Problems with Basic Servo Code
Results 1 to 8 of 8
Threaded View
  1. #8
    Dec 2012
    Tennessee
    Default Re: Problems with Basic Servo Code
    Ace, glad you caught that, that used to be 500 not 250, dont know why that got changed. I've actually used a fet on the grounds of the lcd backlight to turn the backlight on and off with the pic.
    also thanks mackrakit, is this something I can just turn on and leave on with all projects?
    if I use the internal timer, I can include the grounds for the whole display on the fet and turn the entire display on and off even after the pic is already running with no bad effects, it only had to do the pause when useing an external/crystal timing source. which is nice because you could take and use an interupt with switch to turn on the display and backlight for X amount of time to save battery power.
  1. Why doesn't this servo code work?
    By artswan in forum mel PIC BASIC Pro
    Last Post: - 5th December 2009, 23:18
  2. problems with Servo Motors...
    By saturnX in forum mel PIC BASIC Pro
    Last Post: - 11th March 2006, 02:43
  3. Servo Code problem
    By ALFRED in forum General
    Last Post: - 2nd March 2006, 04:30
  4. How would i write this in pic basic pro (Servo controller)
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 09:21
  5. PIC basic and rc servo signals
    By BCIcdrz in forum mel PIC BASIC Pro
    Last Post: - 11th May 2003, 15:51
