Hi Heckler,
I hope it finds you well.
Thank you for your kind replying here.
I really appreciate you in advance for your support.
My suggesstion is to modify your written routine under my Microcode studio and just assign a pin for "R/w". and using LCDIN command for writing in LCD's RAM and so on. Because I should work with usual LCDs. I think I should all these two headers
What do you think Sir?DEFINE LCD_RWREG PORTE ' LCD read/write pin port
DEFINE LCD_RWBIT 2 ' LCD read/write pin bit
After I received your help, if my suggestion be right, it seems, it would be easy to fix this section. But now, I am hardly busy at something else, a damn PID routine for pressure control.and honestly I cannot focus on anything else. My mind is 100% busy
May I very kindly ask you twice to take a look again at your valuable work and give me some points/remedy for implementing a dot, between 1st and 2nd numbers (from left side)?
I would never forget your kind help.
Best regards,
Andy
