Problems with MicroCode Studio version MSCX
Results 1 to 24 of 24
    Default Re: Problems with MicroCode Studio version MSCX
    Hi, Yes, MCSX is the only program that crashes. The PC works without other problems. I would try another computer, but my wife's laptop is my only available option, and that could cause marital discord.
    I don't know much about managing computer resources. Everything is as came with Windows XP, as far as I know.
    I'm not familiar with the Task Manager. When run, it lists the Physical memory as;
    Total 2.35 mb
    Available 1.61
    System cache 1.19
    I am not an expert on windows too. But you might try something just in case.
    You might need the CD of Windows with this.
    From Command prompt window run sfc /scanonce (More about this here: http://www.microsoft.com/resources/d....mspx?mfr=true)
    This will check your Windows system files for corruption and replace them either from your hard drive or from your CD.
    I think that this tool can run if you are loged in as admininstrator only.
    Hope this will solve your problem.
    Ioannis, sfc/scanonce not found on my computer. I think sfc is a XP Professional Edition function not the Home Edition that I have.
    The problem remains and is isolated to MCSX. As mentioned earlier the older MCS and all other programs work okay.
    Henrick, When I right click I'm not getting an Administrator option.
    Sorry, my bad, I was in "Windows 7 mode". I'm afraid I don't have any more ideas, I sincerely hope you get it resolved one way or another.
    The sfc.exe is present on all windows. Are you sure you cannot find it?
    If it is not on yours, then I suppose other files are missing too...
    How about a re-install of windows?
    Ioannis, I found and ran the system file checker. A search disclosed the correct format to be: sfc.exe /scannow. Followed this with a Windows Update. The result is the same: MSCX stops running, coughs out the same error message. I thank you and Henrick for you suggestions, but it appears something is wrong with MCSX.
    I can verify the MCSX runs on Win XP Home. I run a VirtualBox with XP Home on my Linux box (PBP3 does not play nice on Linux, but that is another issue). So, as much as I dislike MCSX there is not a problem with it running.
    The next time you get the error message, post here what it says it will send to Microsoft. (click on the "click here"). Maybe we will see the problem?
  1. MicroCode Studio Plus Problems
    By Mike2545 in forum mel PIC BASIC Pro
    Last Post: - 11th August 2009, 03:11
  2. new version MicroCode Studio Plus ?????
    By micro in forum mel PIC BASIC Pro
    Last Post: - 27th December 2006, 15:02
  3. Problems with MicroCode Studio ICD
    By Muzza in forum mel PIC BASIC Pro
    Last Post: - 5th July 2006, 03:37
  4. Microcode Studio Problems
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 25th March 2006, 19:00
  5. Replies: 3
    Last Post: - 16th September 2005, 08:40
