hpwm more than 2 ch possible in pbp?????????
Results 1 to 21 of 21
    What happens if you enable only 1 channel at a time?
    I.E. CCP1CON=0 : CCP3CON=0
    Does channel 2 still flicker?
    Are you sure it's not the circuit channel 2 is connected
    to that's causing the flicker?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    oscar's Avatar
    oscar Guest
    Default found the problem
    yet again tis me thats at fault.... many thanx to bruce for his code example. the mistake i was making was that i was calling the hpwm routine which seemed to be causing a conflict. instead i just wrote the duty val directly to the port ie portb.5=duty5 ... simple! lol this took many hours of hair loss and alcohol !!!!!!. only 1 teeny weeny prob left lol... i cant get the ch's to go to full off . they get to say 9% and stay there. so a faint glow is visible but apart from that everything is aok. dimming is as smooth as a babys ass and im a happy bunny.( irish saying).. many many thanks to bruce n the rest of u guys.. slainte...
    thanx
    oscar.
    Feb 2005
    Im refloating this thread because I have a question:
    I tried the example provided by Bruce succesfully, but now I want to use ON Interrupt on portb changes.
    The problem I encounter is that CCP3 uses RB5 and the interrupt is triggered by changes in the portb.4 to portb.7
    What can be done?
    Help us a litle bit Pic model?
    How bad/good it is if in the INT routine you test the PORTB and if it's just related to the HPWM, it goes out of there ?
    Feb 2005
    Sorry Im using the same pic as Bruce example: 16F767
    but Im having more basic problems, when I wasnt able to run the program as desired I started to remove parts of it, and now I see it does not work at all, so I may be missing some register configuration.
    Here is the header of my program:
    @ device pic16F767, wdt_on, intrc_osc_noclkout, mclr_off, protect_off
    trisb   =%11000000
    trisa   =%00000001
    cmcon   =%00000111  'Comparators Off
    intcon  =%10001000  'interrupts enable
    ; Set CCP modules to PWM mode
    CCP1CON = %00001100 ' Mode select = PWM
    CCP2CON = %00001100 ' Mode select = PWM
    CCP3CON = %00001100 ' Mode select = PWM
    PR2 = $20    ; Set period
    pie2.1=0    ;disable interrupts on CCP3 (I think this should work)
    ; Set TMR2 up for 1:1 prescale & turn it on
    T2CON = %00000100 ' TMR2 ON 1:1 prescale
    porta=0:portb=0:portc=0
    high porta.1
    pause 200
    low porta.1
    pause 200
    high porta.1
    pause 200
    low porta.1
    As you can see very basic, and I dont even started with the pwm/interrupts stuff.
    I program the pic via ICSP and power it, it seems to run at turtle speed , the 200ms pause takes 28seconds...
    What I am missing? Thanks
    Hangover, Germany
    Talking
    Quote Originally Posted by peu
    What is about a DEFINE OSC ?
    At what speed does the PIC work ?
    What speed did you tell the PBP-Compiler ?
    Feb 2005
    Oh I didnt post it in my previous post sorry, there is a define osc 4 below the @device statement
    but it still goes slow...
    Pablo
  1. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  2. Microcontroller with 2 way paging application problem
  3. Replies: 2
    Last Post: - 10th July 2006, 02:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
