OK, give it a try and see if it springs to life.
I've commented out the line re: set the GIE or INTE bits but left the clearing of the interrupt flag in my handler. Are you sure I don't need that?Since you have the ResetFlag "switch" set to Yes, then no you shouldn't have to reset the flag manually. I don't think there's any harm in doing it though, except wasting execution cycles.Code:ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler INT_INT, _Flash_Mode_Btn, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM
