Many problems with programs that used to work
Results 1 to 10 of 10
    Default Re: Many problems with programs that used to work
    Well, in that case I stand corrected - for now... :-)
    Feb 2005
    Holmfirth England
    Thank you for your help. I will post the full code.
    #config
     __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BOREN_ON & _CP_ON & _LVP_OFF
    data @1,200,0,200,0,200,0,200,0,50,0,50,0,50,0,50,0
    data @17,0,0,0,0,0,0,0,0,30,0,30,0,30,0,30,0,0
    define OSC 20
    asm
        BSF     STATUS, RP0 ;SELECT BANK 1
        MOVLW   0x06        ;A/D channels all digital
        MOVWF   ADCON1
        MOVLW   0x07        ;PORT B = 00000111
        MOVWF   TRISB
        MOVLW   0xEF        ;PORT C = 11101111
        MOVWF   TRISC
        MOVLW   0x0F        ;PORT D = 00001111
        MOVWF   TRISD
        MOVLW   0x07        ;PORT E = 111
        MOVWF   TRISE
        BCF     STATUS, RP0 ;SELECT BANK 0
    spare       var portb.0
    coilin      var portb.1
    contact     var portb.2
    pulseon     var portb.3
    coil1       var portb.4
    coil2       var portb.5
    coil3       var portb.6
    coil4       var portb.7
    sw4         var portc.0
    sw3         var portc.1
    sw2         var portc.2
    sw1         var portc.3
    trigout     var portc.4
    trigger4    var portd.0
    trigger3    var portd.1
    trigger2    var portd.2
    trigger1    var portd.3
    led1        var portd.4
    led2        var portd.5
    led3        var portd.6
    led4        var portd.7
    clock       var porte.0
    dout        var porte.1
    send        var porte.2
    current1    var word
    current2    var word
    current3    var word
    current4    var word
    time1       var word
    time2       var word
    time3       var word
    time4       var word
    gas1        var word
    gas2        var word
    gas3        var word
    gas4        var word
    sctime1     var word
    sctime2     var word
    sctime3     var word
    sctime4     var word
    packet      var word
    index       var word
    ivalue      var word
    tvalue      var word
    gvalue      var word
    scvalue     var word
    machinetype var word
    lastgun     var byte
    let lastgun = 0
    GOSUB readvalues
    GOTO MAIN
    writevalues1:           'write gun 1 values to memory
    write 1, ivalue.lowbyte
    write 2, ivalue.highbyte
    write 9, tvalue.lowbyte
    write 10, tvalue.highbyte
    write 17, gvalue.lowbyte
    write 18, gvalue.highbyte
    write 25, scvalue.lowbyte
    write 26, scvalue.highbyte
    writevalues2:           'write gun 2 values to memory
    write 3, ivalue.lowbyte
    write 4, ivalue.highbyte
    write 11, tvalue.lowbyte
    write 12, tvalue.highbyte
    write 19, gvalue.lowbyte
    write 20, gvalue.highbyte
    write 27, scvalue.lowbyte
    write 28, scvalue.highbyte
    writevalues3:           'write gun 3 values to memory
    write 5, ivalue.lowbyte
    write 6, ivalue.highbyte
    write 13, tvalue.lowbyte
    write 14, tvalue.highbyte
    write 21, gvalue.lowbyte
    write 22, gvalue.highbyte
    write 29, scvalue.lowbyte
    write 30, scvalue.highbyte
    writevalues4:           'write gun 4 values to memory
    write 7, ivalue.lowbyte
    write 8, ivalue.highbyte
    write 15, tvalue.lowbyte
    write 16, tvalue.highbyte
    write 23, gvalue.lowbyte
    write 24, gvalue.highbyte
    write 31, scvalue.lowbyte
    write 32, scvalue.highbyte
    readvalues:
    read 1, current1.lowbyte
    read 2, current1.highbyte
    read 3, current2.lowbyte
    read 4, current2.highbyte
    read 5, current3.lowbyte
    read 6, current3.highbyte
    read 7, current4.lowbyte
    read 8, current4.highbyte
    read 9, time1.lowbyte
    read 10, time1.highbyte
    read 11, time2.lowbyte
    read 12, time2.highbyte
    read 13, time3.lowbyte
    read 14, time3.highbyte
    read 15, time4.lowbyte
    read 16, time4.highbyte
    read 17, gas1.lowbyte
    read 18, gas1.highbyte
    read 19, gas2.lowbyte
    read 20, gas2.highbyte
    read 21, gas3.lowbyte
    read 22, gas3.highbyte
    read 23, gas4.lowbyte
    read 24, gas4.highbyte
    read 25, sctime1.lowbyte
    read 26, sctime1.highbyte
    read 27, sctime2.lowbyte
    read 28, sctime2.highbyte
    read 29, sctime3.lowbyte
    read 30, sctime3.highbyte
    read 31, sctime4.lowbyte
    read 32, sctime4.highbyte
    READ 33, MACHINETYPE.LOWBYTE
    READ 34, MACHINETYPE.HIGHBYTE
    sendmain:
    low clock
    low dout
    low send
    let packet = ivalue
    high send
    pause 50
    gosub sout
    low send
    pause 10
    let packet = tvalue
    high send
    pause 10
