MCP79410 good time keeping, No alarms?
Results 1 to 8 of 8
    Alabama,USA
    Default MCP79410 good time keeping, No alarms?
    Greetings!
    My project uses a 16F886 @8Mhz and a MCP79410 RTCC. I am pleased with the digital calibration and the unit is keeping very accurate time. HOWEVER, I have been working with the Alarms for several days and I’m getting nowhere! I have three identical boards and the RTCC acts the same on all boards. I must be missing something!
    MFP is tied to RB0 with pull up resistor and a button for manual interrupt with DT_INT’s. The button interrupt is working as expected.
    The ISR checks to see if ALM0IF or ALM1IF has been set, if NOT the interrupt was caused by button press. The OLED notifies upon interrupt which flag is set, if any.
    My major problem is that I can‘t get the darn thing to go into alarm state. I expect an interrupt if RTCC goes into alarm state, its not happening... No interrupt... No Alarm flag set. As I said all three board are working the same so it must be something in the setup I missed.
    PBP 2.60, PMASM
           ; Clock set to 0000,  Alarm0 set,   MFP set to Hi in default position, goes low on interrupt
    Set_TimeDate:
            rtcsec     = %10000000           ;top 4 bits ST&tens, bottom 4 bits ones
            rtcmin     = %00000000   	;can be a Hex $ entry,
            rtchour    = %00000000   	;bit6,12/24hr : bit5 pm/am : bit4=tens : bottom 4bits=ones
            rtcday     = %00000001  	;oscon bit5 : Vbat bit4 :  Vbaten bit3 :  bit 2-0 day
            rtcdate    = %00000000
            rtcmon     = %00000000  	 ;bits4 tens : bottom 4 bits ones
            rtcyear    = %00000000
            rtccon     = %10010000   	;[OUT][SQWE][ALM1][ALM0][EXTOCS][RS2][RS1][RE0]  CONTROL
            rtccal     = %00000000   	;Calibration
            i2cwrite I2C_Dat, I2C_Clk, $DE,$00,[STR RTCbuffer\9] ' Write all 8 RTC reg
            ;Set Alarm0 for Lo on alarm interrupt, Alarm set to  Seconds match, Seconds set to 15
    Set_RTCC_Alarm0:
            Alrm0_sec    =  $0F
            Alrm0_min    =  %00
            Alrm0_hour   =  %00
            Alrm0_day    =  %00    ;   [ALM0POL][ ALM0C2][ALM0C1][ALM0C0][  ALM0IF  ] [  DAY   ]  Addr 0Dh
            Alrm0_date   =  %00
            Alrm0_mon    =  %00
            i2cwrite I2C_Dat, I2C_Clk, $DE,$0A,[STR Alrm0_buffer\6]
             ;Set Alarm1 for Lo on alarm interrupt, Alarm set to  Seconds match, Seconds set to 15
    Set_RTCC_Alarm1:
            Alrm1_sec   =  $0F
            Alrm1_min   =  %00
            Alrm1_hour  =  %00
            Alrm1_day   =  %00    ;   [ALM1POL][ ALM1C2][ALM1C1][ALM1C0][  ALM1IF  ] [  DAY   ]  Addr 14h
            Alrm1_date  =  %00
            Alrm1_mon   =  %00
            i2cwrite I2C_Dat, I2C_Clk, $DE,$11,[STR Alrm1_buffer\6]
    OLED display posts a constant update of the clock. If I push the INT button, OLED post BIN value of Alrm0_day and Alrm1_day. This tells me if ALM0IF and ALM1IF is clear or set. Following my interpretation of the datasheet almost everything else is working as expected. Calibration works well, PWM on MFP works well, EEProm works well in Page Write and Byte Read, and ID is cool.
    PBP I2C command doesn’ like the EEProm Random Read or Current Address Read. I guess some bit banging will be required. SRAM wants to give me back only seven bits instead of eight; what’s with that?
    Any comments or direction will be appreciated!
    Wayne
    Alabama,USA
    Default Re: MCP79410 good time keeping, No alarms?
    update:
    My testing shows that both my MCP7940 and MCP79410 will not alarm interrupt on seconds only.
