USB issue - 18F4550
Results 1 to 15 of 15
    Default Re: USB issue - 18F4550 - DT_HID260
    Malcolm,
    I'm running your program here on a LAB-XUSB.
    I had to change some things to make it run on it. And I made a program for the PC to just send/receive some data over USB.
    Your program is sending out 127 reports per second when the USB is plugged in.
    I'm not sure if your friends PC app can handle that many reports while updating GUI sliders etc..
    It also fills up the USB buffer before the PC app connects, so when it does connect, it gets hit hard with a whole bunch of reports.
    When I send data to it via USB, it saves the data to EEPROM and continues sending the new data at 127 reports per second.
    So the USB portion is working properly.
    You just need to limit the data going out.
    It should really only send the data by request from the PC, instead of all the time.
    This was all quite evident after adding the USB status LED's from post #3.
    Oct 2009
    Darrel,
    thanks for taking the time out to test the code and report your findings.
    I assume that ideally the PC program should send a request to the PIC, which then responds and sends the report, rather than the PIC constantly sending out reports when connected ?
    I'll drop the guy a mail to see if he can come up with a revised application.
    Your contribution is very much appreciated
    Malcolm
    Dec 2010
    A simple interim step might be sending only 1 report per second or even less. There'll be lots of work to get a query/response protocol going and a simple slow down might meet your needs for this one-off project, or at least let you work other areas of the code while you're waiting for PC side changes.
    Oct 2009
    Hi Charlie,
    Yes I have other parts of the code to develop, and whilst it would be a nice function to have, I can live without it if I must.
    To prove it wasn't a duff chip or hardware issue with the USB port on the EasyPic5 board I downloaded the USB Demo example (Mr E's) and stuck a 4mhz resonator in the board - it ran fine and I could toggle the LEDS on portB from the PC application. I then swapped the resonator for a 20 mhz xtal and set the fuses in the programmer accordingly and tested again - it ran sweetly. So the issue is with the code, and I have no reason to doubt DT's explanation.
    Thanks for the comments
    Malcolm
    Oct 2009
    @Darrel,
    Hi, need some advice regarding the way the HID260 USB routine works.
    I commented out the send section in my main code thus:
     ;   if TX_READY = 1 and plugged = 1 then gosub SendUSB
        if RX_READY = 1 and plugged = 1 then gosub GetUSB
        if plugged = 0 then FirstSend = 1       'If we unplug then reset the first read packet as dont want it!
    So this way I can check the sending of data from the PC to PIC. As the software is written to read the EEPROM data from the PIC first, the application displayed garbage values in the sliders which was as expected. Opening up the port monitor I got one TX report for each time I clicked on the update button, and whilst I couldn't see what values I was sending to the PIC, the LCD appeared to respond and display the change of values.
    I removed the comment from that line and again the PIC was spewing report after report as you found. I therefore added the line
    SendData:
            USBOut 1, USBTXBuffer, USBBufferCount , SendData  ' if bus available, transmit data
            plugged = 0
    The theory being that once it's sent that first report the software would then behave as if the USB lead had been removed - there was no change when the USB port was monitored. So I tried the following
            TX_READY = 0
    Again, my logic thinking that once the report had been sent and the TX_ready state set to "not ready" it would stop transmission - but again no change. It's as if something else is over-riding the values used, which originate in the included HID260 file. The code I'm using doesn't have any other calls or conditions connected with the USB, just those IF / THEN statements to check the status of ready and plugged, and then the send and receive routines. Can you advise where or why over-riding these variables have no effects.
    Cheers
    Malcolm
    PLUGGED, RX_READY and TX_READY are status bits that DT_HID copies from the hardware USB registers on each USB interrupt.
    They allow your program to know the USB status.
    But they do not control anything.
    Why not just increment a variable, and only send data when it reaches 127.
    Then it should send it once a second.
    Oct 2009
    Thanks for the info,
    I've added a counter and condition as suggested and it does indeed now pole once a second, but I'm still getting the same issue, but this time it's easy to spot. I can move a slider, click update, but a second later it will revert back to it's default setting. Watching the port monitor, only RX reports are being shown. However if I comment out the part of the code which does the checks for TX ready and plugged, I can send updates from the PC, which is shown in the port monitor window. It's as if the RX part on the PIC side is being ignored
  1. USB Electrical Layout?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 11th March 2013, 12:04
  2. PIC USB in and USB Out
    By koossa in forum General
    Last Post: - 9th February 2013, 09:00
  3. 18F4550 issue
    Last Post: - 4th February 2013, 06:27
  4. Wake from sleep with USB Interrupt
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 13th January 2013, 00:59
  5. Bidirectional Excel Data via USB
    By jmstrat in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2013, 08:04
