PBP installation folder) and deactivate the licence for that machine.
    Now you can install and activate the license on the W7 machine.
    May 2009
    Thank you all, if have managed to deactivate and reactivate on new machine.
  1. Speed regulator for sewing machine
    By Kenwood in forum General
    Last Post: - 22nd January 2014, 07:30
  2. Turning a smoke machine on/off with a triac
    Last Post: - 9th January 2011, 15:16
  3. Replies: 6
    Last Post: - 1st February 2008, 04:35
  4. State machine programming
    By tjstevens in forum mel PIC BASIC Pro
    Last Post: - 17th April 2007, 23:45
  5. Help with a Parallel I/O to Machine Interface?
    By john meiers in forum mel PIC BASIC Pro
    Last Post: - 16th September 2005, 19:50
