USB issue - 18F4550
Results 1 to 15 of 15
    Default Re: USB issue - 18F4550 - DT_HID260
    Hi Malcolm,
    I'm affraid there's not enough code posted to be able to find your problem.
    I think what you've posted is the part you've gone over a hundred times and couldn't see anything wrong. So maybe there's nothing wrong there.
    It's likely the problem is somewhere else.
    The RX_READY bit is simply copied from the Hardware USB status register on every USB interrupt.
    If it never goes high, then either nothing is being sent from the PC, or the data has been collected already before you displayed RX_READY on the LCD.
    I would suggest enabling the USB Status LED's so you can see what's happening in real time.
    ; --- Each USB LED is optional, comment them if not used ----
    DEFINE USB_LEDPOLARITY 1       ; LED ON State [0 or 1]  (default = 1)
    DEFINE USB_PLUGGEDLED  PORTB,0 ; LED indicates if USB is connected
    DEFINE USB_TXLED       PORTC,2 ;  "      "     data being sent to PC
    DEFINE USB_RXLED       PORTC,1 ;  "      "     data being received from PC
    Oct 2009
    Hi Darrel,
    Here's the full code, which I hope might help. I have tried a USB scanner and got the attached results.. which mean nothing to me, other than it throws up some errors when the PC software was launched.
    @ errorlevel -205
    ' Config settings
    asm
    ; 18F2550/4550, 20mhz crystal
       __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
       __CONFIG    _CONFIG1H, _FOSC_HSPLL_HS_1H
       __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_OFF_2L & _VREGEN_ON_2L
       __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
       __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    DEFINE OSC 48
    CLEAR
    ADCON0 = 0          'Set ADCON0
    ADCON1 = %00001111  'Set D i/o
    CMCON = 7           'Disable Comparators
    CCP1CON = %00001100 'set pwm  white  - pin12
    CCP2CON = %00001100 'set pwm  blue   - pin12
    TRISA  = %00000000  'set PORTA as all output
    TRISB  = %00000011  'set PORTB as all output
    TRISC  = %01011000  'set PORTC as all output apart from port 6 used for backlight button
    PR2 = 249
    'T2CON = %00000100   ' Start Timer2, Prescaller 1:1
    DEFINE LCD_DREG PORTB       ' Setup the ports for the LCD (as not set to the default layout as set in PBP)
    DEFINE LCD_DBIT 0           ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_RSREG PORTB      ' Set LCD Register Select port
    DEFINE LCD_RSBIT 4          ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB       ' Set LCD Enable port
    DEFINE LCD_EBIT 5           ' Set LCD Enable bit
    DEFINE LCD_BITS 4           ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_LINES 4          ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2000   ' Set command delay time in us
    DEFINE LCD_DATAUS 50        ' Set data delay time in us
    LCD_BACKLIGHT   var PORTB.7     'Set port b .7 for LCD backlight (High = on)
    PBUTTON         var PORTC.6     'set PORTC.6 for the button for the lcd
    SDA_Pin         var PORTB.0     'RTC SDA Data pin
    SCL_Pin         var PORTB.1     'RTC SCL clock pin
    CounterA var byte	               ' General purpose Variable
    CounterB var byte	               ' General purpose Variable
    option            var byte
    H_butt   VAR PORTE.2
    M_butt   VAR PORTE.0
    S_butt   VAR PORTE.1
    i               var word        'Misc counter
    iv              var word
    LCD_Mode        var word        'LCD light mode
    LCD_Timer       var word        'Timer for how long the LCD is on for.
