Oscillator question and measurement
Results 1 to 12 of 12
    Default Re: Oscillator question and measurement
    some JELT pcb " Tropicoat " protective varnish makes real good glue ... did you also try nail lacquer ??? ( NO metallic colour !!! - of course -)
    a simulator run would show your program NEVER will run @ 1 Mhz ... as TOGGLE and GOTO commands need some time to execute
    we also must suppose your Pic is a 18F series for the Pauseus1 to be equal to 1µs ...
    Now, Hot glue doesn't disturb the oscillator in any way ...
    New Jersey
    Get rid of the line "PAUSEUS 1" and tell us what happens.
    I didn't have a scope handy and the meter I had isn't able to calculate high frequencies. I'll be able to try that tonight. What should I expect to see with just a toggle command?
    Yes, it's an 18F4550. The program works but the CAN data isn't flowing smoothly compared to the previous devices I made. All of the pinouts are different, and wanted to rule that out, but I can't even see how that would cause slow CAN data in the first place.
    a little MPSIM ( MPLAB ) simulation - supposed to be relatively true - gives à 3.2µs half -cycle to your test ... around 160 khz output frequency !
    BTW ... I'm not sure the DEFINE OSC 48 and a 20 Mhz Xtal to be a good combination ...
    best result @ 1.8µs half cycle given by
    Portb.1 = ! Portb.1
    instead of TOGGLE + PAUSEUS1
    New Jersey
    Here are the results. Are these typical?
    start:
    pauseus 1
    toggle portd.1
    goto start
    375 KHz
    start:
    toggle portd.1
    goto start
    1 MHz
    start:
    Portb.1 = ! Portb.1
    goto start
    This does nothing
    start:
    portd.1=1
    portd.1=0
    goto start
    3 MHz
    Quote Originally Posted by Christopher4187 View Post
    start:
    Portb.1 = ! Portb.1
    goto start
    This does nothing
    Sure it does not show anything on portD1 ...
    New Jersey
    I know. I was too lazy to edit it yesterday. My original comment still stands.
    ohhh ... may be the RMW issue ...
    due to a 18F chip ... I should have written:
    start:
    latb.1 = ! latb.1
    goto start
    on test with the EP5 tomorrow morning ...
    Miami, Florida USA
    I think the problem is that you are not configuring the fuses of the PIC correctly. Are you also setting the OSCON register? I use a 4MHz crystal with my 18F4550 and to make it work the first time it was a pain.
    Anonymous
    Results of the test ...
    output freq is exactly that expected ... and that MPSIM shows ....
    111.1 Khz with a 8 Mhz Xtal
    277.7 Khz with a 20 Mhz Xtal
    sooo ... getting 1 Mhz output looks a bit too much !!! - gives 72 Mhz @ Clock - 18Mhz Xtal and PLL x 4 ; that looks real hard overclocking for such chips ...
    MAY BE POSSIBLE, but with very light loads on the output ...
    666.5 Khz with 48 Mz @ Clock
    833.1 Khz with ... 60Mhz ( poor USB clock ! )
    looks a bit over 1Mhz with ... 80Mhz ( poor ... etc )
        __CONFIG    _CONFIG1L, _PLLDIV_3_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
                                ;              ;                      ; USB clock source comes from the 96 MHz PLL divided by 2
                                ;              ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
                                ; 1/2 prescale
        __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
                                ;                  ;               ; Oscillator Switchover mode disabled
                                ;                  ; Fail-Safe Clock Monitor disabled
                                ; HS oscillator, PLL enabled, HS used by USB
        __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L  & _BORV_2_2L  & _VREGEN_ON_2L
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
        __CONFIG    _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L  & _XINST_OFF_4L & _DEBUG_OFF_4L
        __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
        __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
        __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
        __CONFIG    _CONFIG6H, _WRTB_OFF_6H & _WRTC_OFF_6H & _WRTD_OFF_6H
        __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L &_EBTR2_OFF_7L &_EBTR3_OFF_7L
        __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    trisa = 0
    trisb = 0
    trisc = 0
    trisd = 0
    lata = 0
    latb = 0
    latc = 0
    latd = 0
    Start:
    Latb.1 = ! Latb.1
    GOTO start
    some surely will throw me everything that can fly .... LOL !
    sooo ... getting 1 Mhz output looks a bit too much though !!! - gives 72 Mhz @ Clock - 18Mhz Xtal and PLL x 4 ; that looks real hard overclocking for such chips ...
    I did it ... so any idiot can do it too ...
    the 4550 did not die ... really nice chip, isn't it ???
    PS: this "timeout" really is a shame, Lester ....
  1. High Speed Oscillator question
    By Tina10 in forum mel PIC BASIC Pro
    Last Post: - 9th July 2012, 11:29
  2. A question on defining the external oscillator
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2009, 15:31
  3. Using PIC16F88 oscillator as oscillator for other ICs
    By Torael_7 in forum mel PIC BASIC Pro
    Last Post: - 30th March 2008, 13:58
  4. AC Measurement
    By Atom058 in forum General
    Last Post: - 14th December 2006, 21:20
  5. low Resistance measurement
    By sanatana in forum mel PIC BASIC Pro
    Last Post: - 19th October 2004, 19:32
