Interrupt/timer not really interrupting...
Results 1 to 2 of 2
    Feb 2005
    Bellevue
    Question Interrupt/timer not really interrupting...
    PIC 18F2525
    I have my first interrupt and timer routine working as part of a menu system, and it feels over my head.. The system loop has several subroutines, and it chooses which to do based on some flags set in the menu interrupt.
    The problem is two fold:
    1. When I hit the button (b0) to interrupt to my menu handler, it jumps to the menu handler fine. However, when selecting a new menu, the code returns back whatever routine it WAS just in to finish that BEFORE it will jump to the next one. I need it to really INTERRUPT -- ie if I start a download routine, and then click the button to choose a different menu, I want it NOT to then download, but to just skip to the next routine. (Below)
    2. Timeout - if I click a menu select button (bo), then never click the menu submit button (b1), I want it to 'time out' and keep doing what it was doing before. I have a timout routine I got from this forum, but I don't think it is working right as it never does this. (Below)
    3. Crashing - this code watches a modem line for activity, and if it sees it, it starts reading. If it does NOT see it, it just loops thorugh a routine that says 'No data'.. and then returns to the top of the code.
    basically :
    getdata:
    Serin2 Cpinin,84,1000,nodata,[wait($02,$47), STR SSMAX\34]
    '*******[No Data from modem] ***********
    nodata:
    Pause 30
    LCDout $fe, L2, " Searching"
    LCDout $fe, L3, " No TracIDs Found"
    LCDout $fe, L4, " Check Tranmsitters"
    pause 50
    Then main ends up calling 'get data' again. This is supposed to loop, but eventually, the code hangs and has to be power cycled to come back to life..
    I am thinking this might have something to do with my timer..
    TG
    -- some of the code follows ----
    ADCON0 = %00110000 ' turn off - select port AN12 (nothing)
    ADCON1 = %00001111 ' turn portA to digital I/O (same as dec 15)
    CMCON = $07 ' turn off
    HLVDCON = %00000000 ' turn off
    CVRCON = $00000000 ' turn off
    SSPCON1 = %11011100 ' supposed to be turning on I2C
    SSPCON2 = %01111000 ' supposed to be turning on I2C
    INTCON = %11110000 ' TG guess at 2525 interrups for all INT pins
    INTCON2= %01110100 ' rising edge of INT0,1,2 RB0,1,2
    RCON = %10000000 ' no priority interrups
    T1CON = %11000000 'Timer1 1:1 prescale.
    T0CON = 1
    On Interrupt Goto INT_handle
    Smenu = 0
    ReStart:
    TMR1H = 0 ' Clear time counts before Timer1 re-start
    TMR1L = 0 ' Clear time counts before Timer1 re-start
    PIR1.0 = 0 ' CLear over-flow flag before enable
    T1CON.0 = 1 ' Turn Timer1 back on before entry into MainProcedure
    Main program stuff happens here
    ' --------- Interrupt Handler in main loop---------------
    IF PIR1.0 THEN ' IF Timer1 has over-flowed then
    Timer = Timer + 1 ' Increment Timer variable
    PIR1.0 = 0 ' Clear over-flow/int flag
    ' @20MHz 200nS * 65,536 * 8 = 0.1048576 seconds per over-flow
    ' 0.1048576 * 48 = ~5.033 seconds before jump to NextStage
    IF Timer >= 20 and Mnu = 1 THEN NextStage
    goto Main
    NextStage: ' timer routine
    Mnu = 0
    T1CON.0 = 0 ' Turn off Timer1 if you need to here
    Timer = 0 ' Clear Timer var on entry here
    TMR1H = 0
    TMR1L = 0 ' CLear timer count registers as required
    LCDout $fe, 1
    LCDout $fe, 2
    LCDout $fe, L2, "Timer Ran Out"
    GOTO ReStart ' When you're ready to start all over
    ' Interrupt handler stuff here
    Disable ' Disable interrupts in handler
    INT_handle:
    TMR1H = 0
    Selectit=0
    While selectit = 0
    Mnu=1 ' we are in the menu system
    If Mmenu = 0 then
    While Mmenu = 0 ' waiting until
    wend ' push-button is release
    pause 100 ' debounce time
    Bmenu=Bmenu+1
    endif ' bo pressed – go to next menu
    Select Case Bmenu
    Case 0
    LCDout $fe, 1
    LCDout $fe, 2
    LCDout $fe, L2, " Menu 0: Cycle Menu"
    pause 10
    Case 1
    LCDout $fe, 1
    LCDout $fe, 2
    LCDout $fe, L2, " Menu 1: Sensors"
    pause 10
    ... etc ...
    If Smenu = 0 then ' select button is pressed
    While MMenu = 0 ' waiting until
    selectit = 1 ' b1 pressed get out of the loop!
    Wend
    Mnu=0 ' turn off menu flag
    Here:
    If MMenu = 0 then here
    PIR1.0 = 0 ' Clear Timer1 over-flow flag
    Timer = 0 ' Clear Timer counts before return
    INTCON.1=0 ' reset RB0 interrupt flag
    Resume ' Return to main program
    Enable ' Enable interrupts after
    ' handler
    Feb 2005
    Bellevue
    Question Simple Menu System fails with Interrupt
    Well with 54 reads over the past few weeks, and no replies, there must be some interest in a menu system! My code has a weak interrupt system I am trying to improve, and NOW I need to add something else -- a sub-menu.. Well, it does not work.
