hpwm more than 2 ch possible in pbp?????????
Results 1 to 21 of 21
    Jan 2006
    This seems to be a very popular comment. Bruce mentioned that you could modify the 16F library to accomodate for the 3rd HPWM channel. Could any of the advanced members take on this project and post the library? Seems that it would solve many repeat posts for the same problem.
    Feb 2005
    Quote Originally Posted by docwisdom
    If someone has just a tip on what to look, I will really appreciate it. Thanks!
    Feb 2005
    Kolkata-India
    Default Clicked two times sorry
    The post is the next one
    Feb 2005
    Kolkata-India
    Default Sneek into PBPPIC14.LIB in your PBP folder
    That's the library bruce was talking about. This contains the PBP function which is used by the compiler to extract and create codes and fits into the target processor. So portions only needed by your code are compiled according to PIC and placed in the top part of your compiled prog.
    The problem with the HWPM command is that it calculates the PR2 (Freq) and CCP1CON + CCPCON (Duty Cycle) every time you use it in your code. That's the reason why changes do not take place immediately. So it is always a better idea to modify the duty cycle registers directly. To make life easy use the HPWM once then go on varying the duty cycle yourself. Depending on the PR2 values (read the datasheet for the Math) you should have a limit on the max duty cycle value to ensure smooth rollover.
    It was Bruce's code found in a thread which gave me the wayout. Thanks bruce. I should have thanked you much earlier for showing the path.
    I do not have a chip lying around that has 3 channels HPWM. I would sure like to give a try modifying the library. No commitments however (My firm is a design house and basically one man army on the development front!!!)
    Sougata
  1. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  2. Microcontroller with 2 way paging application problem
  3. Replies: 2
    Last Post: - 10th July 2006, 01:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 14:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