    LCD_Time        var word        'Counter for the timer
    LCD_Tmr         var word
    ' Temp probes
    Temperature var word[4]
    Temperature1    var temperature[0]
    Temperature2    var Temperature[1]
    Temperature3    var Temperature[2]
    Temperature4    var Temperature[3]
    ' RTC Variables
    'RTC_Msecs       var byte
    RTC_Secs        var byte
    RTC_Mins        var byte
    RTC_Hours       var byte
    RTC_Day         var byte
    RTC_WDay        var byte
    RTC_Month       var byte
    RTC_Year        var byte
    RTC_Ctrl        var byte
    dummy           var byte
    RTclock         var byte[8]
    Tick_Tmr        var byte
    SetupPreset:
    	RTC_Secs=$00		             ' Seconds preset to 00
    	RTC_Mins=$59		             ' Minutes preset
    	RTC_Hours=$09		             ' Hours preset
    	RTC_WDay=$01		             ' Weekday preset to 01
    	RTC_Day=$12		                 ' Day preset 12
    	RTC_Month=$06	                 ' Months preset to June
    	RTC_Year=$02		             ' Year preset to 2002
    	RTC_Ctrl=$10
    ' LED variables
    ' Whites:
    W_Min           var word    'Min Light value
    W_Max           var word    'Max Light value
    W_Fade_In       var word    'Fade in duration
    W_Fade_Out      var word    'Fade out duration
    W_On_Time_H     var word    'What time to turn the lights on
    W_On_Time_M     var word    'What time to turn the lights on
    W_Off_Time_H    var word    'Time to turn lights off
    W_Off_Time_M    var word    'Time to turn lights off
    ' Blues:
    B_Min           var word    'Min Light value
    B_Max           var word    'Max Light value
    B_Fade_In       var word    'Fade in duration
    B_Fade_Out      var word    'Fade out duration
    B_On_Time_H     var word    'What time to turn the lights on
    B_On_Time_M     var word    'What time to turn the lights on
    B_Off_Time_H    var word    'Time to turn lights off
    B_Off_Time_M    var word    'Time to turn lights off
    'Running fade variables
    B_FadeIn_Time   var word    'LIVE fade delay time seconds
    B_FadeOut_Time  var word
    W_FadeIn_Time   var word
    W_FadeOut_Time  var word
    B_Cnt           var word    'Seconds counter for the timing of adjusting the PWM
    W_Cnt           var word
    B_Tick          var word
    W_Tick          var word
    'PWM Variables where the current output values are stored
    W_PWM           var word    'Whites
    B_PWM           var word    'Royal Blues
    Blue_Day_Cycle      var word    'Store for which part of the day cycle we are in
    White_Day_Cycle     var word
    ' Constants for the current running mode cycle for the lights
    DAWN    con     0
    DAY     con     1
    DUSK    con     2
    NIGHT   con     3
    'Expendable variables used for misc calculations etc
    Vb_1            var word
    Vb_2            Var word
    Vb_3            var word
    Vb_4            var word
    USBBufferCount  Var Byte
    Firstsend       var byte        ' When first connected the pc auto sends data, but we want to READ first otherwise
                                    ' the eeprom gets overwritten with zeros as the pc sends a packet we DONT want.
    ' Set default data in internal EEPROM
        data @0
        data    10      'Whites ON Time HOURS
        data    00       'Whites ON Time MINS
        data    10      'Whites OFF Time HOURS
        data    10       'Whites OFF Time MINS
        data    0       'Whites Fade IN duration HOURS
        data    5      'Whites Fade IN duration MINS
        data    0       'Whites Fade OUT duration HOURS
        data    3       'Whites Fade OUT duration MINS
        data    0       'Whites MIN Intensity %
        data    100      'Whites MAX Intensity %
        data    10      'Blues ON Time HOURS
        data    0       'Blues ON Time MINS
        data    10      'Blues OFF Time HOURS
        data    10       'Blues OFF Time MINS
        data    0       'Blues Fade IN duration HOURS
        data    5       'Blues Fade IN duration MINS
        data    0       'Blues Fade OUT duration HOURS
        data    5       'Blues Fade OUT duration MINS
        data    0       'Blues MIN Intensity %
        data    100      'Blues MAX Intensity %
        Data @150,74,97,110,70,101,98,77,97,114,65,112,114
    		' Jan Feb Mar Apr
    	Data 77,97,121,74,117,110,74,117,108,65,117,103
    		' May Jun Jul Aug
    	Data 83,101,112,79,99,116,78,111,118,68,101,99
    		' Sep Oct Nov Dec
    	Data 84,117,101,87,101,100,84,104,117,70,114,105
    		' Tue Wed Thu Fri
    	Data 83,97,116,83,117,110,77,111,110
    		' Sat Sun Mon
    'Setup Interrupts
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"
    INT_LIST  macro    ; IntSource,          Label,  Type, ResetFlag?
