Averaging & 16 maths
Results 1 to 3 of 3
    paul.mcallister's Avatar
    paul.mcallister Guest
    Question Averaging & 16 maths
    Hi all,
    I was wondering if someone could help me with an approach to this problem. I have a pressure transducer connected to a 12 bit ADC being read by a 16f876. The problem I have is that when I read the data is varies about 20 counts around the mean.
    I have captured the data via debug commands in to a text file and analyzed in a spread sheet and I know if I take 128 samples and divide it by 128 that it averages out the variation but..... 128 samples summed of 12 bits exceeds the 16 word size.
    Could someone suggest an approach for me.
    Thanks, Paul
    http://www.picbasic.co.uk/forum/showthread.php?t=1746
    You can always "Sum on the run"... for example...
    Sample=0
    For CounterA=1 to 128
    Gosub GetNewSample
    Sample=Sample+NewSample
    Sample=Sample/2
    Next CounterA
    Not the best solution but it won't spill out of any variables.
    Hi Paul,
    I have a little routine that keeps a "Running Average" of 16-bit values, without using 32-bit math.
    I use it for Pressure transducers, Flow sensors, Voltage readings, etc. It works really well for all of them.
    Averaging 16 bit values without using 32 bit math?
    HTH,
       Darrel
  1. 16 bit PWM using CCP1
    By Normnet in forum mel PIC BASIC Pro
    Last Post: - 27th August 2014, 09:13
  2. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  3. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  4. Averaging 16 bit values without using 32 bit math
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 5th October 2007, 23:18
  5. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 09:44
