How to Figure Out Compile Errors?
Results 1 to 9 of 9
    Default Re: How to Figure Out Compile Errors?
    I downloaded the datasheet before ordering it, and it mentions the CCP1CON register - does that only apply to one of the other chips in the shared PIC16F631/677/685/687/689/690 data sheet?
    Can anyone think of another chip that has a CCP module, USART and 8 output pins on a PORTA/B/C which doesn't have the CCP/Rx pin?
    If you look at page 2 of the datasheet you'll find the following table:
    There you'll see that the 16F687 doesn't have the ECCP module. I'm not sure exactly what you're trying to do but if you want 8 outputs can't you split them across two ports? Say PortB.0-3 and PortC.0-3 of the 16F690 (same datasheet), RX is on PortB.4 and the CCP1 on PortC.5 so both of those are avoided.
    Finally, in the code in your first post I don't see BLINKYFREQ being defined anywhere.
    Datasheet's with combined PICs drive me nuts, but in most cases I've seen so far it's usually just 2 PICs; this is the first time I've run across one which has 6 and only some have ECCP modules (I think the 16F690 has it, which may be why a search through the datasheet comes up with 'CCP1CON'.
    I trimmed the code to test and left out the definition of BLINKYFREQ - even with it back in, though, it still doesn't compile (same reason).
    For the 8 pins together, its because of this cool code from Darrel:
    ;----[Main Program Loop]----------------------------------------
        ' Check if flash mode has changed
        IF FlashMode <> Old_FlashMode Then
            Old_FlashMode = FlashMode
            GOSUB SetNavLtsFlashRates
        EndIF
        x = (x + 1) // LEDcount
        PORTB.1(x) = !!(LoopLED(x) < OnTime(x))
        LoopLED(x) = (LoopLED(x) + 1) // (OnTime(x) + OffTime(x))
        #IFDEF USE_RANDOM_SEQUENCE
            IF x < 5 THEN
                RandPeriod(x) = RandPeriod(x) - 1
                IF RandPeriod(x) = 0 THEN
                    READ RandPeriods+(x<<1), WORD RandPeriod(x)
                    RANDOM RND
                    OnTime(x) = (MAX_ON - MIN_ON)* RND.HighByte / 255 + MIN_ON
                    OffTime(x)= (MAX_OFF - MIN_OFF)* RND.LowByte / 255 + MIN_OFF
        #ENDIF
        IF x != (LEDcount - 1) THEN Main
    Waiting: IF !CCPIF THEN Waiting
        CCPIF = 0
    GOTO Main
    In this example, it's offset by 1 since PORTB.0 is the INT pin which is being used to detect a button push.
    Yes, the table shows the 16F690 having both an ECCP module and an USART. Unfortunately they won't leave you with unrestriced access to PortB.
    If, instead of doing the indexed bit operation ( PortB.1(x) etc ) on the PortB or any other Port, you do them on a BYTE variable (like myLEDS or whatever) you can then, as a final task in the loop take the value of that BYTE variable and split it across two ports. Write the four low bits to PortB.0-3 and the four high bits to PortC.0-3. Not saying that I'm sure it will work, Darrel may be using one of his tricks, but I think it might. Perhaps its worth a try.
    I was going to use PORTC on the 16F690.
    Hmm, then I'm not following, which doesn't really matter as long as you get what you need but in a previous post you wrote
    On the 16F690 the RX-pin is on PortB.5 and the CCP1 pin on PortC.5. I thought you were using those pins for their peripheral functions therfore not allowing 8 consecutive bits on either of those two ports - but I've must have misunderstood.
    Sorry for not being clear, Henrik. For the current iteration of the code on a PIC16F88 I'm using PORTB.1-7 (since PORTB.0 is the INT pin which I have hooked up to a button switch) where the CCP1 pin is PORTB.3 but it doesn't matter as I'm only using the compare module, not the capture or PWM.
  1. Replies: 10
    Last Post: - 11th April 2010, 10:12
  2. Usart compile errors 18F4520
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 7th May 2009, 00:13
  3. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 09:18
  4. USB Mpasm Compile errors
    By JBrannan in forum mel PIC BASIC Pro
    Last Post: - 21st December 2007, 19:13
  5. Compile errors within macro....
    By forgie in forum mel PIC BASIC Pro
    Last Post: - 5th September 2005, 20:08