    gosub sout
    low send
    pause 10
    let packet = gvalue
    high send
    pause 10
    gosub sout
    low send
    pause 10
    let packet = scvalue
    high send
    pause 10
    gosub sout
    low send
    pause 10
    let packet = machinetype
    high send
    pause 10
    gosub sout
    low send
    pause 5
    input send
    input clock
    input dout
    sout:
    for index = 0 to 15
    dout = packet.0[index]
    pause 5
    high clock
    pause 5
    low clock
    pause 5
    next index
    low dout
    weld1: 'welding routine for gun1
    'check if it is a good trigger signal
    pause 10
    if trigger1 = 1 then return
    pause 10
    'check to see if gun1 was last to be uesd
    if lastgun = 1 then goto jmp1   'if it was last to be used then no need to
                                    'send settings or change relays
    high coil1     ;switch on channel 1 relay
    low coil2     ;swirch off all others
    low coil3
    low coil4
    'load channel 1 settings ready to be sent to main card
    let ivalue = current1
    let tvalue = time1
    let gvalue = gas1
    let scvalue = sctime1
    gosub sendmain ' send the values
    pause 150
    jmp1:   'jump to here if this was last gun used
    let lastgun = 1 'set last gun flag
    high pulseon
    pause 150
    high trigout
    low trigout
    pause gas1
    pause time1
    pause sctime1
    asm
    JMPA    BTFSC   _coilin     ;wait for coil to go low
            GOTO    JMPA
    JMPB    BTFSC   _contact    ;wait for break in contact
            GOTO    JMPB
    endasm
    low pulseon
    pause 600
    weld2: 'welding routine for gun2
    pause 10
    if trigger2 = 1 then return
    pause 10
    'check to see if gun2 was last to be uesd
    if lastgun = 2 then goto jmp2   'if it was last to be used then no need to
    high coil2     ;switch on channel 2 relay
    low coil1     ;swirch off all others
    low coil3
    low coil4
    'load channel 2 settings ready to be sent to main card
    let ivalue = current2
    let tvalue = time2
    let gvalue = gas2
    let scvalue = sctime2
    pause 150
    jmp2:   'jump to here if this was last gun used
    let lastgun = 2 'set last gun flag
    high pulseon
    pause 150
    high trigout
    low trigout
    pause gas2
    pause time2
    pause sctime2
    asm
    JMPC    BTFSC   _coilin     ;wait for coil to go low
            GOTO    JMPC
    JMPD    BTFSC   _contact    ;wait for break in contact
            GOTO    JMPD
    endasm
    low pulseon
    pause 600
    weld3: 'welding routine for gun3
    pause 10
    if trigger3 = 1 then return
    pause 10
    'check to see if gun3 was last to be uesd
    if lastgun = 3 then goto jmp3   'if it was last to be used then no need to
    high coil3     ;switch on channel 3 relay
    low coil2
    low coil4
    'load channel 3 settings ready to be sent to main card
    let ivalue = current3
    let tvalue = time3
    let gvalue = gas3
    let scvalue = sctime3
    pause 150
    jmp3:   'jump to here if this was last gun used
    let lastgun = 3 'set last gun flag
    high pulseon
    pause 150
    high trigout
    low trigout
    pause gas3
    pause time3
    pause sctime3
    asm
    JMPE    BTFSC   _coilin     ;wait for coil to go low
            GOTO    JMPE
    JMPF    BTFSC   _contact    ;wait for break in contact
            GOTO    JMPF
    endasm
    low pulseon
    pause 600
    weld4: 'welding routine for gun4
    pause 10
    if trigger4 = 1 then return
    pause 10
    'check to see if gun4 was last to be uesd
    if lastgun = 4 then goto jmp4   'if it was last to be used then no need to
    high coil4     ;switch on channel 4 relay
    low coil2
    low coil3
    'load channel 4 settings ready to be sent to main card
    let ivalue = current4
    let tvalue = time4
    let gvalue = gas4
    let scvalue = sctime4
    pause 150
    jmp4:   'jump to here if this was last gun used
    let lastgun = 4 'set last gun flag
    high pulseon
    pause 150
    high trigout
    low trigout
    pause gas4
    pause time4
    pause sctime4
    asm
    JMPG    BTFSC   _coilin     ;wait for coil to go low
            GOTO    JMPG
    JMPH    BTFSC   _contact    ;wait for break in contact
            GOTO    JMPH
    endasm
    low pulseon
    pause 600
    settings:
    'test switches & light the ones that need to be on
    if sw1 = 0 then
    high led1
    low led1
    if sw2 = 0 then
    high led2
    low led2
    if sw3 = 0 then
    high led3
    low led3
    if sw4 = 0 then
    high led4
    low led4
    'if all switches are off (high) then turn off leds, and return
