Need guidence for programming a DS1821C+
Results 1 to 10 of 10
    May 2008
    Default Re: Need guidence for programming a DS1821C+
    OK, never mind I found it. Just a little more research... I was pretty tired. Any way, in case anyone else comes across this and doesn't know, here's what I found.
    @ tells PBP that the next command is assembly, the assembly command nop (also noop) is short for No Operation. Essentially means do nothing. The PIC apparently takes 1 uSec to "Do Nothing" therefore a 1 uSec delay at 4 MHZ. Using PBP (2.5c at least) the minimum delay is 24 uSec @ 4 MHZ so the assembly "nop" is a work around for shorter time delays. Makes me wonder if...
    @ nop
    @ nop
    @ nop
    @ nop
    is a 4 uSec delay? I bet the answer to that is in the PIC's data sheet.
    Feb 2010
    USA, New England
    Since it takes 4 clock cycles to complete a single operation, divide the oscillator frequency by 4 to get the number of operations the PIC can perform in a second:
    4,000,000/4 = 1,000,000 operations per second.
    Take the inverse of the number of operations per second to get the time it takes to perform a single operation:
    1/1,000,000 = 0.000001 seconds = 0.001 milliseconds = 1 microsecond.
    So yes, four NOPs will delay for 4 microseconds when operating at 4 MHz.
    At 20 MHz, each NOP will delay for 200 nanoseconds.
    Best Regards,
    Paul
    May 2008
    Thanks again, I think that will come in handy when I work at regaining access to the DS1821.
    I had ordered some DS1821 and they arrived today. I wrote some code to query and write to the DS1821 setting and reading the various registers and finally put it into thermostat mode. It works. Mostly.
    The issue I'm having now is the logic hi / low levels don't seem to match the spec in the data sheet, unless I don't understand it, which is most likely.
    I'm reading that the DS1821 can sink 4mA minimum. Yet in thermostat mode with a logic 0 on the DQ pin I can drive it to a logic 1 by measuring the voltage on the DQ Pin if I reference Vdd (+5 volts). In other words Red lead on DQ (PORTA.0) Black lead on +5 volts forces a logic high and reads -3.7232 VDC (avg) which is of course inverted because of the reversed leads. My meter is a Fluke 189 with 10M ohms impedance, I figure I'm loading the circuit with +500 nano amps and forcing it to a logic 1. I tried my other Fluke meter with the same results. Tried 1 meg ohm pull up and pull down resistors but the DS1821 seems to have no drive, it can't overcome the 1 Meg Ohm resistor either high or low. Even TOUCHING the free end of a 1 meg ohm resistor plugged into the DQ line of the DS1821 forces it to a logic high.
    It does produce high and low states to PORTA.0 on the PIC as it's supposed to but I wasn't planning on using a PIC in the final circuit, I was going to drive a MOSFET with the DS1821 and wanted a pull down resistor on the gate but it seems even a 10 Meg Ohm is not an option. What's the solution with such small signals?
    Data sheet is HERE (DS1821) if anyone wants to have a look.
    TIA
    Neo
    May 2008
    Once again, problem solved. Operator error. I'll blame it on working 16 hour days and bread-boarding at 1:00 am. Lets just say the power supply was inadequate. I'm getting very good logic states now. In the future I'll try to sleep on a problem before asking about it.
    Neo
  1. need help programming
    By chris000 in forum General
    Last Post: - 20th May 2009, 06:18
  2. new to PIC programming could really do with some help
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 15:03
  3. I2C programming
    By goku24m in forum mel PIC BASIC Pro
    Last Post: - 24th October 2007, 04:12
  4. gps programming
    By chuckad in forum mel PIC BASIC Pro
    Last Post: - 20th June 2006, 02:02
  5. New to PIC Programming
    By Keiou in forum General
    Last Post: - 29th October 2003, 20:13
