Best way to use USART/HSERIN
Results 1 to 18 of 18
    Default Best way to use USART/HSERIN
    I'm working on a project where there will be one PIC as a master controller to adjust LED brightness & motor control. I want to link this master PIC to the motor/LED chips via USART in a chain (all by wire on a PCB - no other components involved) and send the mode/speed changes down using a hard-coded ID; each chip down the line will check the ID and if it matches it's own then it acts on it, else it just passes it down the line.
    My question is this - how best to set up HSERIN in a situation like this? Should I use something like this in a Main loop:
        HserIN [WAIT("OK"),ID]
        IF ID="3" THEN
            gosub updateLEDs
            HserOUT [data]
        goto Main
    Or would it be better to use Darrel's Instant Interrupts with the Rx interrupt?
    This will be my first time using HSERIN/HSEROUT apart from using it for LCD debugging.
    Default Re: Best way to use USART/HSERIN
    Why do you need to daisychain them like [Master Out] -> [Slave In - Slave Out] -> [Slave In - Slave Out] ?
    Why not just wire the output of the master to the inputs of the slaves? That way the delay between the master and all the slaves will be equal and there will be less overhead in each of the slaves.
    Also, your code seems to read the ID but then it doesn't read the actual data.
    I'd probably send equally sized packets each time, perhaps something like sync, ID, 8 bytes of data, checksum. The slave then waits for the sync, grabs x number of bytes into an array, evaluates the checksum and if OK checks the ID. If ID matches it acts on the data otherwise it does nothing.
    Using interrupts or not highly depends on what else your program needs to do. If it just needs to sit there and wait for serial data, act on that data and then go back to waiting then you should be fine without using interrupts. But if your program needs to do other things and receive the serial data in the background then you probably need to use interrupts - and DT-Ints is a great way to do it.
    Thanks very much, Henrik. I didn't put the whole code in but what you suggest is what I was thinking.
    I didn't think I could hook up the Tx on the master controller to all the Rx pins on the other PICs, but that makes life a lot easier so I'll give it a go.
    I've been using the PIC16F88 chip which has the 7 sequential pins I need for the code seen in this post. The problem is those 7 pins (PORTB.1-7) include the Rx pin, and I can't seem to find another chip which has 7 sequential pins where the USART Rx pin is somewhere else.
    Should I use SERIN instead to communicate between PICs, or is there a PIC which has 7 sequential pin outputs (none of which are the USART Rx pin)?
    Spending a little more time on the Microchip selector site, I think PIC16F687 might do the trick - 20 pin DIP, 18 I/O pins with Rx on RB5 and RC0-7 available.
    Coming back to this thread after recovering from some encoder/code porting issues from last week, I'm still trying to figure out the best way to send/receive data from 1 Master chip to 3-4 slaves via USART. I've read over many threads here regarding HSEROUT/HSERIN and the permutations & combinations leave me confused.
    As of last night, I've got a PIC12F1840 sending the following on the Tx pin based on a rotary encoder turn (there's an IOC ISR to determine the direction of turn which sets RotEncDir):
    DEFINE OSC 16                ' Set oscillator 16Mhz
    DEFINE HSER_TXSTA 20h        ; Set transmit status and control register
    DEFINE HSER_BAUD  2400       ; Set baud rate
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_CLROERR 1        ; Clear overrun error upon
                                 ; execution of every HSERIN
                                 ; command
        TOGGLE LED_0
        If ValueDirty = 1 THEN
            ' Send RotEncDir to receiving chip
            '    Chip Id,Itm Id,     <modifier>, "~"
            HSEROUT ["2",   "3", SDEC RotEncDir, TxEndChar]  ' use 'SDEC' if RotEncDir can be -1 for CCW
            ValueDirty = 0               ' Clear the flag
            #IFDEF USE_LCD_FOR_DEBUG
                HSEROUT [LCD_INST, LCD_CLR]
                pause 5
            #ENDIF
        GOTO Main
    The output on my LCD shows this for a CW turn:
    231~
    and this for CCW (RotEncDir actually gets set to 0 but I change it to -1 as on the slave I want to just add this value:
    23-1~
    The first number represents the slave chip which is the intended target of the serial data (I'll have 2-3 slaves in this project). The second number represents what to change on that chip with the rotary encoder info. The next part is either '1' for CW or '-1' for CCW (I could go back to using '0' for CCW if that makes the overall serial data easier to interpret on the slaves).
