Pic int
Results 1 to 3 of 3
Thread: Pic int
    Mar 2013
    Default Pic int
    What is the difference between PICbasic INT and Atom INT
    PICBASIC
    led var PORTB.7 ‘Establish name for portb.7
    ATOM
    time var byte ‘ Establish variable Time
    trisc = %00000000 ‘ Make port C all outputs (P8-P15)
    portc = %11111111 ‘ P12-P15 LEDs off, P8 on
    http://www.precision-robotics.com/pic_int.pdf
    Dec 2012
    Tennessee
    Default Re: Pic int
    4 letters
    hahahaha sorry
    Default Re: Pic int
    Hi and welcome to the forum,
    Was this meant as a question or did you want to link to the article which tried to answers that very question?
    If it WAS meant as a question then a good place to start is in the very article you linked to, then in the syntax manual for the ATOM.
    Since the code snippets you posted actually doesn't have anthing to do with interrupts it's possible that you're confusing it with the datatype INTeger.... INT, in this case stands for Interrupt and not integer as may be the case in other languages.
    Anyway, if it was a question and you don't get an answer please clarify what it is you're asking.
  1. Replies: 17
    Last Post: - 16th March 2013, 00:11
  2. Replies: 8
    Last Post: - 19th January 2013, 00:21
  3. interfacing pic 18f4520
    By keerthi in forum General
    Last Post: - 11th January 2013, 06:45
  4. PIC as I2C Slave
    By Mainul in forum General
    Last Post: - 5th January 2013, 14:23
  5. Interupts - can two switches share the 'INT' Pin?
    Last Post: - 19th May 2010, 00:28
