Quad Encoder Problem
Results 1 to 37 of 37
    Default Re: Quad Encoder Problem
    I stil cannot see how this piece of code can be true:
    RotEncDir = New_Bits.1 ^ Old_Bits.0
        IF RotEncDir = 1 Then
    If you follow what Henrik has posted on that pulse train diagram at #21, you will see that after the above XOR, the IF RotEncDir = 1 statement will always fail and the ELSE will be executed.
    The New_Bits will be the same for A & B, but the Old_Bits should still have PORTA.0 (B pin of encoder) as 1 for the last falling edge interrupt, won't it?
    I don't think so after the 4 step counter. At that moment both will be zero.
    But experimentally it works, both for CW & CCW. I'd love to optimize this code for full quad cycle encoders like the CUI ACZ11 one I'm using, but I'm at a loss as to what to change (other than trying Henrik's suggestion of reducing the number of edges to 2 from 4).
    Change the code so that you interrupt on one edge of one channel - only. (The rising edge of channel A for example).
    In the ISR, poll "the other" channel, if it's low you're moving in one direction, if it's high you're moving in the other.
    Verify that it works at "any" speed you may turn the encoder.
    I tried this but nothing happens - the display changes erratically with encoder movement and only really goes up or down by 1:
    #DEFINE USE_CUI_ROTARY_ENCODER  ; comment out if using Grayhill rotary encoder
                                    ; which triggers an interrupt only once per detent
    ' Enable interrupts on RPM control now that motors are fully spun up
    INTCON   = %10001000        ' Global int enabled, IOCI enabled,
                                ' INTF flag bit 0 clr, IOCI flag bit 0 clr
    #IFDEF USE_CUI_ROTARY_ENCODER
        IOCAP.1  = 1                ' Enable positive (rising edge) change, PORTA.1
    '   The CUI encoder goes thru a full quad cycle with 1 detent turn,
    '     so only need to capture 1 edge (A channel, rising)
    '   CH A
    '   CH B
    '   Detent markers
    '   If interrupt is triggered, it means A had a rising edge:
    '           If B = 0 Then CW
    '           If B = 1 Then CCW
    #ELSE
        ' For Grayhill encoder, 1 detent triggers only 1 edge
        IOCAP.0  = 1                ' Enable positive (rising edge) change, PORTA.0
        IOCAN.0  = 1                ' Enable negative (falling edge) change, POARTA.0
        IOCAN.1  = 1                ' Enable negative (falling edge) change, PORTA.1
        IOCAF.0  = 0                ' Clear interupt-on-change flag
        IOCAF.1  = 0                ' Clear interupt-on-change flag
    #ENDIF
    @ INT_ENABLE  IOC_INT       ; Interrupt-on-Change interrupt
        ' Check if motor RPM has changed
        IF MotorRPM <> Old_RPM Then
            Old_RPM = MotorRPM
            GOSUB ChngMotorHPWM
        EndIF
        If ValueDirty = 1 THEN
            TimeToSave = TimeToSave - 1
            If TimeToSave = 0 THEN           ' Time to save ?
                WRITE EE_MotorRPM, MotorRPM
                ValueDirty = 0               ' Clear the flag
                #IFDEF USE_LCD_FOR_DEBUG
                    HSEROUT [LCD_INST, LCD_CLR]
                    pause 5
                    HSEROUT ["Saved RPM=", DEC MotorRPM, "  ", 13, 10] ' Send text followed by carriage return and linefeed
                #ENDIF
        GOTO Main
    ' [IOC - interrupt handler]
    RotEncAdjust:
            IF PORTA.0 = 0 THEN
                RotEncDir = 1                 ; CW rotation if B channel is 0
                RotEncDir = 0                 ; CCW rotation
        #ELSE
            New_Bits = PORTA & (%00000011)
            IF New_Bits = Old_Bits Then DoneRotEnc
        #ENDIF
            ; CW rotation - increase speed but only to a max of 'MaxDuty'
            IF MotorRPM < MaxDuty then MotorRPM = MotorRPM + 1
        Else
            ' CCW rotation - decrease speed to a min of 0
            IF MotorRPM > 0 Then MotorRPM = MotorRPM - 1
        EndIF
        ValueDirty = 1                  ; Set dirty flag
        TimeToSave = 50000              ; Set value to begin countdown to EEPROM save
    DoneRotEnc:
        Old_Bits = New_Bits
        IOCAF.0 = 0                     ' Clear interrupt flags
        IOCAF.1 = 0
    @ INT_RETURN
    (I left out the rest of the code)
    In theory it should work... Perhaps the interrupt latency is just too large to be able to catch the correct state of the 'other' channel once you get to the ISR. One way to test that is to try it with the Grayhill encoder, then it should count every 4th click. If it does then it's a timing problem, if it doesn't it's something else.
    Nice demonstration of conditional compilation!
  1. RF600E & RF600D encoder/decoder problem
    By Megahertz in forum Off Topic
    Last Post: - 17th April 2012, 17:18
  2. using Quad UART
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 30th April 2011, 00:13
  3. quad encoders
    Last Post: - 13th March 2007, 17:49
  4. Quad encoder problems
    By smitty505000 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2006, 22:44
  5. Encoder problem
    Last Post: - 12th September 2006, 22:21