            INT_Handler   USB_Handler
            INT_Handler     TMR1_INT,  _MyTimer,   PBP,  yes
    endasm
    T1CON = %10000001                               ; free-running, 1:1 prescaler
    @   INT_ENABLE   TMR1_INT                       ; enable Timer1 interrupts
    'Setup USB
    INCLUDE "DT_HID260.pbp"
    DEFINE USB_VENDORID    6017
    DEFINE USB_PRODUCTID   1969
    DEFINE USB_VERSION     1
    DEFINE USB_VENDORNAME  "CSL Designs"
    DEFINE USB_PRODUCTNAME "Aqua-LED"
    DEFINE USB_SERIAL      "001"
    DEFINE USB_INSIZE      64   ;  IN report is PIC to PC (8,16,32,64)
    DEFINE USB_OUTSIZE     64   ; OUT report is PC to PIC
    DEFINE USB_POLLIN      10   ; Polling times in mS, MIN=1 MAX=10
    DEFINE USB_POLLOUT     10
    ' Start the program
    code_start:
       ' i2cwrite SDA_Pin,scl_pin,$D0,$00,[$00,$00,$00,$59,$19,$24,$08,$00]
        I2Cwrite SDA_pin,SCL_pin,$D0,$00,[RTC_Secs,RTC_Mins,RTC_Hours,RTC_WDay,RTC_Day,RTC_Month,RTC_Year,RTC_Ctrl]
        Blue_Day_Cycle = DAWN
        White_Day_Cycle = DAWN
        b_cnt = 0
        w_cnt = 0
        gosub   read_eeprom     'Read in the data needed for the lighting periods
        Firstsend = 1
        USBBufferCount = 64     'Size of the USB buffer we use
        LCD_Mode = 3            'LCD Backlight always ON
        LCD_Time = 0            'Both these are used for the duration the backlight
        LCD_Tmr = 0             'is on when not in mode 3.
        gosub Calc_Fade
        high LCD_BACKLIGHT
        LCDOUT  $FE,1
    ' Display splash screen
        lcdout  $FE,$C0,"    AquaLED V1.0    "
        lcdout  $FE,$94,"  (C)2010 M.Jervis  "
        pause   1000   'wait a seconds so they can see it
        lcdout  $FE,1   'Clear the screen
    'Main program loop
        'Main body of program where we determine which time of day we are in
    '*** Do BLUE daily cycle
        select case Blue_Day_Cycle
        case DAWN
        lcdout $FE,$94,"BL: DAWN "
            if b_cnt = B_Fadein_time and B_PWM < B_Max then
                B_PWM = B_PWM + 1
                b_cnt = 0
            if B_PWM = b_max then
                Blue_Day_Cycle = DAY
        case DAY
        lcdout $FE,$94,"BL: DAY  "
            if RTC_Hours = B_Off_Time_H and RTC_Mins = B_Off_Time_M then
                Blue_Day_Cycle = DUSK
                b_cnt = 0
        CASE DUSK
        lcdout $FE,$94,"BL: DUSK "
            if b_cnt >= B_Fadeout_time and B_PWM > B_Min then
                B_PWM = B_PWM - 1
                b_cnt = 0
            if B_PWM = b_min then
                Blue_Day_Cycle = NIGHT
        case NIGHT
        lcdout $FE,$94,"BL: NIGHT"
            if RTC_Hours = B_On_Time_H and RTC_Mins = B_On_Time_M then
                b_cnt = 0
        end select
    '*** Do WHITE daily cycle
        select case White_Day_Cycle
        case DAWN
        lcdout $FE,$94+11,"WT: DAWN "
            if w_cnt = w_Fadein_time and W_PWM < w_max then
                W_PWM = W_PWM + 1
                w_cnt = 0
            if W_PWM = W_max then White_Day_Cycle = DAY
        case DAY
        lcdout $FE,$94+11,"WT: DAY  "
            if RTC_Hours = W_Off_Time_H and RTC_Mins = W_Off_Time_M then
                White_Day_Cycle = DUSK
                w_cnt = 0
        CASE DUSK
        lcdout $FE,$94+11,"WT: DUSK "
            if w_cnt >= w_Fadeout_time and W_PWM > w_min then
                W_PWM = W_PWM - 1
                w_cnt = 0
            if W_PWM = W_min then White_Day_Cycle = NIGHT
        case NIGHT
        lcdout $FE,$94+11,"WT: NIGHT"
            if RTC_Hours = W_On_Time_H and RTC_Mins = W_On_Time_M then