    • Should I have a sync character at the start of the serial data so that on the slave I can determine if new serial data is sent before processing the first message (or there's an error)?
    • Should I convert the HSEROUT line to multiple lines?
    For the slaves, I've decided I need to use a Rx interrupt as I have other code running in the Main loop.
                                 ; command
    ' ASM Interrupt Definitions
    INT_LIST  macro    ; IntSource,           Label,  Type, ResetFlag?
            INT_Handler     RX_INT,        _UsartRx,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    ' Enable interrupt
    @ INT_ENABLE   RX_INT      ; USART Rx interrupt
    • Do I need to make the RX_INT a low priority interrupt, or is that only important if there are other time-sensitive interrupts (I am using SPWM_INT.bas for one slave)?
    • As Henrik suggests above, should I make the serial data entirely consistent in terms of number of bytes to make the parsing here easier? If that's true, then I probably need to revert to using '0' for CCW rotary encoder changes.
    • The code below is from DT on another thread but I can't see how the whole serial data (e.g. "231~" for slave chip #2 to increment item #3 by 1) will be pieced together.
    • Does the ISR get 1 byte every time? i.e. the first time it goes into the above ISR, 'SerialData' will be "2" and then the next iteration will have "3"?
    • Should the ISR have the ResetFlag set or not? I've seen both.
    '*********** 'ISR for RX_INT interrupt *************************************
    Getbytes:
        HSERIN [Serialdata]                    ' Get the serial data
        IF Serialdata = SyncByte THEN          ' if it's a Sync byte,
            IF Sync THEN ERROR = 1            '  last command was corrupted
            Sync = 1                          '  indicate Sync was rcvd
            ForMe = 0                          '  ID has not been rcvd
            IF Sync THEN
                IF !ForME THEN                ' if we haven't rcvd the ID
                    IF Serialdata = ID THEN    '  and this byte matches the ID
                        ForMe = 1              '    indicate ID rcvd
                        Sync = 0              ' Not my packet
                        ForMe = 0              '  reset receive state
                    ENDIF                      '  and wait for next Sync
                    CmdBuf = serialdata        ' store the command
                    IF CmdRcvd THEN LATE = 1  '  last command not finished
                    CmdRcvd = 1                '  indicate a command was rcvd
                    Sync = 0                  '  reset receive state
                    ForMe = 0
    @ INT_RETURN
    All slaves Rx pin will be connected to the master's Tx pin so each slave needs to determine if the serial data is for them or not (which the above code does).
    I've modified Darrel's sample code from this thread (switching to use TMR1 - I couldn't get TMR0 to work) and hooked up my LabX1 board with a PIC16F877A chip jumpered to 4Mhz. It would appear to work except for when the SYNC character appears twice and depending on where it yields a different result.
                'Based on Hserin with Darrel Taylor's Instant Interrupts
    '    Program to echo incoming serial data.
    '  RX SYNC byte, if good: ChipID byte, if good: COMMAND, if good: ADJUSTMENT
    '   MPASM, LabX-1 , PBP2.47, Using PIC 16F877A @ 4mHz, 9600 Baud
    '   Using Hardware USART and MAX232 to MCS Serial Communicator on PC
    ' >>>>>>>>>>>>>>>>>    Slave IC ID: 1    <<<<<<<<<<<<<<<<<<<<<<<
    ChipID          CON "1"
    DEFINE HSER_RCSTA 90h ' enable serial port,
    DEFINE HSER_TXSTA 24h ' enable transmit,
    DEFINE HSER_BAUD 9600 ' set baudrate to 9600
    DEFINE HSER_CLOERR  1 ' automatic clear overrun error
    TRISD  = %00000000    ' D to outputs for the LEDs
    TRISC  = %10000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
    ADCON1 = %00001111    ' Set up ADCON1 register no matter what yr doing!!!