    I have two buttons - I want to use button 0 as the interrupt from running to go to the menu system. Keep pushing it and cycle through the menus. Find the one you want, and hit Button 1. This works at a high level now. Problem is one of the menus I need to display some options and use these buttons to select THEM too.. In this case, I don't need an interrupt, just to read 0 or 1 from those pins. The following code displays OK, but the buttons do nothing..
    I could use a pointer to a template about how folks use buttons for menus.. This is not working..
    LCDsetting:
    ' make the LCD able to program the unit without the PC
    I2Cread DPIN, CPIN, Chip1, wpt_loc, [set_wpt] ' waypoint flag storage 0 or 1
    I2Cread DPIN, CPIN, Chip1, Pass_loc, [passthru] ' waypoint flag storage 0 ir 1
    I2Cread DPIN, CPIN, Chip1, D_baud_loc, [D_baud] ' store address pointer 84 for 9600, 6 for 38400
    I2Cread DPIN, CPIN, Chip1, W_baud_loc, [wptbd] ' store address pointer 84 for 9600, 188 for 4800
    I2Cread DPIN, CPIN, Chip1, wpt_loc,[set_wpt] ' waypoint flag storage 0 or 1
    LCDout $fe, 1
    LCDout $fe, 2
    LCDout $fe, L1, " Unit Set-up "
    LCDout $fe, L2+2,"Waypoint:"
    Select case Set_wpt
    Case 0
    LCDout $fe, L2+13,"off"
    Case else
    LCDout $fe, L2+13,"Err"
    end select
    Select Case Wptbd
    Case 188
    LCDout $fe, L2+13,"4800"
    Case 84
    LCDout $fe, L2+13,"9600"
    Case else
    end select
    LCDout $fe, L3+2,"Passthru:"
    Select case passthru
    Case 0
    LCDout $fe, L3+13,"off"
    Case 1
    LCDout $fe, L3+13,"9600"
    Case else
    LCDout $fe, L3+13,"Err"
    end select
    LCDout $fe, L4+2,"Download:"
    Select Case D_Baud
    Case 84
    LCDout $fe, L4+13,"9600"
    Case 6
    LCDout $fe, L4+13,"38,400"
    Case else
    LCDout $fe, L4+13,"Err"
    end select
    ' menu changes
    tempb = 1 ' start with 1
    If PORTB.0 = 0 then 'first button is pressed - select category
    tempb=tempb+1
    if tempb > 3 then tempb = 1
    Select case tempb
    case 1 ' gpsbaudrate item
    LCDout $fe, L2, "X" ' indicate selected item on lcd
    LCDout $fe, L3, " " ' indicate selected item
    LCDout $fe, L4, " " ' indicate selected item
    Case 2 ' passthru mode item
    LCDout $fe, L2, " " ' indicate selected item
    LCDout $fe, L3, "X" ' indicate selected item
    Case 3 ' download baudrate item
    LCDout $fe, L4, "X" ' indicate selected item
    end select
    while PORTB.0 = 1 ' as long as B0 is not pressed to make us move to another line item above:
    If tempb = 1 then
    select case wptbd 'translate default baudrate
    case 188
    tempc = 1
    case 84
    tempc = 2
    case 0
    tempc = 3
    end select
    select case tempc
    case 1
    LCDout $fe, L2+13, "4800" ' display setting
    wptbd=188
    Set_wpt=1
    passthru=0
    Case 2
    LCDout $fe, L2+13, "9600" ' display setting
    wptbd=84
    set_wpt=1
    passthru=0
    Case 0
    LCDout $fe, L2+13, "off" ' display setting
    wptbd=84
    set_wpt=0
    Case else
    LCDout $fe, L2+13, "Err" ' display setting
    end select
    If PORTB.1 = 0 then ' second button is pressed - increment options at this level
    tempc=tempc+1
    if tempc > 3 then tempc = 1
    If tempb = 2 then ' passthru mode
    select case passthru 'translate default passthru
    case 0
    tempc = 1
    case 1
    tempc = 2
    end select
    select case tempc
    case 1
    LCDout $fe, L2+13, "On 9600" ' display setting
    wptbd=188
    passthru=1
    set_wpt=0
    Case 2
    passthru=0
    end select
    tempc=tempc+1
    if tempc > 2 then tempc = 1
    If tempb = 3 then ' download baudrate
    select case D_baud 'translate default dnlspeed
    case 84
    tempc = 1
    case 6
    tempc = 2
    end select
    select case tempc
    case 1
    LCDout $fe, L1+13, "9600" ' display setting
    D_Baud=84
    Case 2
    LCDout $fe, L1+13, "38400" ' display setting
    D_Baud=6
    end select
    tempc=tempc+1
    wend
  1. USART interrupt not interrupting right
    Last Post: - 6th March 2005, 01:07
  2. USART interrupt not interrupting :-(
    By barkerben in forum mel PIC BASIC Pro
    Last Post: - 5th January 2005, 13:30