                w_cnt = 0
        end select
        hpwm 1,W_PWM,1500
        hpwm 2,B_PWM,1500
        gosub Read_Clock
        i = (((RTC_Secs>>4)&$0F)*10)+(RTC_Secs&$0F)
        lcdout $FE,$80,"BLUES  ",dec3 (B_PWM *100)/255,"%"
        lcdout $FE,$C0,"WHITES ",dec3 (W_PWM *100)/255,"%"
        gosub   USB_Plugged
        if TX_READY = 1 and plugged = 1 then gosub SendUSB
        if RX_READY = 1 and plugged = 1 then gosub GetUSB
        if plugged = 0 then FirstSend = 1   'If we unplug then reset the first read packet as dont want it!
        lcdout $FE,$D4+6," ",dec RX_READY
    '**** FINSISH BUTTON CODE ****
        if PBUTTON = 1 then
            LCDOUT $FE,1
            goto mainmenu
    ' LCD Backlight time
    ' Keeps the LCD backlight on until time is met unless its set to
    ' always on.
    LCD_Blight:
        if LCD_Mode = 0 then        '10 seconds
            LCD_Timer = 10
        elseif LCD_Mode = 1 then    '30 seconds
            LCD_Timer = 30
            LCD_Timer = 60          '1 minute
        LCD_Time = LCD_Time + 1
        if LCD_Time = 100 then
            LCD_Tmr = LCD_Tmr + 1
            LCD_Time = 0
        if LCD_Tmr >= LCD_Timer then
            low LCD_BACKLIGHT
            LCD_Tmr = 0
            LCD_Time = 0
    ' USB Services.
    ' Send and recieve data packets
    ' Packet sizes are 64 bytes which should cover the amount of
    ' data we need for now.
    SendUSB:
            for i = 0 to USBBufferCount - 1
                read i,USBTXBuffer[i]    'Read the eeprom data and store in the outward bound buffer
            next i
    SendData:
            USBOut 1, USBTXBuffer, USBBufferCount , SendDATA  ' if bus available, transmit data
    GetUSB:
            USBin 1, USBRXBuffer, USBBufferCount, Timeout  ' if bus available, receive data
            if Firstsend = 0 then
                    write i,USBRXBuffer[i]    'Write the eeprom data received from the PC
                next i
            gosub Read_eeprom                 'Read eeprom data into the variables
                Firstsend = 0
    Timeout:
    ' If USB plugged display USB on the display
    USB_Plugged:
        if plugged = 0 then
        lcdout $FE,$91,"   "
        lcdout $FE,$91,"USB"
    ' LED Fade calculations
    ' This routine takes the fade in/out durations and also the min/max
    ' LED power values and calculates what the duration is between
    ' changing the PWM value to give us a smooth fade from min to max
    Calc_Fade:
        vb_1 = ((b_fade_in.highbyte * 60) + b_fade_in.lowbyte) *60  'Get total duration time in seconds
        vb_2 = b_max - b_min                                        'Work out the 'distance' the lights go from min to max
        b_fadein_time = vb_1 / vb_2                                 'Get number of seconds between each PWM change
        vb_4 = vb_1 // vb_2                                         'Get fractions of a second
        if vb_4 >=5 then b_fadein_time = b_fadein_time + 1          'If its over half a second then round up
        vb_1 = ((b_fade_out.highbyte * 60) + b_fade_out.lowbyte) *60
        b_fadeout_time = vb_1 / vb_2
        if vb_4 >=5 then b_fadeout_time = b_fadeout_time + 1        'If its over half a second then round up
        vb_1 = ((w_fade_in.highbyte * 60) + w_fade_in.lowbyte) *60
        vb_2 = w_max - w_min
        w_fadein_time = vb_1 / vb_2
        if vb_4 >=5 then w_fadein_time = w_fadein_time + 1          'If its over half a second then round up
        vb_1 = ((w_fade_out.highbyte * 60) + w_fade_out.lowbyte) *60
        w_fadeout_time = vb_1 / vb_2
