Hi Al,
yes, i have a boatload of new stepper motors, and they are all 200 steps or higher. Most of my encoders are 400 cpr.
I have many steppers that are gear reduced giving actual 0.18 degree per step translation at the shaft. My applications require relatively low speed on the steppers,60-100 rpm range , it's more a matter of being accurate, than fast.
I do not need the accuracy of 2000 pulse per turn, i just thought (without really knowing what the heck i am talking about ;-) that the PIC18f4431 QUI features would make hardware more straight forward as the functionality would be handles at the chip "hardware" level rather than at the motor controller level.
Again, total newbie here, just trying to figure this out so I can actually build a prototype.
At the end of the day, all i need it to get this darn thing up and running, as it turns out I then have to spend untold hours trying to just understand that I can do before I can actually do anything
i have been trying to get the combination of :So far, a simple, totally newbie, easy to understand without tons of research, etc. . . .has eluded me
- Program in PBP
- schematic using parts I have So i understand how to actually connect things on a breadboard
- using motors and encoders that I have (almost exclusively HEDS-5545 or HEDS-5645 on double shaft VEXTA steppers)
Your fine assistance is well appreciated but was a little less than "turn-key" LOL and is still being worked on by yours truly :-)
thanks again for the continued help . . .man do I need it.
Lost in New Jersey
John