    When I setup Alarms to match on Min. the flags will set on both Alarms, however Alarm0 will not interrupt. Alarm1 will not clear flag with the same command structure used to clear flag Alarm0. Where’s my DS1307?
    Mar 2013
    Leicestershire - England
    Cool Re: MCP79410 good time keeping, No alarms?
    Hi MOUNTAIN747, I am just starting to attempt to communicate with this RTC. Could you possibly share any more code for this project . Many thanks perkoperkins
    Alabama,USA
    Hi perkoperkins, what are you having problems with? I can dig out several code blocks to assist you if you can tell me what you are trying to do. In the code from the first post the i2cwrite communication is all you need to talk to the RTCC to set the time.
    Wayne
    Mar 2013
    Hi Wayne , Thanks for your promt reply !!.
    Hardware Used -
    Pic Used = PIC16F876A - 4MHZ External Xtal - SDA Port RC.4 - SCL Port RC.3 - Output ( Currently LCD ) but want to use a 4x7segment display. Using PBP 2.60.
    I have uploaded what code I have so far, If you could pick out any errors for me that would be great. I'm fairly new to PBP and
    this is the first time I have tried i2c. when i run this code the time and date is set but if i set ClkSec = %10000000 to start
    the oscilator My seconds display 80 and start to count up . I read on Microchips Application note AN1491
    (http://ww1.microchip.com/downloads/e...tes/01491A.pdf)
    " The recommended practice is to load the Time and Date registers from 0x01 through 0x06 and then load the Seconds register 0x00 with the ST (oscillator Start bit set, enabling the oscillator)."
    When I try this though I get the wrong setting returned on the LCD. Is my method for converting the BCD to DEC correct ?
    One more question sorry ! When the i2cread is read, do the variables need manually updating ie
    RtcSec = (ClkBuffer[0])
    RtcMin = (ClkBuffer[1])
    Rtchour = (ClkBuffer[2])
    etc
    etc
    Thankyou for taking the time to answer my questions , any help or code examples would be great. Can't find much code on
    the net , other than for C.
    Thanks Tim
    MyRTC4Forum.bas
    ( I'm hoping my code has appeared above if not ill try again )
    Mar 2013
    Ill Try again - Hopefully will work this time
    ' ________________________ Chip Setup ___________________________
    @ __config _XT_OSC & _WDT_OFF & _LVP_OFF & _CPD_OFF & _DEBUG_OFF
    ' ___________________ Definitions & LCD Definitions _____________
    DEFINE OSC 4            ' Tell PBP using a 4 MHZ Crystal
    DEFINE I2C_HOLD 1       '
    define LCD_DREG PORTB   ' Declare data bus port
    define LCD_DBIT 0       ' Declare data bus starting address
    define LCD_RSREG PORTC  ' Declare Register Select
    define LCD_RSBIT 7      ' port and bit
    define LCD_EREG PORTC   ' Declare Enable port and bit
    define LCD_EBIT 6       ' Declare Enabit bit
    define LCD_BITS 4       ' Declare no. of Bits
    define LCD_LINES 2      ' Declare no. of lines
    ' _________________________ Variables ______________________________
      BCDsecs   var  byte   '
      BCDmins   var  byte   '
      BCDHours  var  byte   ' Conversion Variables
      BCDday    var  byte   '
      BCDdate   var  byte   '
      BCDmon    var  byte   '
      BCDyear   var  byte   '
    ' ______________________ Clock Variables ___________________________
      ClkSec    var byte '$00   ' Seconds Register
      ClkMin    var byte '$01   ' Minutes Register
      ClkHour   var byte '$02   '   Hours Register
      ClkDay    var byte '$03   '    Days Register