        if vb_4 >=5 then w_fadeout_time = w_fadeout_time + 1        'If its over half a second then round up
        'Lets say 2 hours (120 mins) & 191 for the fade amount (ie 0 to 255 or 0% to 100% intensity)
        'So we need to do:
        ' convert hours into minutes, then add minutes and then multiply by 60 to convert to seconds
        ' so: 2 hours = 120 mins + 0 mins * 60 to get 7200 seconds
        ' The distance is now based on the converted % into the PWM range of 0-255
        ' calculate the 'distance' the light goes from min to max (0 to 255 in this eg: 75% = 191 so: 191- 0 = 191)
        ' now divide total seconds by 'distance' ie: 7200 / 191 = 37.69 seconds between each PWM change
        ' Now we test the milliseconds and if above .5 we round up to the next second
    ' Check current time and adjust the position in the cycle to
    ' make sure that its where it should be in case of a power failure
    ' or if the settings are changed via the PC
    Check_Lighting:
        if rtc_hours < b_on_time_h then                 'Are we earlier than the fade in time?
            blue_day_cycle = NIGHT                      'Yes so set the current mode to night
            white_day_cycle = NIGHT
        elseif rtc_hours > b_off_time_h then            'Are we later than time off?
            vb_1 = b_off_time_h + b_fade_out.highbyte   'need to find out if were actually past the end of the fade out time
            vb_2 = b_off_time_m + b_fade_out.lowbyte
            if vb_2 > 59 then                           'if the minutes are more than 59
                vb_1 = vb_1 + 1                         'then add 1 to the hour
                vb_2 = vb_2 - 60                        'Adjust the minutes back to between 0-59
            if rtc_hours > vb_1 and rtc_mins > vb_2 then
                blue_day_cycle = NIGHT                  'Yes so set the current mode to NIGHT
                blue_day_cycle = DUSK                   'No, were inbetween so set to DUSK
                white_day_cycle = DUSK
                vb_1 = rtc_hours - b_off_time_h          'Calculate the time difference between on time and current time
                vb_2 = rtc_mins - b_off_time_m
                vb_3 = (vb_1 * 3600) + (vb_2 * 60)      'Convert all to seconds
                B_PWM = B_max - (vb_3 / b_fadeout_time)   'Divide by the seconds count between each PWM to get how far we are in
                vb_1 = rtc_hours - w_off_time_h          'Calculate the time difference between on time and current time
                vb_2 = rtc_mins - w_off_time_m
                W_PWM = w_max - (vb_3 / w_fadeout_time)   'Divide by the seconds count between each PWM to get how far we are in
            vb_1 = w_on_time_h + w_fade_in.highbyte     'need to find out if were actually past the end of the fade out time
            vb_2 = w_on_time_m + w_fade_in.lowbyte
                blue_day_cycle = DAY                    'Yes so set the current mode to DAY
                white_day_cycle = DAY
                B_PWM = B_MAX
                W_PWM = w_max
                blue_day_cycle = DAWN                   'No, were inbetween so set to DAWN
                white_day_cycle = DAWN
                vb_1 = rtc_hours - b_on_time_h          'Calculate the time difference between on time and current time
                vb_2 = rtc_mins - b_on_time_m
                B_PWM = b_min + (vb_3 / b_fadein_time)  'Divide by the seconds count between each PWM to get how far we are in
                vb_1 = rtc_hours - w_on_time_h          'Calculate the time difference between on time and current time
