Windows 8 - downloaded PBP3 but meprog is nowhere to be found
Results 1 to 8 of 8
    Northern California
    Default Windows 8 - downloaded PBP3 but meprog is nowhere to be found
    I have an old version of PBP on my Win XPPro machine and purchased a new Win 8 machine. On the Win 8I downloaded the evaluation copy of PBP3 and was able to compile a test program but can't load it because the programmer driver is not loaded. I did an uninstall of PBP3, mechanique and mplab then re-installed but the problem still exists. How do I load the driver for the USB programmer? Thanks
    Default Re: Windows 8 - downloaded PBP3 but meprog is nowhere to be found
    And the programmer is???
    meprog is nowhere
    Hi, Dave
    you know you should always wear your glasses ... even if NOT programming !
    Best regards
    The programmer software is not part of the PBP installation.
    You can download the beta version from ... http://melabs.com/support/progsoft.htm
    Ooopppss... that bold type in the title was hard to see...
    Not sure how familiar you are with Win 8, but go to the control panel and devices, etc... just like any other version of windows and see if the programmer shows up. It could be the drivers just did not install correctly and need to be removed.... then start over.
    Northern California
    It's the old USB programmer. Thanks for the tops.
    Northern California
    The programmer is now working - thanks for the tip.
    I'm curious as to why the programmer software isn't included with the download and why the melabs support team didn't tell me it wasn't a part of the download. They mentioned nothing about separately loading the programmer and there's no information that I could find on the website that mentioned this - not in support or in the FAQ's.
    The programmers are seperate products that can be used with any compiler.
    They are not specific to Picbasic Pro, and the software is not distributed with PBP.
    You should have received a CD along with your programmer that has the software on it.
    The CD is labeled meLabs Programmer.
    When people lose their CD, I point them to the FREE beta version.
    But you can purchase a new CD or download from ... http://store.melabs.com/cat/upgrades.html
  1. Problems with PBP3, Windows 7 and MELabs programmer
    By chaneyv4 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2011, 15:58
  2. USB key not found
    By shrtrtrt in forum General
    Last Post: - 20th April 2011, 16:12
  3. CONFIGURE & OSCCON & meProg configure
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 22:25
  4. meProg configuration vs setting fuses in code
    By AndrewC in forum General
    Last Post: - 10th June 2008, 15:00
  5. Windows GUI
    By Zenon in forum mel PIC BASIC Pro
    Last Post: - 17th November 2006, 08:15
