hpwm more than 2 ch possible in pbp?????????
Results 1 to 21 of 21
    Feb 2005
    Sorry Im using the same pic as Bruce example: 16F767
    but Im having more basic problems, when I wasnt able to run the program as desired I started to remove parts of it, and now I see it does not work at all, so I may be missing some register configuration.
    Here is the header of my program:
    @ device pic16F767, wdt_on, intrc_osc_noclkout, mclr_off, protect_off
    trisb   =%11000000
    trisa   =%00000001
    cmcon   =%00000111  'Comparators Off
    intcon  =%10001000  'interrupts enable
    ; Set CCP modules to PWM mode
    CCP1CON = %00001100 ' Mode select = PWM
    CCP2CON = %00001100 ' Mode select = PWM
    CCP3CON = %00001100 ' Mode select = PWM
    PR2 = $20    ; Set period
    pie2.1=0    ;disable interrupts on CCP3 (I think this should work)
    ; Set TMR2 up for 1:1 prescale & turn it on
    T2CON = %00000100 ' TMR2 ON 1:1 prescale
    porta=0:portb=0:portc=0
    high porta.1
    pause 200
    low porta.1
    pause 200
    high porta.1
    pause 200
    low porta.1
    As you can see very basic, and I dont even started with the pwm/interrupts stuff.
    I program the pic via ICSP and power it, it seems to run at turtle speed , the 200ms pause takes 28seconds...
    What I am missing? Thanks
    Hangover, Germany
    Talking
    Quote Originally Posted by peu
    What is about a DEFINE OSC ?
    At what speed does the PIC work ?
    What speed did you tell the PBP-Compiler ?
    Feb 2005
    Oh I didnt post it in my previous post sorry, there is a define osc 4 below the @device statement
    but it still goes slow...
    Pablo
    Feb 2005
    any idea? Thanks
    Feb 2005
    I could use some help Thanks in Advance
    Jan 2006
    This seems to be a very popular comment. Bruce mentioned that you could modify the 16F library to accomodate for the 3rd HPWM channel. Could any of the advanced members take on this project and post the library? Seems that it would solve many repeat posts for the same problem.
    Feb 2005
    Quote Originally Posted by docwisdom
    If someone has just a tip on what to look, I will really appreciate it. Thanks!
  1. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  2. Microcontroller with 2 way paging application problem
  3. Replies: 2
    Last Post: - 10th July 2006, 02:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
