How to configure ADC sampling rate?
Results 1 to 3 of 3
    Jan 2013
    Default How to configure ADC sampling rate?
    Hi!
    I am using dsPIC Starter Kit which has a dsPIC33fj256gp506. I am trying to modify the ADC sampling rate using the example from Microchip.
    Here is the code:
    #ifndef __ADCCHANNELDRV_H__
    #define __ADCCHANNELDRV_H__
     #define ADC_CHANNEL_FCY   40000000
    #define ADC_FSAMP    8000 /* Sampling Frequency */
    #define ADC_BUFFER_SIZE   128    /* This is the size of each buffer */
    #define ADC_CHANNEL_DMA_BUFSIZE (ADC_BUFFER_SIZE*2)
     #include "..\h\p33FJ256GP506.h"
     typedef struct sADCChannelHandle {
     int * buffer1;
     int * buffer2;
     volatile int bufferIndicator;
     volatile int isReadBusy;
    }ADCChannelHandle;
     void ADCChannelInit (ADCChannelHandle * pHandle,int * pBufferInDMA);
    void ADCChannelStart (ADCChannelHandle * pHandle);
    void ADCChannelRead (ADCChannelHandle * pHandle,int *buffer,int size);
    int ADCChannelIsBusy (ADCChannelHandle * pHandle);
    void ADCChannelStop (ADCChannelHandle * pHandle);
    #define ADCON1VAL   0x0744    /* 12 bit ADC with signed fractional format
                                                * Triggered by Timer 3 and auto start
                                                         * sampling after conversion complete. */
    #define ADCON2VAL   0x0000      /* AVdd and AVss voltage reference,
                                                          * use channel 0 with no scan */
    #define ADCON3VAL  0x0010      /* Tad is 16 Tcy     */
    #define ADCHSVAL  0x0000  /* AN0 input on channel 0  */
    #define ADPCFGVAL  0xFFFE  /* AN0 input is Analog   */
    #define ADCSSLVAL  0x0000   /* No channel scanning   */
     #endif
     #include "..\h\ADCChannelDrv.h"
     static ADCChannelHandle * thisADCChannel;
     /* This function will intialize the DMA  */
     /* DMA0 is used to read from the ADC  */
      thisADCChannel = pHandle;
     pHandle->buffer1  = pBufferInDMA; /* Assign the ping pong buffers for the ADC DMA*/
     pHandle->buffer2  = (int *)((int)pBufferInDMA + ADC_BUFFER_SIZE);
     DMA0CONbits.SIZE  = 0;  /* Word transfers       */
     DMA0CONbits.DIR  = 0;  /* From ADC1BUF to DMA     */
     DMA0CONbits.HALF  = 0;  /* Interrupt when all the data has been moved */
     DMA0CONbits.NULLW  = 0;  /* No NULL writes - Normal Operation   */
     DMA0CONbits.AMODE  = 0;  /* Register Indirect with post-increment mode */
     DMA0CONbits.MODE  = 2;  /* Continuous  ping pong mode enabled  */
     DMA0REQbits.FORCE  = 0;  /* Automatic transfer    */
     DMA0REQbits.IRQSEL = 0xD; /* ADC conversion complete   */
     DMA0STA = (int)(pHandle->buffer1) - (int)&_DMA_BASE;
     DMA0STB  = (int)(pHandle->buffer2) - (int)&_DMA_BASE;
      DMA0PAD = (int )&ADC1BUF0;
     DMA0CNT = ADC_BUFFER_SIZE - 1;
      AD1CON1  = ADCON1VAL;    /* Load the ADC registers with  value  */
     AD1CON2  = ADCON2VAL;    /* specified in 12bitADCDriver.h */
     AD1CON3  = ADCON3VAL;
     AD1CHS0  = ADCHSVAL;
     AD1PCFGLbits.PCFG0 = 0;
     AD1CSSL  = ADCSSLVAL;
    TMR3   = 0;
     PR3  = (ADC_CHANNEL_FCY/ADC_FSAMP) - 1;
     pHandle->bufferIndicator  = 0;
     pHandle->isReadBusy   = 1;
     _DMA0IF = 0;
     _DMA0IE = 1;
     DMA0CONbits.CHEN = 1;  /* Enable the DMA Channel */
     AD1CON1bits.ADON = 1;  /* Enable ADC module  */
     T3CONbits.TON   = 1;  /* Enable Timer 3        */
     void ADCChannelStop(ADCChannelHandle * pHandle)
     _DMA0IE = 0;    /* Disable the DMA interrupt */
     DMA0CONbits.CHEN = 0;  /* Disable the DMA Channel */
     AD1CON1bits.ADON = 0;  /* Disable ADC module  */
     T3CONbits.TON   = 0;  /* Disable Timer 3        */
     void ADCChannelRead (ADCChannelHandle * pHandle,int *data,int size)
     int *source;
     int  i;
     /* if the buffer indicator bit is 1, then use buffer 1 else use buffer2 */
     /* Since the DMA ping pongs between these buffer, you must know */
     /* which one to read. The bufferIndicators keep track of this  */
     source = (pHandle->bufferIndicator) ? pHandle->buffer1 : pHandle->buffer2;
     if (size > ADC_BUFFER_SIZE) size = ADC_BUFFER_SIZE;
     for(i = 0;i < size;i++)
      data[i] = source[i];
     __asm__ volatile("disi #0x4"); /* disable interrupts */
     __asm__ volatile("disi #0x0"); /* enable interrupts */
     return(pHandle->isReadBusy);
     void __attribute__((__interrupt__,no_auto_psv)) _DMA0Interrupt(void)
     _DMA0IF = 0;
     thisADCChannel->bufferIndicator   ^= 1;  /* Flip the indicator bit  */
     thisADCChannel->isReadBusy  = 0;   /* New frame is available */
    I want to set it to 60kHz. I set ADC_FSAMP = 60000, and calculate ADCS.
    Tcy = 25ns (@40MHz)
    Tc = 1/60000 = 16.66us = 16666ns (aprox.)
    Tad = Tc/14 = 1190ns (aprox.)
    ADC Conversion Clock: Tad=Tcy*(ADCS+1) => ADCS = (Tad/Tcy) - 1 = 46,61 = 47 (aprox.).
    I set ADCS = 47, so I write:
    #define ADCON3VAL 0x002F
    To test if the ADC is working correctly, I generate a 10kHz signal for the board using my PC sound card (using Visual Analyser 2011). But the ADC won't finish sampling (I use a LED to signal when 128 samples have been acquired - when finished, the LED switches off). Also, if I generate a DC signal, the ADC won't finish sampling. More interesting is the fact that when I generate a 1kHz signal, the ADC works fine!! I used debug to view the samples, exported the values in a file and plotted them in Matlab.Please help in solving this problem. I really need to get this ADC running for a project I am working on.
    Default Re: How to configure ADC sampling rate?
    Maybe you should try a C forum. Here we do Basic only.
    Jan 2013
    OK. I will try another forum. Thanks!
  1. Picbasic and ADC set_up
    Last Post: - 13th January 2013, 10:26
  2. Help with multiple ADC inputs
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 4th January 2013, 01:27
  3. CONFIGURE & OSCCON & meProg configure
    By SUNFLOWER in forum mel PIC BASIC Pro
    Last Post: - 19th February 2011, 22:25
  4. Replies: 1
    Last Post: - 19th February 2011, 19:35
  5. Sampling rate - PIC16F877
    By Tomas in forum mel PIC BASIC Pro
    Last Post: - 29th January 2011, 11:00