    if (sw1 = 1) and (sw2 = 1) and (sw3 = 1) and (sw4 = 1) then
    low led1
    low led2
    low led3
    low led4
    if send = 1 then gosub readin
    goto settings
    rcv:  'routine to receive packets of information
    for index = 0 to 15
    while clock = 0
    wend
    packet.0[index] = dout
    while clock = 1
    wend
    next index
    readin:
    pause 1
    if send = 0 then return
    pause 1
    pause 1
    pause 1
    pause 1
    pause 1
    gosub rcv
    let ivalue = packet
    let packet = 0
    ASm
    JMPI    BTFSC   _send  ;Wait for send to go low
            GOTO    JMPI
    JMPJ    BTFSS   _send  ;Wait for send to go high
            GOTO    JMPJ
    gosub rcv
    let tvalue = packet
    let packet = 0
    ASm
    JMPK    BTFSC   _send  ;Wait for send to go low
            GOTO    JMPK
    JMPL    BTFSS   _send  ;Wait for send to go high
            GOTO    JMPL
    gosub rcv
    let gvalue = packet
    let packet = 0
    ASm
    JMPM    BTFSC   _send  ;Wait for send to go low
            GOTO    JMPM
    JMPN    BTFSS   _send  ;Wait for send to go high
            GOTO    JMPN
    gosub rcv
    let scvalue = packet
    let packet = 0
    ASm
    JMPO    BTFSC   _send  ;Wait for send to go low
            GOTO    JMPO
    JMPP    BTFSS   _send  ;Wait for send to go high
            GOTO    JMPP
    gosub rcv
    let machinetype = packet
    let packet = 0
    JMPQ    BTFSC   _send  ;Wait for send to go low
            GOTO    JMPQ
    'we have received values from front PCB, now need to store any that
    'have switches set
    if led1 = 1 then gosub writevalues1
    if led2 = 1 then gosub writevalues2
    if led3 = 1 then gosub writevalues3
    if led4 = 1 then gosub writevalues4
    write 33, machinetype.lowbyte
    write 34, machinetype.highbyte
    'first check for any trigger signals
    if trigger1 = 0 then gosub weld1
    if trigger2 = 0 then gosub weld2
    if trigger3 = 0 then gosub weld3
    if trigger4 = 0 then gosub weld4
    'now check if any settings switches are on
    if (sw1 = 0) or (sw2 = 0) or (sw3 = 0) or (sw4 = 0) then gosub settings
    'switch on led of last used gun
    if lastgun = 1 then
    high led1
    low led2
    low led3
    low led4
    if lastgun = 2 then
    low led1
    high led2
    low led3
    low led4
    if lastgun = 3 then
    low led1
    low led2
    high led3
    low led4
    if lastgun = 4 then
    low led1
    low led2
    low led3
    high led4
    I'm not sure if this will help, as I said the program did work fine, before Windows 7, and PBP3. Though I am not certain that this is the cause. My development time is short and fragmented with months going by without looking at a project. This makes it hard to keep track of what stage I was at, and what exactly I was doing when I encountered a problem.
    The problem with this program is in the 4 weld subroutines. The If lastgun statements (in bold type) are always ignored, or rather if you keep pressing the trigger on one gun the lastgun flag is not set to a number, so the next time pressing the trigger the code i want to skip is always executed.
    Bob.
    When I get unexpected results like this, I test pieces of logic one by one.
    I'd start with just blinking a led in simplest loop possible; just to be sure pic timing and configs are correct. With timing you can verify easily, like:
    LOOP:
    pin=1
    pin=0
    goto LOOP
    Feb 2005
    Holmfirth England
    Thanks for your replies. I have now solved the problem, but still cant explain why it was behaving as it was.
    Turns out that I had added some code that had not been tested, before being broken off the project for some months.
    asm
    GOTO JMPA
    GOTO JMPB
    endasm
    They should have been BTFSS. Though how the program was still running and not getting stuck there is a mystery to me. I think it may have been some issue that caused the pic to do a brown out reset each time it went through a weld routine.
    Anyways now I have everything working like a dream the project has been scrapped, so sorry for wasting all of your time.
    Kind regards
    Bob.
  1. lost programs/programs rolled back
    By Chris Barron in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 01:22
  2. How to use TRIS on a ICD programs
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 10th August 2009, 02:12
  3. HELP W/programs
    By furmpf in forum mel PIC BASIC Pro
    Last Post: - 26th February 2008, 14:45
  4. problems with I2C.... and ideas why dosent work?
    By snood in forum mel PIC BASIC Pro
    Last Post: - 26th April 2005, 13:54
  5. Replies: 3
    Last Post: - 3rd September 2003, 13:05
