Guide on flow sensor application
Results 1 to 9 of 9
    Jun 2011
    Philippines
    Default Re: Guide on flow sensor application
    Hi I'm back...My first attempt for 1 flow sensor is I tried to count the pulse similar to a switch button....but still not really sure if I'm doing it right. If its fine how do I get flow rate?...kindly check the code I'm using.
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas"  ' Include if using PBP interrupts
    ;-- Define LCD connections -- (change these to match your hardware) ------------
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    PAUSE 100
    TRISA = %00000000               ; set PORTA to output pins
    PortA = %00000000               ; set to PORTA low
    TRISB = %10000000               ; set PORTB to B7 input pin rest output pins
    PortB = %00000000               ; set to PORTB low
    TRISC = %10000000               ; set PORTD to output pins
    PORTC = %00000000
    TRISD = %10000000               ; set PORTD to output pins
    PORTD = %00000000               ; set to PORTD low
    LCDOUT  $FE,1                   ; Initialize the LCD
    pause 200                       ; pause 2 milisec
    OPTION_REG = $7f  'enable pull offs
    '--variables init
    flag1 var bit
    flag1 = 0
    c var byte
    c = 0
    cnt1 var word
    cnt1 = 0
    StatLed var PORTA.0
    StatLed = 0
    But0 var PortB.7
    But0 = 0
    '--LCD line
    ln1 con $80
    ln2 con $C0
    CS  con 1
    SerialInput var byte[50]
    Serialdata var byte
    ; setup serial port line for transmition
    DEFINE HSER_TXSTA 20h ' Enable transmit, BRGH = 1
    DEFINE HSER_BAUD 9600
    RCIF       VAR     PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
    TXIF       VAR     PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
    '------------------------------------------------------Transmition-------------
    ; create the transmition interrupt
            INT_Handler   RX_INT,    _Getbytes,    PBP,  no
    T1CON = $31                ; Prescaler = 8, TMR1ON
    @ INT_ENABLE  RX_INT
    Hserout ["Flow Sensor Test",13]
    PortB.7 = 0
    LCDOUT $FE,ln1,"Flow Sensor Test"
    LCDOUT $FE,ln2 ,"Cnt: ",dec3 cnt1
    Pause 25
    IF But0 = 0 then
    cnt1 = cnt1+1
       While But0 = 0:Wend
       If flag1 = 0 then
        HSEROUT ["Counter:",Dec3 cnt1,13]
        flag1 = 1
        flag1 = 0
       Endif
    Goto main
    '(((((((((((((((((((((((((This is a preparation for PC interface))))))))))))))))
    Getbytes:
           While RCIF = 1     ' clear the buffer
           c = c + 1
           Hserin [Serialdata]
           select case Serialdata          ' What to do with that data???
               case "A"            ' User selection
                    HSEROUT ["Option A",13] ' take it out
               case "B"
                    HSEROUT ["Option B",13] ' take it out
               case "C"
                    HSEROUT ["Option C",13] ' take it out
               case "*"
                    'HSEROUT ["This is it! > ",13] ' take it out
                    SerialInput[c] =" "
               case else
                   SerialInput[c] = Serialdata
             End select
           Wend
    @ INT_RETURN
    ToggleLED1:
    'Toggle statLed
    @ INT_RETURN
    I also attached some pics about my hardware setup..
    Appreciate any input and time...
    tacbanon
    If it counts the pulses properly then I guess you're doing it right. However, doing it this way is probably not the best when you're trying to get more sensors in but more on that later.
    If you look at the product page for the sensor there's a diagram showing the output frequency as a function of the flowrate. The output seems pretty linear (as you'd expect) with 4.5Hz/l/min.
    So if you count pulses for on second and divide the result by 4.5 you have your flowrate in litres/minute.
    For multiple sensors I'd set up a timer interrupt and poll all inputs in one go. Compare this state to the previous one to see if any input changed. Since the dutycycle of sensor output is 50% you can get twice the resolution (if needed) by counting both the positive and negativ going edges of the signal but then you'd need to poll the inputs twice as fast to guarantee not missing any pulses. It's going to be kind of like reading incremental encoders (lots of examples floating around here) but without the need to determine direction.
    Nice hardware setup!
    I spent some time on this and here's what I came up with. It counts four sensors on PortC.0-3 using a timer based interrupt, polling the inputs at 250Hz. It counts both rising and falling edges effectively doubling the resolution and calculates the flowrate. Hope it's of some use.
    '*  Name    : Flowrate.PBP                                      *
    '*  Author  : Henrik Olsson                                     *
    '*  Notice  : Copyright (c) 2011 Henrik Olsson 2010             *
    '*          : No Rights Reserved                                *
    '*  Date    : 2013-03-10                                        *
    '*  Notes   : Written for tacbanon.                             *
    '*          : Counts pulses from four flow sensors connected    *
    '*          : to the lower four bits of PortC and calculates    *
    '*          : the flowrate based on 4.5Hz/l/min.                *
    '*          : Program requires TMR1 interrupt to exectute at    *
    '*          : 250Hz. Set TmrReload constant to correct value:   *
    '*          : 61543 for 4MHz                                    *
    '*          : 57543 for 8MHz                                    *
    '*          : 45543 for 20MHz                                   *
    '*          :  1543 for 64MHz                                   *
    '*          : Tweak if neccesary                                *
    '*          : Development board used: AMICUS18 platform @64MHz  *
    '*          : Change hardware setup to match acutal hardware!   *
    DEFINE OSC 64
    DEFINE LOADER_USED 1                    ' We're using a bootloader.