                vb_2 = rtc_mins - w_on_time_m
                W_PWM = w_min + (vb_3 / w_fadein_time)  'Divide by the seconds count between each PWM to get how far we are in
    ' Read Eeprom data into variables
    Read_eeprom:
        read 0,w_on_time_h              'Whites ON time hours
        read 1,w_on_time_m              'Whites ON time minutes
        read 2,w_off_time_h             'Whites OFF time hours
        read 3,w_off_time_m             'Whites OFF time minutes
        read 4,w_fade_in.highbyte       'Whites fade IN duration hours
        read 5,w_fade_in.lowbyte        'Whites fade IN duration minutes
        read 6,w_fade_out.highbyte      'Whites fade IN duration hours
        read 7,w_fade_out.lowbyte       'Whites fade IN duration minutes
        read 8,w_min                    'Whites MIN intensity
        read 9,w_max                    'Whites MAX intensity
        read 10,b_on_time_h             'Whites ON time hours
        read 11,b_on_time_m             'Whites ON time minutes
        read 12,b_off_time_h            'Whites OFF time hours
        read 13,b_off_time_m            'Whites OFF time minutes
        read 14,b_fade_in.highbyte      'Whites fade IN duration hours
        read 15,b_fade_in.lowbyte       'Whites fade IN duration minutes
        read 16,b_fade_out.highbyte     'Whites fade IN duration hours
        read 17,b_fade_out.lowbyte      'Whites fade IN duration minutes
        read 18,b_min                   'Whites MIN intensity
        read 19,b_max                   'Whites MAX intensity
        W_Min = (W_Min *255)/100        'Convert intensity % to real PWM value (from 0-100% to 0-255)
        W_Max = (W_Max *255)/100
        B_Min = (B_Min *255)/100
        B_Max = (B_Max *255)/100
        gosub Read_Clock
        gosub Check_Lighting
    Read_Clock:
    I2CRead SDA_pin,SCL_pin,$D0,$00,[RTC_Secs,RTC_Mins,RTC_Hours,RTC_WDay,RTC_Day,RTC_Month,RTC_Year,RTC_Ctrl]
    If RTC_Hours.6=1 then
    CounterA=(RTC_Hours>>4)&$01                           ' Work-Out 12 or 24 hour Display for Hours
    CounterA=(RTC_Hours>>4)&$03
    CounterA=CounterA*10+(RTC_Hours&$0F)                  ' Display Hours appropriately for 12 or 24 hour Mode
    LCDOut $FE,$D4,#CounterA
    LCDOut $FE,$D4,#CounterA Dig 1,#CounterA Dig 0
    LCDOut ":",#(RTC_Mins>>4)&$0F,#RTC_Mins&$0F
     i = (((RTC_Hours>>4)&$0F)*10)+(RTC_Hours&$0F)
        rtc_hours = i
        i = (((RTC_Mins>>4)&$0F)*10)+(RTC_Mins&$0F)
        rtc_mins = i
    MyTimer:
        Tick_Tmr = Tick_Tmr + 1
        if Tick_Tmr >107 then
            Tick_Tmr = 0
            b_cnt = b_cnt + 1
            W_cnt = W_cnt + 1
    @  INT_RETURN
    mainmenu:
    LCDOUT $FE,$80,"Setup Menu"
    lcdout $FE, $C0, "Select Option"
    IF Option = 1 THEN lcdout $FE, $D4, "Set Time and Date  "
    if option = 2 then lcdout $FE, $D4, "op2 "
    if option = 3 then lcdout $FE, $D4, "op3 "
    if option = 4 then lcdout $FE, $D4, "opt4"
    if option = 5 then lcdout $FE, $D4, "Run                "
    IF PBUTTON THEN Option = option + 1
    if option >5 then option = 1
    Pause 250
    If option = 1 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    'Gosub SetButtonRelease
    'goto  setup
    If option = 2 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    'goto opt2
    If option = 3 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    'goto opt3
    If option = 4 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    'goto opt4
    If option = 5 Then
    If S_butt = 0 Then
    LCDOUT $FE,1
    Goto mainmenu
    Malcolm,
    I'm running your program here on a LAB-XUSB.
