how to loop thru setting port bits?
Results 1 to 3 of 3
    Dec 2012
    Tennessee
    Default how to loop thru setting port bits?
    I have a variable array, now I need to cycle thru it and set PORTB bits based on values in that array, heres my code
    FOR CNT = 0 to 7
    IF TEMP[CNT] < 100 then PORTB.CNT = 0
    IF TEMP[CNT] >= 100 then PORTB.CNT = 1
    NEXT CNT
    Now "TEMP[CNT]" works fine, but it throws an error on "PORTB.CNT"
    Error is Bad Variable Modifyer ".CNT"
    I Changed it to PORTB.(CNT)
    New Error, Bad Token "."
    Default Re: how to loop thru setting port bits?
    Try
    IF TEMP[CNT] < 100 then PORTB.0(CNT) = 0
    For more info see Melanies excellent write up and the follow up discussions.
    Dec 2012
    Tennessee
    ok i didnt get a error on compile but i cant test it yet as Ive got alot more code to finish. but no errors looks good so far.
  1. Configuation bits setting in PBP
    By Max_Gauss in forum mel PIC BASIC Pro
    Last Post: - 8th September 2010, 19:25
  2. Setting bits
    By bearpawz in forum General
    Last Post: - 28th November 2009, 01:37
  3. How to reference variable bits in a loop
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 21st April 2006, 16:56
  4. Addressing bits in a loop?
    By Mad_Labs in forum mel PIC BASIC Pro
    Last Post: - 27th September 2005, 19:11
  5. Trouble setting config. bits
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 13th March 2004, 23:22
