Actuating Servos on a Schedule/Time Delay
Results 1 to 2 of 2
    Dec 2012
    Tennessee
    Question Actuating Servos on a Schedule/Time Delay
    I need to have servos (up to say 8) move from position 0 to (X) on a time delay, but I need to set a seperate time delay between each servo also,
    so say every 10 minutes I need to cycle all servos and I need each servo to wait say 20 seconds before returning to the 0 position and letting the next servo run, so on and so forth. only 1 servo can be out of the position 0 at a one time. right now I'm just working with 2 servos, but I want to use up to 8. Ive been working with the code below, i would like the display to show which servo is not in position 0, and how long before the servos are to run (in a countdown perhaps). My code is incorrect as it would fire up all servos at the same time. also if anyone sees other problems with code let me know.
    DEFINE LCD_DREG PORTD   ' LCD Data bits on PORTD
    DEFINE LCD_DBIT 0       ' PORTD starting address
    DEFINE LCD_RSREG PORTD  ' LCD RS bit on PORTD
    DEFINE LCD_RSBIT 5      ' LCD RS bit address
    DEFINE LCD_EREG PORTD   ' LCD E bit on PORTD
    DEFINE LCD_EBIT 4       ' LCD E bit address
    DEFINE LCD_BITS 4       ' LCD in 4-bit mode
    DEFINE LCD_LINES 4      ' LCD has 4 rows
    DEFINE ADC_BITS 10 ' A/D number of bits
    DEFINE ADC_CLOCK 1 ' Use A/D internal RC clock
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time in us
    TRISA = 1 'PORTA is all input
    TRISD = 0 ' PORTD is output 'LCD
    TRISB = 0 ' PORTB is output
    LCDOUT $FE, 1 ' Clear LCD
    PAUSE 500 ' Wait 0.5sec for LCD to initialize
    Time Var Word : time = 0' Time Between Engaging
    Servo VAR word : Servo = 200 ' Servo Position Set when Engaged
    NumServos VAR byte : numservos = 2 ' # of Servos, Max 8
    Counter VAr word : Counter = 0' Time Counter
    X var word : x = 0 ' OnTime
    Y VAR WORD : y = 0 ' Servo Select
    AGAIN:
    ADCIN 0, time ' Read Channel 0 data
    time = (time / 121) + 60 ' 60-600 Seconds
    for Y = 1 to NumServos
    PULSOUT PORTB.0 [Y], 100 ' Send the Home position Pulse
    Next y
    PAUSE 20 ' Wait 20 ms
    goto Display
    Counter = counter + 1
    if counter > time then counter = 0
    GOTO AGAIN ' Repeat
    RunServos:
    for X = 1 to 500 ' 20ms X 500 = 10 Seconds
    For Y = 1 to NumServos ' Select Servo
    PULSOUT PORTB.0[Y], 200 ' Send the Not HOME Pulse
    Next Y
    goto display
    next X
    Display:
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT "Set Minutes = ", DEC3 time
    LCDOUT $FE, $C0
    LCDOUT "RunTime = " , DEC Counter , "      "
    Dec 2012
    Tennessee
    Default Re: Actuating Servos on a Schedule/Time Delay
    OK i got it to work, timing is a bit off but it shouldnt work with servo positions used. I added a 3rd servo on a pot just to see what numbers i had to send to activate the servos... weird thing is it rotates from 15 - 50, a pic programming manual says to use 130 - 170, and Ive seen articles on here that use 100 - 200. on a older program i wrote just for testing servos with a 12f675 I used 100 - 200 and it worked fine. I am now using a 18f4550. not sure why its having issues. I would like to get it back to the 100-200 range for servo resolution. heres the code working right now. I did speed it up changing the adc math, 500 will go back to 121.
    TRISA = 255                               ' PORTA is all input
    PAUSE 250                               ' Wait 0.5sec for LCD to initialize
    Time Var WORD : time = 0                ' Time Between Engaging
    HomePos VAR byte : homepos = 20        ' Servo Starting Position 15
    Servo VAR byte : Servo = 25            ' Servo Position Set when Engaged 50
    Counter VAr WORD : Counter = 0          ' Time Counter
    Initialize:
    PORTB.2 = 1                             ' Set All Servos to Home Position
    For Y = 1 to NumServos                  ' Select Servo (Each in use for 5s)
    for X = 1 to 25                         ' 20ms X 250 = 5 Seconds
    PULSOUT PORTB.0[y], homepos                ' Send the Home Position Pulse
    next X
    Next Y
    PORTB.2 = 0
    Mainloop:
    time = (time / 512) + 5                ' 60-600 Seconds
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT $FE, $C0
    LCDOUT "Servo OFF = " , DEC3 counter
    counter = 0
    For Y = 1 to NumServos                  ' Select Servo (Each in use for 15s)
    LCDOUT $FE, 2
    LCDOUT $FE, $80
    LCDOUT $FE, $C0
    LCDOUT "Servo On = " , DEC3 counter     ' Update Display (Servo Selection)
    PULSOUT PORTB.0[y], servo                ' Send the Home Position Pulse
    next X
    Next Y
    PORTB.2 = 0
    next X
    Next Y
    PORTB.2 = 0
    'For X = 1 to 100
    Pause Time
    'next x
    x = 0
    GOTO mainloop                           ' Repeat
  1. Calculating time delay between two inputs?
    By grimmjow in forum General
    Last Post: - 18th October 2010, 15:52
  2. Need advice for creating nS time delay
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 12th December 2007, 08:34
  3. change in the delay in real time
    By manu123 in forum General
    Last Post: - 6th April 2007, 20:11
  4. Control unlimited servos at the same time
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 15:14
  5. Linx RF -> HSERIN time delay / time critical app...
    By batee in forum mel PIC BASIC Pro
    Last Post: - 15th October 2004, 16:04