    DEFINE HSER_RCSTA 90h                   ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h                   ' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1                   ' Clear overflow automatically
    DEFINE HSER_SPBRG 138                   ' 115200 Baud @ 64MHz, -0,08%
    INCLUDE "DT_INTS-18.bas"                ' Include Darrel Taylors interrupt processing routines
    INCLUDE "ReEnterPBP-18.bas"
            INT_Handler   TMR1_INT,  _PollInputs,   PBP,  yes
        INT_CREATE              ; Creates the interrupt processor
    ' Create an alias to the TIMER1 register so we can access it as a word.
    ' Make sure RD16 is disabled.
    @Timer1 = TMR1L
    Timer1  VAR  WORD EXT
    TMR1_ON VAR T1CON.0                     ' Alias to the TMR1ON bit
    SensorCount Var BYTE[4]                 ' Count 4 sensors
    FlowRate VAR BYTE[4]                    ' Flow rate for 4 sensors
    SensorState VAR BYTE                    ' Stores current state of inputs.
    PreviousState VAR BYTE                  ' Used to determine if inouts has changed state.
    ISRCount VAR WORD                       ' Used to keep time based on number of interrupts
    i VAR byte                              ' General purpose index variable
    j VAR BYTE                              ' General purpose index variable
    DataReady VAR BIT
    TmrReload CON 1543                      ' 250Hz, 1:1 @64MHz
    CLEAR
    SPBRGH = 0
    BAUDCON.3 = 1                           ' Enable 16 bit baudrate generator
    TRISB = %00000000                       ' PortB.0 are all outputs
    TRISC = %10001111                       ' Sensor inputs on PortC.0-3, RX/TX on PortC.7/PortC.6
    Timer1 = TmrReload                      ' Preload the timer for 250Hz interrupt
    TMR1_ON = 1                             ' Start the timer and....
    @ INT_ENABLE TMR1_INT                   ; ....enable the interrupt
    HSEROUT["Program start",13]
        If DataReady = 1 THEN               ' ISR sets this flag when data new data is avialble
            DataReady = 0                   ' Clear the flag
            HSEROUT["Flowrate: "]
            For j = 0 to 3
                ' The ISR calculate the flow rate in units of 0.1 litres per minute.
                HSEROUT[DEC FlowRate[j] / 10, ".", DEC FlowRate[j] // 10, "l/min."]
                If j = 3 THEN
                    HSEROUT[13]
                    HSEROUT[" - "]
            NEXT
    Goto Main
    ' ------------- [Interrupt service routine for Timer1 interrupt] ---------------
    ' Designed to be executed at 250Hz. Make sure to change the TmrReload constant
    ' to match the actual clock frequency of the PIC.
    PollInputs:
        TMR1_ON = 0                         ' Stop timer
        Timer1 = Timer1 + TmrReload         ' Reload timer, account for latency
        TMR1_ON = 1                         ' Restart timer
        'Toggle PortB.0                      ' Used to verify interrupt frequency
        SensorState = PortC & %00001111     ' Get state of inputs.
      ' Iterate thru the four sensor inputs and determine if anyone has changed
      ' state since last interrupt. If so, increment the count for that sensor.
        For i = 0 to 3
            If SensorState.0[i] XOR PreviousState.0[i] = 1 THEN
                SensorCount[i] = SensorCount[i] + 1
        NEXT
        PreviousState = SensorState         ' Store current state so we have something to compare with.
        ' To get some resolution we update the flowrate and volume at a rate of
        ' 0.5Hz based on the 250Hz interrupt frequency. The output frequency of
        ' the sensor is 4.5Hz/l/min, we're counting both rising and falling edges
        ' so we're getting 9 counts/l/min per second. We're counting for 2 seconds
        ' so we're going to divide by 1.8 to get the flow in units of 0.1 l/min
        ISRCount = ISRCount + 1
        If ISRCount = 499 THEN               ' 500 interrupts = 2 seconds.
            ISRCount = 0
            DataReady = 1
            For i = 0 to 3
                FlowRate[i] = SensorCount[i] ** 36409
                SensorCount[i] = 0
            NEXT
    @ INT_RETURN
    Jun 2011
    Philippines
    Smile Re: Guide on flow sensor application
    WOW Henrik...Thank You! I know it would take for me another week(s) to get this application running and probably thinking of another path to make it easier for me...but this is just so great (save me lot of precious time )...I will work on it, and feed back you later.
    Kind regards,
    tacbanon
  1. Microchip Tips ‘N Tricks Guide
    By Heckler in forum Documentation
    Last Post: - 6th January 2015, 05:24
  2. fuel flow sensor?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 20th May 2009, 04:01
  3. Mass Air Flow Sensor Data
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 1st January 2009, 09:35
  4. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 04:05
  5. Windows XP API guide
    By mister_e in forum Off Topic
    Last Post: - 9th July 2006, 19:55
