BUTTON question
Results 1 to 4 of 4
Thread: BUTTON question
    Default BUTTON question
    Hi, The team
    I played a bit with BUTTON command ...
    BUT ... could someone explain to me HOW the BVar variable ( as named in the Holy Manual ) really acts ???
    That is simply to use different BUTTON Commands with different debouncing durations ... ( and there's only ONE DEFINE in the Header ... )
    Default Re: BUTTON question
    ... This timeout really is a shame ... Lester !!!
    May be I could overwrite the value located @ asm line 20 ( if my chip allows program rewrite @ runtime ... ) , but I feel it ... " not so good " ...
    Oct 2009
    Utah, USA
    Wink Re: BUTTON question
    As I read the "holy manual"... especially the explaination on the second page at the bottom, I would interpret it that the BVar just lets you choose what name to call the varialble that will be used for the Button command.
    So you must declare that variable as a Byte and initialize it to = 0 and not use it else where in your program.
    But then I could be wrong... as I often am.
    Dwight
    Hi, Heckler
    I also read That in my Holy Manual ...
    But the interesting point is "How to modify the debouncing time" to adapt it to the place where the BUTTON Command is located...
    as the same button can be used for different actions all along a program ...
    the amazing game is to initialize BVar to 1, 2 .... 255 ... instead of 0
  1. Button command question
    By aherrera in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 08:44
  2. button help
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 14th October 2008, 13:12
  3. Button
    Last Post: - 27th May 2007, 16:52
  4. Button
    Last Post: - 4th July 2006, 23:32
  5. Interrupt Button Wiring Question
    By elec_mech in forum mel PIC BASIC Pro
    Last Post: - 8th June 2005, 12:25
