help me please
Results 1 to 20 of 20
Thread: help me please
    MICOCALI's Avatar
    MICOCALI Guest
    Default a problem
    thank you for reply but i have one problem:
    HSerin 2000,LOOP,[WAIT ("*ELIP:")] is true when i receve all caracter?(*elip
    if yes what is the command for receve only two caracter for example *e
    thank you carlo
    HSerin 2000,LOOP,[WAIT ("*ELIP:")] is going to wait until *ELIP: is received.
    If *elip: (note it's in lower case) is received, it will not match.
    If you need to wait for 2 characters, then only use 2 characters.
    HSerin 2000,LOOP,[WAIT ("*E")]
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    MICOCALI's Avatar
    MICOCALI Guest
    Default not run
    the telefone send *elip i confirm with hyper terminal ,i write
    HSerin 2000,LOOP,[WAIT ("*E")] in the pic 16f628 but the pin portb4 not
    on.
    wy for you?
    If you are seeing *elip in hyperterminal, then wait for *e. Not *E.
    i write HSerin 2000,LOOP,[WAIT ("*E")]
    Have you tried this?
    HSERIN 2000,LOOP,[WAIT("*e")]
    -Bruce
    tech at rentron.com
    MICOCALI's Avatar
    MICOCALI Guest
    Default re
    I write:
    but not run
    I connect the pic with two resistore of 4,7 kohm direct at the phone if possible is this? not max 232
    Does your phone output RS232 or TTL level voltage?
    Does your phone send serial data inverted or true?
    -Bruce
    tech at rentron.com
    MICOCALI's Avatar
    MICOCALI Guest
    Default i think
    but is not important because the command Hserout is run very well i think
