SPI devices in parallel.
Results 1 to 12 of 12
    Feb 2004
    Michigan, USA
    Default Re: SPI devices in parallel.
    Dont worry about it.
    I'm going to try the drivers and will be using standard cat5 cable and connectors. Makes things really easy.
    Feb 2004
    Michigan, USA
    Just a thought, connect a 1K resistor to the output of each receiver and connect the other end of the resistor to the base of a 3904 transistor, I think I should be able to turn on an LED each time the line goes high without loading it. It would be really nice to have a simple led showing activity on the data lines at each light, as a cable and connector diagnostic.
  1. question about the pin to pin connections on a SPI interface
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 14:03
  2. Need to use SPI but I'm already using the SPI port
    Last Post: - 30th December 2012, 10:52
  3. USB devices
    By MKtiger in forum USB
    Last Post: - 2nd November 2008, 11:23
  4. problems with parallel LCD
    By Brown in forum mel PIC BASIC
    Last Post: - 12th June 2008, 05:37
  5. Parallel LCD to Serial LCD
    By Mostafa in forum mel PIC BASIC Pro
    Last Post: - 17th June 2007, 22:14
