Interrupts and WDT are driving me crazy!
Results 1 to 3 of 3
    Jan 2012
    Grid EN19MV
    Default Interrupts and WDT are driving me crazy!
    First of all, this may be a duplicate - I posted in the PBP 3 forum before I noticed that the three posts there were two years old! It also said that the post had to be moderated first - so, mods, could you delete that one?
    Here's the problem: I am adding a feature to an existing project (I know, I know, leave well enough alone......)
    I am trying to accomplish the following: When a switch is on (logic low) the LED is on steady. When the switch is off, I want the LED to be on for 250ms out of two seconds.
    Originally when the switch was off, the program would nap the processor with GIE off, and the only thing that woke it up was the change of state on PORTB.0. There was no interrupt handler, the program just continued the main loop. Now I need the WDT to wake it up as well, and the interrupt handler to blink the LED based on a counter.
    I have tried various ways to do this and have failed at every attempt. The LED is on when the switch is on, but it does not blink when the switch is off - it remains stubbornly dark. Almost like the interrupt handler is not even being entered.
    I have pared the program down to just this feature for testing - and I'm pulling my hair out at this point. Every time I think I have it, I don't.
    If anyone has any ideas what I'm doing wrong, I would appreciate the suggestions. I read a bunch of interrupt and WDT posts but didn't find anything that helped.
    BTW, I have used interrupts when I was programming in assembler but never in PBP. And its a 16F886.
     __config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    DEFINE OSC 8  'LETS PBP KNOW THE OSCILLATOR IS RUNNING AT 8MHz
    OSCCON = %01110001 '8 MHz INTERNAL OSCILLATOR, INTERNAL OSCILLATOR IS USED FOR SYSTEM CLOCK
    DISABLE DEBUG 'NO DEBUG
    ANSEL = 0 'PORTA ALL DIGITAL
    ANSELH = 0 'PORTB ALL DIGITAL
    OPTION_REG = %10000000 'PORT B PULLUPS ENABLED, TMR0 PRESCALER IS *NOT* ASSIGNED TO WDT
    WPUB = %01111111 'PULL UPS ENABLED ON PORTB 0-6
    INTCON = %10001000 'GIE ENABLED, PORTB CHANGE OF STATE INTERRUPT ENABLED
    IOCB = %00000001 'PORTB.0 INTERRUPT ON CHANGE ENABLED
    WDTCON = %00010000 '1:8192 PRESCALER (272MS)
    TRISA = 0 'PORTA ALL OUTPUTS
    TRISB = %01111111 'B7 OUTPUT, ALL THE OTHERS INPUTS
    TRISC = 0 'PORTC ALL OUTPUTS
    SWITCH VAR PORTB.0
    LED VAR PORTC.6
    DEBOUNCE VAR BYTE
    DUMMY VAR BYTE
    BLINK_COUNT VAR BYTE
    DEBOUNCE = 30 'MILLISECONDS
    ON INTERRUPT GOTO MY_INT
    BLINK_COUNT = 0
    MAIN_LOOP:
    	DO 'ENDLESS LOOP
    			IF SWITCH = 0 THEN 'SWITCH ON
    			PAUSE DEBOUNCE 'DELAY TO DEBOUNCE
    				IF SWITCH = 0 THEN 'SWITCH STILL ON
    DISABLE INTERRUPT
    					LED = 1 'TURN LED ON STEADY WHILE SWITCH IS OPERATED
    					DO WHILE SWITCH = 0
    					LOOP
    					PAUSE DEBOUNCE
    					LED = 0 'TURN OFF THE LED TO ALLOW THE INTERRUPT HANDLER TO BLINK IT
    					BLINK_COUNT = 0
    					GOTO DONE_LOOP
    DONE_LOOP:
    		INTCON = %10001000 'TURN ON GIE AND INTERRUPTS FOR PORTB.0 CHANGE OF STATE AND CLEAR ANY FLAGS
    		WDTCON = %00010000 '1:8192 PRESCALER - 272MS (CLRWDT RESETS THIS TO 17MS)
    ENABLE INTERRUPT
    			SLEEP	'SLEEP UNTIL WDT TIMES OUT OR PORTB.0 CHANGES STATE
    			NOP		'NOP BECAUSE THE PROCESSOR PREFETCHES PC+1 ON SLEEP
    	LOOP
    DISABLE 'DISABLE INTERRUPTS BELOW THIS POINT
    MY_INT:
    	DUMMY = PORTB 'READ PORTB TO CLEAR THE SWITCH MISMATCH IF THAT GENERATED THE INTERRUPT
    	IF BLINK_COUNT = 8 THEN BLINK_COUNT = 0
    	IF STATUS.4 = 0 THEN 'WDT TIME OUT OCCURRED
    		BLINK_COUNT = BLINK_COUNT + 1
    		IF BLINK_COUNT > 1 THEN
    			LED = 0
    			LED = 1
    	INTCON = %10001000 'TURN ON GIE AND INTERRUPT PORTB.0 CHANGE OF STATE, AND CLEAR FLAGS
    	RESUME  'IF NO WDT TIME-OUT OCCURRED, THEN THE SWITCH WAS TURNED ON NO NEED TO DO ANYTHING
    			'AS THE SWITCH WILL BE CAUGHT BY THE MAIN LOOP
    -Stephen Hawking
    Default Re: Interrupts and WDT are driving me crazy!
    Hi andywpg. I don't know what you're adding this feature to but perhaps a simpler approach will work:
    start:
    if switchport = 0 then blinkled 'switch open (or closed depending on pull ups or pull downs)
    if switchport = 1 then high ledport 'switch closed
    goto start
    blinkled:
    high ledport
    pause 250
    low ledport
    if switchport = 1 then start
    goto blinkled
    Jan 2012
    Grid EN19MV
    Quote Originally Posted by peterdeco1 View Post
    start:
    goto start
    blinkled:
    high ledport
    pause 250
    low ledport
    goto blinkled
    That would work - and if I don't get it working with the interrupt and sleep, that's way I'll go.
    But the idea was to have it happening 'in the background' - so the power led blinks very briefly when the device is not running - just to let you know the power is on, but nothing is running.
    And it's almost PERSONAL now - I am going to bend this device to my will if it kills me!
    Thanks for the reply
    -Stephen Hawking
  1. Interrupts and WDT are driving me nuts!
    By andywpg in forum PBP3
    Last Post: - 27th February 2013, 00:49
  2. PBP is driving me crazy trying to make an 18F chip blink
    By George in forum mel PIC BASIC Pro
    Last Post: - 20th June 2008, 06:08
  3. LED crazy
    By rickyD in forum mel PIC BASIC
    Last Post: - 11th May 2008, 19:50
  4. Button problem driving me crazy!! Please help!
    By bearpawz in forum mel PIC BASIC Pro
    Last Post: - 20th November 2007, 14:46
  5. WTF? Am I crazy?
    By RichardBowser in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 02:49