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    ;-- Place a copy of these variables in your Main program -------------------
    ;--   The compiler will tell you which lines to un-comment                --
    ;--   Do Not un-comment these lines                                       --
    ;wsave   VAR BYTE    $20     SYSTEM      ' location for W if in bank0
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
        '   Variable definition
    led0       var     PORTD.0
    led1       var     PORTD.1
    led2       var     PORTD.2
    led7       var     PORTD.7
    ERROR_LED  VAR led7            ' rename the LED's
    LATE_LED   VAR led2
    HEART_LED  VAR led0
    LEDonDELAY CON 4
    TxEndChar   CON "~"
    SyncByte    CON "S"
    CmdBuf      VAR BYTE
    AdjBuf      VAR BYTE
    SerialData  VAR BYTE
    ERRORtime   VAR BYTE
    LATEtime    VAR BYTE
    HEARTtime   VAR BYTE
    state       VAR BYTE
      Sync      VAR state.0      ' sync byte received
      ForMe     VAR state.1      ' packet is for this device
      CmdRcvd   VAR state.2      ' command has been received
      AdjRcvd   VAR state.3      ' adjustment factor has been received
      ERROR     VAR state.4      ' sync received out of order
      LATE      VAR state.5      ' command received before last one was processed
    state = 0                    ' Initialize default value
            INT_Handler   TMR1_INT,      ReloadTMR1,   ASM,  no       ; MUST be first
            INT_Handler   TMR1_INT,      _T1handler,   PBP,  yes
            INT_Handler     RX_INT,        _GetBytes,  PBP,  no
    ;--- Change these to match the desired interrupt frequency -------------------
    ;--- See http://DarrelTaylor.com/DT_INTS-14/TimerTemplate.html for more Info.
    @Freq       = 10                  ; Frequency of Interrupts in Hz
    @Prescaler  = 2                   ; Timers Prescaler setting
    T1CON = $10                       ; $30 = Prescaler 1:8, TMR1 OFF
    ; $00=1:1, $10=1:2, $20=1:4, $30=1:8 --  Must match @Prescaler value
    ' Enable interrupts
    @ INT_ENABLE  RX_INT        ; enable USART RX_INT interrupts
    @ INT_ENABLE  TMR1_INT      ; enable Timer 1 interrupts
    GOSUB StartTimer            ; Start Timer 1 ('MotorRPM' will be saved on every
                                ; interrupt if dirty
    ;        High HEART_LED    ' Turn on LED connected to PORTD.0
    ;        Pause 500       ' Delay for .5 seconds
    ;        Low HEART_LED         ' Turn off LED connected to PORTD.0
        IF (CmdRcvd AND AdjRcvd) THEN GOSUB ProcessCmdAdj    ' Process any incomming data
        IF ERROR THEN                          ' if there's been an Error
            HIGH ERROR_LED                     '   Turn ON ERROR LED
            ERROR = 0                          '   reset the error flag
            ERRORtime = LEDonDELAY             '   start countdown till LED-OFF
            HSEROUT ["Error",13,10]
        IF LATE THEN                           ' if command took too long
            HIGH LATE_LED                      '   Turn ON LATE LED
            LATE = 0                           '   reset the LATE flag
            LATEtime = LEDonDELAY              '   start countdown till LED-OFF
            HSEROUT ["Late",13,10]
    GOTO Main
    '*********** Process received command **************************************
    ProcessCmdAdj:
        hserout ["Cmd: ",CmdBuf, _ ' send ChipID, Command, Adjustment and CR/LF
                 " [",DEC CmdBuf,"]",", Adj:",AdjBuf,_
                 " [",DEC AdjBuf,"]",13,10]
    ;    hserout ["Cmd: ",CmdBuf, " [", _
    ;            DEC CmdBuf,"]",13,10]
