I am having troubles recently. Programs that used to work ok are now behaving strangely, like certain lines of code being ignored, or so it seems. I may have only changed a pause time or something simple, but when compiled no longer work as expected. This started (though may be a coincidence) when I moved to windows 7 at work, PBP V2.5 did not seem to work, so I upgraded to PBP3, but still having problems. Here is an example.
Now no matter which coil input is high, and when pulseon is low all the program will do is switch on thy1, and continually run the pulse subroutine.Code:goto start pulse: while pulseon = 1 high pulses pauseus 100 low pulses pauseus 100 wend return start: if coil1 = 1 then thy1 = 1 thy2 = 0 thy3 = 0 thy4 = 0 endif if coil2 = 1 then thy1 = 0 thy2 = 1 thy3 = 0 thy4 = 0 endif if coil3 = 1 then thy1 = 0 thy2 = 0 thy3 = 1 thy4 = 0 endif if coil4 = 1 then thy1 = 0 thy2 = 0 thy3 = 0 thy4 = 1 endif if pulseon = 1 then gosub pulse goto start
Here is another:
Here the first line is always ignored, all of the rest of this quite large program works fine, and these programs used to work fine.Code:if lastgun = 3 then goto jmp3 'if it was last to be used then no need to 'send settings or change relays high coil3 ;switch on channel 3 relay low coil1 ;swirch off all others low coil2 low coil4 'load channel 3 settings ready to be sent to main card let ivalue = current3 let tvalue = time3 let gvalue = gas3 let scvalue = sctime3 gosub sendmain ' send the values pause 150 jmp3: 'jump to here if this was last gun used let lastgun = 3 'set last gun flag
I have tried changing chips, and PCBs so I know it cant be hardware faults, or blown chips.
Anyone have any ideas?
Bob.![]()
