Here's my first code with picbasic pro up and running. It does output variable PWM which I use for led dimming.
Sure, code is written really bad, but, at least it works. I've used included BUTX3 sample as basis:
   CMCON = 7          ' PORTA to digital
    OPTION_REG = $7f   ' Enable PORTB pull-ups
    TRISB = %11001111  ' Set PORTB.4,5 (LEDs) to output, rest to input
A var byte
mainloop:
   PORTB = 0           ' Turn off LEDs
   ' Check any button pressed to toggle on LED
   If PORTB.7 = 0 Then ' If 1st button pressed...
      PORTB.5 = 1      ' Turn on 1st LED
      A=A+1
      if a=255 then a=a-1
            HPWM 1,A,1000
   Endif
   If PORTB.6 = 0 Then ' If 2nd button pressed...
      PORTB.4 = 1      ' Turn on 2nd LED
      a=A-1
      if a=1 then a=a+1
            HPWM 1,a,1000
   Endif
   Pause 15             ' Pause 2mS
   Goto mainloop       ' Do it forever
I believe, first two lines of code are irrelevant for PIC16F628A, but at least it works...