    I had to change some things to make it run on it. And I made a program for the PC to just send/receive some data over USB.
    Your program is sending out 127 reports per second when the USB is plugged in.
    I'm not sure if your friends PC app can handle that many reports while updating GUI sliders etc..
    It also fills up the USB buffer before the PC app connects, so when it does connect, it gets hit hard with a whole bunch of reports.
    When I send data to it via USB, it saves the data to EEPROM and continues sending the new data at 127 reports per second.
    So the USB portion is working properly.
    You just need to limit the data going out.
    It should really only send the data by request from the PC, instead of all the time.
    This was all quite evident after adding the USB status LED's from post #3.
    Oct 2009
    Darrel,
    thanks for taking the time out to test the code and report your findings.
    I assume that ideally the PC program should send a request to the PIC, which then responds and sends the report, rather than the PIC constantly sending out reports when connected ?
    I'll drop the guy a mail to see if he can come up with a revised application.
    Your contribution is very much appreciated
    Malcolm
    Dec 2010
    A simple interim step might be sending only 1 report per second or even less. There'll be lots of work to get a query/response protocol going and a simple slow down might meet your needs for this one-off project, or at least let you work other areas of the code while you're waiting for PC side changes.
    Oct 2009
    Hi Charlie,
    Yes I have other parts of the code to develop, and whilst it would be a nice function to have, I can live without it if I must.
    To prove it wasn't a duff chip or hardware issue with the USB port on the EasyPic5 board I downloaded the USB Demo example (Mr E's) and stuck a 4mhz resonator in the board - it ran fine and I could toggle the LEDS on portB from the PC application. I then swapped the resonator for a 20 mhz xtal and set the fuses in the programmer accordingly and tested again - it ran sweetly. So the issue is with the code, and I have no reason to doubt DT's explanation.
    Thanks for the comments
    Malcolm
    Oct 2009
    @Darrel,
    Hi, need some advice regarding the way the HID260 USB routine works.
    I commented out the send section in my main code thus:
     ;   if TX_READY = 1 and plugged = 1 then gosub SendUSB
    So this way I can check the sending of data from the PC to PIC. As the software is written to read the EEPROM data from the PIC first, the application displayed garbage values in the sliders which was as expected. Opening up the port monitor I got one TX report for each time I clicked on the update button, and whilst I couldn't see what values I was sending to the PIC, the LCD appeared to respond and display the change of values.
    I removed the comment from that line and again the PIC was spewing report after report as you found. I therefore added the line
    SendData:
            USBOut 1, USBTXBuffer, USBBufferCount , SendData  ' if bus available, transmit data
            plugged = 0
    The theory being that once it's sent that first report the software would then behave as if the USB lead had been removed - there was no change when the USB port was monitored. So I tried the following
            TX_READY = 0
    Again, my logic thinking that once the report had been sent and the TX_ready state set to "not ready" it would stop transmission - but again no change. It's as if something else is over-riding the values used, which originate in the included HID260 file. The code I'm using doesn't have any other calls or conditions connected with the USB, just those IF / THEN statements to check the status of ready and plugged, and then the send and receive routines. Can you advise where or why over-riding these variables have no effects.
    Cheers
    Malcolm
  1. USB Electrical Layout?
    By wdmagic in forum mel PIC BASIC Pro
    Last Post: - 11th March 2013, 12:04
  2. PIC USB in and USB Out
    By koossa in forum General
    Last Post: - 9th February 2013, 09:00
  3. 18F4550 issue
    Last Post: - 4th February 2013, 06:27
  4. Wake from sleep with USB Interrupt
    By kduck63 in forum mel PIC BASIC Pro
    Last Post: - 13th January 2013, 00:59
  5. Bidirectional Excel Data via USB
    By jmstrat in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2013, 08:04
