Arrays and Constants
Results 1 to 4 of 4
    Mar 2013
    Default Arrays and Constants
    Hi everyone,
    Is there a way to use a constant to define the size of your array? eg:
    DEV CON 60
    LED VAR BYTE[WS]
    It compiles, but throws up a syntax error (Haven't tested in the program yet)
    Thanks.
    Default Re: Arrays and Constants
    That IS the way to do it.
    But you can't name the constant DEV and then use WS in the array declaration.... You need to use a constant that actually have been declared.
    WS CON 60
    LED VAR BYTE[WS]
    Mar 2013
    Thanks, yep that was just a typo.
    I'll have a go now I'm back with the project.
    Mar 2013
    Simple problem in the end.
    WS CON 60
    LED VAR BYTE[WS]
    Has to be above anything that uses it. If you don't it will compile O.K. but you will see a syntax error afterwards, and will not work.
    Badger...
  1. Port Variables act like Constants
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 7th March 2011, 17:29
  2. PORTC constants
    By Forkosh in forum mel PIC BASIC Pro
    Last Post: - 18th October 2007, 05:43
  3. constants
    By cmolson in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 13:33
  4. Bug ? Error in calculating constants
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 11th October 2005, 21:55
  5. storing arrays and reading arrays
    By Yue in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 22:03