        CmdRcvd = 0                            ' indicate CMD & ADJ has been processed
        AdjRcvd = 0
    ' [TMR1_INT - interrupt handler]
    T1handler:
        IF ERRORtime > 0 THEN                  ' if the Error LED is ON
            ERRORtime = ERRORtime - 1          '   decrement the count
            IF ERRORtime = 0 THEN              '   when it reaches 0
                LOW ERROR_LED                  '   turn the Error LED OFF
        IF LATEtime > 0 THEN                   ' if the LATE LED is ON
            LATEtime = LATEtime - 1            '   decrement the count
            IF LATEtime = 0 THEN               '   when it reaches 0
                LOW LATE_LED                   '   turn the LATE LED OFF
        HEARTtime = HEARTtime + 1              ' Toggle heartbeat ~.5sec
        IF HEARTtime = 7 THEN
            HEARTtime = 0
            TOGGLE HEART_LED
    @ INT_RETURN
    ' [RX_INT - interrupt handler]
    GetBytes:
    ' Henrik's suggestion (http://www.picbasic.co.uk/forum/showthread.php?t=17685)
    ' I'd probably send equally sized packets each time, perhaps something like sync,
    ' ID, 8 bytes of data, checksum. The slave then waits for the sync, grabs x
    ' number of bytes into an array, evaluates the checksum and if OK checks the ID.
    ' If ID matches it acts on the data otherwise it does nothing.
    ' Darrel Taylor's code (http://www.picbasic.co.uk/forum/showthread.php?t=9932&p=65066#post65066)
            IF Sync THEN
                    IF Serialdata = ChipID THEN'   and this byte matches the ID
                ELSEIF !CmdRcvd THEN
                    ;Sync = 0                   '   reset receive state
                    ;ForMe = 0
                    AdjBuf = SerialData        ' store the command
                    IF AdjRcvd THEN LATE = 1   '   last adjustment not finished
                    AdjRcvd = 1                '   indicate an adjustment was rcvd
                    ForMe = 0
    @ INT_RETURN
    ;---[TMR1 reload - interrupt handler]-----------------------------------------
    ASM                               ; Calculate Timer Reload Constant
    ReloadInst  = 8                   ; # of Intructions used to reload timer
      if ((Prescaler == 1)||(Prescaler == 2)||(Prescaler == 4)||(Prescaler == 8))
    MaxCount    = 65536 + (ReloadInst / Prescaler)
    TimerReload = MaxCount - (OSC*1000000/4/Prescaler/Freq)
        if ((TimerReload < 0) || (TimerReload > (65535-ReloadInst)))
            error Invalid Timer Values - check "OSC", "Freq" and "Prescaler"
          error Invalid Prescaler
    @Timer1 = TMR1L                   ; map timer registers to a word variable
    Timer1       VAR WORD EXT
    TimerReload  CON EXT              ; Get the External Constant
    TMR1ON       VAR T1CON.0          ; Alias the Timers ON/OFF bit
    ;---Reload Timer1------
    ReloadTMR1
        MOVE?CT  0, T1CON, TMR1ON     ;  1     stop timer
        MOVLW    LOW(TimerReload)     ;  1     Add TimerReload to the
        ADDWF    TMR1L,F              ;  1     value in Timer1
        BTFSC    STATUS,C             ;  1/2
        INCF     TMR1H,F              ;  1
        MOVLW    HIGH(TimerReload)    ;  1
        ADDWF    TMR1H,F              ;  1
        MOVE?CT  1, T1CON, TMR1ON     ;  1     start timer
      INT_RETURN
    ;---Start/Stop controls -----
    StartTimer:
        Timer1  = TimerReload         ; Load Timer
        TMR1ON = 1                    ; start timer
    StopTimer:
        TMR1ON = 0                    ; stop timer
    I need to capture a 3rd byte (the adjustment to the command feature on the indicated chip) but something's not right - I get strange text in the receive window of the MCS serial window.
