help me please
Results 1 to 20 of 20
Thread: help me please
    so now it imply that you use SERIN2/SEROUT2 or else. chances are that you'll never find anything in the datasheet since it's a PBP statement. You'll find the result in the APPENDIX A at the end of your PBP manual... there you'll find the right setting for SERIN2/SEROUT2 wich is.....16468
    For SERIN/SEROUT you'll use 6
    You can't tell to HSERIN/HSEROUT to drive inverted since it use the internal PIC hardware.
    MICOCALI's Avatar
    MICOCALI Guest
    Default re
    I write this code and now run but not very well . sometime run at first ring , sometime run at five ring , wy for you?
    @ device WDT_OFF, MCLR_OFF, HS_OSC, BOD_OFF, PWRT_ON, CPD_OFF, LVP_OFF
    INCLUDE "modedefs.bas"
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE DEBUGIN_MODE 1
    DEFINE DEBUG_MODE 1
    DEFINE DEBUGIN_REG PORTB
    DEFINE DEBUGIN_BIT 4
    CMCON = 7
    VRCON = 0
    INIT:
    Pause 2000
    LOOP:
    Pause 500
    HSerout ["AT*EIPS=1,1",13,10]
    Pause 3000
    Loop2
    DebugIn [wait("*")]
    APRI:
    High PORTA.1
    Pause 1000
    Low PORTA.1
    Pause 10000
    GoTo LOOP
