150 ms between readings must be a bit tooshort to see anything clear ...
also add PAUSE > 700ms before sending the first data stream ( just once @ power up ) to the LCD ...
I am down with just the LCDOUT commands:
still giving awkward letters on the LCD:
INCLUDE "modedefs.bas" 'Includes supoprt for PicBasic language
OSCCON = %01110000 '8 Mhz
DEFINE OSC 8
'// LCD configuration //
DEFINE LCD_DREG PORTB ' Set LCD Data port
DEFINE LCD_DBIT 4 ' Set starting Data bit (0 or 4) if 4-bit bus
DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
DEFINE LCD_RSBIT 0 ' Set LCD Register Select bit
DEFINE LCD_EREG PORTB ' Set LCD Enable port
DEFINE LCD_EBIT 1 ' Set LCD Enable bit
DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits)
DEFINE LCD_LINES 2 ' Set number of lines on LCD
DEFINE LCD_COMMANDUS 2500
DEFINE LCD_DATAUS 250
DEFINE CHAR_PACING 2000
Mainloop:
lcdout $FE,1, " This is a test" '
lcdout $FE,$C0, "Next or Select" '
pause 200
GOTO Mainloop
a scheme would be helpful ... especially to see how contrast and R/W lines are connected ...
I was about to put a video of my circuit working. So i decided to use many colored wiring to make it easier to see. Once that was done, I tried the circuit and... yes.. I was working. There u go.. hardware problem.
Thanks for your time.
K
No way! A hardware issue? Got to be the first - NOT ;-)
Seriously, glad you found it!
