I'm using MCS 4.0. I've checked the box "Automatically jump to first error" under the Editor Options. When I create an intentional syntax error the cursor does not jump. It just stays where it was before the compile attempt. Any ideas?
I experimented an found(remembered) that the highlighting of errors does indeed occur when using PM as the assembler. I forgot that I am using MPASM as my assembler. It is required when working with 16F1828 devices and similar 16F1's. This is a pity because troubleshooting is very difficult when the cursor is not jumping to the error line
I found (remembered) that the solution to this problem is to use compiler version PBPX 3.0 along with Micro Studio version MSCX 5.0. Errors are now highlighted.
