Hello
I can't seem to find a reason why I am struggling to light an LED tied to Pin 2 (MCE, PORTA.5) of a PIC16F1825.
I have checked the polarity of the LED and also changed it out for LEDs that are working, the resistor is also functioning correctly. When the pin goes high then the LED should light.
Can anybody see a reason why this LED doesn't light?
I am wondering if it's a case of not being able to see the wood for the trees and it is actually something very simple.
Thank you very much.Code:clear DEFINE OSC 32 'PINS Current_Pos_In VAR PORTA.4 'RA4 AN3 Pot input for current position MCE VAR PORTA.5 'RA5 OUT Enable H Bridge SCK_Pin VAR PORTC.0 'RC0 IN SPI Clock Pin SDI_Pin VAR PORTC.1 'RC1 IN SPI Data Input SDO_Pin VAR PORTC.2 'RC2 OUT SPI Data Output SS_Pin VAR PORTC.3 'RC3 IN SPI Chip Select 'REGISTERS OSCCON = %11110010 INTCON = %11000000 PIE1 = %01001000 APFCON0 = %00000000 APFCON1 = %00000000 TRISA = %00011111 ANSELA = %00010111 WPUA = %00000000 TRISC = %00001011 ANSELC = %00000000 WPUC = %00000000 ADCON0 = %00001100 ADCON1 = %10100000 'SPI Registers SSP1STAT = %00000000 SSP1CON1 = %00100100 SSP1CON2 = %00000000 SSP1CON3 = %00010000 'Interrupt Set up INCLUDE "DT_INTS-14.bas" ' Base Interrupt System INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts ;--------------------------------------------------------------------------- wsave VAR BYTE $20 SYSTEM ' location for W if in bank0 ;wsave VAR BYTE $70 SYSTEM ' alternate save location for W ' if using $70, comment wsave1-3 ' --- IF any of these three lines cause an error ?? ------------------------ ' Comment them out to fix the problem ---- ' -- Which variables are needed, depends on the Chip you are using -- wsave1 VAR BYTE $A0 SYSTEM ' location for W if in bank1 wsave2 VAR BYTE $120 SYSTEM ' location for W if in bank2 'wsave3 VAR BYTE $1A0 SYSTEM ' location for W if in bank3 ' -------------------------------------------------------------------------- ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler SSP1_INT, _SPI_Com, PBP, yes INT_Handler AD_INT, _Current_Pos, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM high mce