      ClkDate   var byte '$04   '    Date Register
      ClkMonth  var byte '$05   '   Month Register
      ClkYear   var byte '$06   '    Year Register
      ClkCont   var byte '$07   '          Control
      ClkCal    var byte '$08   '      Calibration
      ClkBuffer var byte[9]     '      Time Buffer
    ' ______________________ Alarm0 Variables ___________________________
      Alm0Secs  var byte '$0A   ' Seconds Register
      Alm0Mins  var byte '$0B   ' Minutes Register
      Alm0Hour  var byte '$0C   '   Hours Register
      Alm0Day   var byte '$0D   '    Days Register
      Alm0Date  var byte '$0E   '    Date Register
      Alm0Month var byte '$0F   '   Month Register
      Alm0Buff var byte[6]
      Alm1Secs  var byte '$11   ' Seconds Register
      Alm1Mins  var byte '$12   ' Minutes Register
      Alm1Hour  var byte '$13   '   Hours Register
      Alm1Day   var byte '$14   '    Days Register
      Alm1Date  var byte '$15   '    Date Register
      Alm1Month var byte '$16   '   Month Register
      Alm1Buff var byte[6]
    ' _____________________ Pin Definitions _________________________
      SDA var PORTC.4     ' Serial Data Pin RC.4    ( pin )
      SCL var PORTC.3     ' Serial Data Pin RC.3    ( pin )
      SetButt  var PORTB.0     '
      UpButt   var PORTB.1
      DownButt var PORTB.1
    ' ____________________ Inital time setup ________________________
      ClkSec   = %10000000;$00
      ClkMin   = $00
      ClkHour  = $00
      ClkDay   = $01
      ClkDate  = $17
      ClkMonth = $10
      ClkYear  = $78
      ClkCont  = %10000000;$00
      clkcal   = $00
    ' _______________________ Main Program __________________________
                   ' Allow LCD to Wake Up !
    gosub settime
    goto Main
    Main :
        gosub gettime
        gosub disptime
    ' _________________________ Subrountines ________________________
    SetTime :   ;$DE = write
        i2cwrite sda, scl, $DE,$00,[str clkbuffer\9]
        'i2cwrite sda, scl, $DE,$00,[clksec,clkmin,clkhour,clkday,clkdate,clkmonth,clkyear,clkcont,clkcal]
        'i2cwrite sda, scl, $DE,$00,[clksec]
    GetTime :    ;$DF = read 11011111
        i2cread sda, scl, $DF,$00,[str clkbuffer\9]
        'i2cread sda, scl, $DF,$00,[clksec,clkmin,clkhour,clkday,clkdate,clkmonth,clkyear]
           bcdsecs  = (clksec>>4*10)  + (clksec & %00001111)      ; convert BCD to Decemal ??
           bcdmins  = (clkmin>>4*10)  + (clkmin & %00001111)      ;
           bcdhours = (clkhour>>4*10) + (clkhour & %00001111)     ;
           BCDday   = (clkday>>4*10) + (clkday & %00001111)       ;
           bcddate  = (clkdate>>4*10) + (clkdate & %00001111)     ;
           bcdmon   = (clkmonth>>4*10)+ (clkmonth & %00001111)    ;
           bcdyear  = (clkyear>>4*10) + (clkyear & %00001111)     ;
    DispTime :
        lcdout $FE,1,dec bcdhours,":",dec bcdmins,":",dec bcdsecs
        lcdout $FE,$c0,dec bcddate,"/",dec bcdmon,"/",dec bcdyear
    '    lcdout $FE,1,dec clkhour,":",dec clkmin,":",dec clksec
    '    lcdout $FE,$c0," ",dec clkdate,"/",dec clkmonth,"/",dec clkyear
    '    pause 100
  1. Mcp79410 rtcc
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 17th July 2012, 05:36
  2. May be it is good idea
    By hardcore in forum PBP Wish List
    Last Post: - 16th March 2010, 02:09
  3. Alarms with Mel's "Olympic Timer" based timer - how to?
    Last Post: - 20th June 2007, 23:09
  4. Problem Keeping PORTD.1 LOW
    Last Post: - 9th September 2005, 09:51
  5. DS1307 multiple alarms
    By jrt4fun in forum mel PIC BASIC Pro
    Last Post: - 18th August 2004, 22:49