    Serial window config:
    Proper sequence yields correct result:
    Correct error msg:
    Weird error msg:
    Weird error msg 2:
    On a side note, any idea why some of the LEDs in the bargraph light up when they're not supposed to? Seems like every time I plug in the Lab X1, different ones light up.
    The 2 LEDs which are on when they shouldn't be are still perplexing me, but this code works now if anyone's interested:
    ' Based on Hserin with Darrel Taylor's Instant Interrupts
    '  MPASM, LabX-1 , PBP3, Using PIC 16F877A @ 4mHz, 9600 Baud,
    '  USART and MAX232 to MCS Serial Communicator on PC
    ThisChipID CON "1"
            INT_Handler     RX_INT,        _GetBytes,  PBP,  yes
    led0       var     PORTD.0
    led1       var     PORTD.1
    led2       var     PORTD.2
    led7       var     PORTD.7
    LATE_LED   VAR led2
    HEART_LED  VAR led0
    LEDonDELAY CON 4
    TxEndChar   CON "~"
    SyncByte    CON "S"
    SerialData  VAR BYTE
    CmdVal      VAR BYTE
    AdjVal      VAR BYTE
    ERRORtime   VAR BYTE
    LATEtime    VAR BYTE
    HEARTtime   VAR BYTE
    state         VAR BYTE
      SyncRcvd    VAR state.0      ' sync byte received
      MsgRcvd     VAR state.4      ' compelte message received
      ERROR       VAR state.5      ' sync received out of order
      LATE        VAR state.6      ' command received before last one was processed
      SyncIndx    VAR state.7      ' index # of incoming byte
    state      = 0                 ' Initialize default values
    cmdVal     = 0
    AdjVal     = 0
    serialdata = 0                 ' message sample: "S3B1~"
    ' Enable interrupts
        IF MsgRcvd THEN GOSUB ProcessCmdAdj    ' Process incomming data
            HSEROUT ["SyncRcvd: ", DEC SyncRcvd,", SyncIndx: ",DEC SyncIndx, _
                    ", ForMe: ", DEC ForMe,", CmdRcvd: ",DEC CmdRcvd, _
                    ", AdjRcvd: ",DEC AdjRcvd,", Cmd: ",CmdVal, ", Adj: ",DEC AdjVal,13,10]
    GOTO Main
    ProcessCmdAdj:
        HSEROUT ["Cmd: ", CmdVal, _ ' send ThisChipID, Command, Adjustment and CR/LF
                 ", Adj: ",AdjVal,_
                 " [",DEC AdjVal,"]",13,10]
        state      = 0               ' indicate CMD & ADJ has been processed
        cmdVal     = 0
        AdjVal     = 0
    T1handler:
            HEARTtime = 0
            TOGGLE HEART_LED
    @ INT_RETURN
    GetBytes:
        HSERIN [Serialdata]                    ' Get the serial data (guaranteed here to have at
            IF SyncRcvd THEN                   ' if it's a Sync byte,
                state = 0                      '   last command was corrupted; reset 'state'
                ERROR = 1                      '   and indicate error
            SyncRcvd = 1                       '   indicate Sync was rcvd
            IF SyncRcvd THEN
                IF !ForMe THEN                 ' if we haven't rcvd the ID
                    IF Serialdata = ThisChipID THEN 'and this byte matches the ID
                        state = 0               '   and wait for next Sync
                    CmdVal = SerialData
                    CmdRcvd = 1
                ELSEIF !AdjRcvd THEN
                    AdjVal = SerialData
                    AdjRcvd = 1
                ELSEIF !MsgRcvd THEN
                    If SerialData = TxEndChar THEN
                        MsgRcvd = 1
    @ INT_RETURN
    Timer1       VAR WORD EXT
    ReloadTMR1
        INCF     TMR1H,F              ;  1
        ADDWF    TMR1H,F              ;  1
      INT_RETURN
    StartTimer:
    StopTimer:
    Any suggestions for improvement gratefully appreciated.
    Did you set the pull-up/down jumper for the Lab X1 LEDs?
    I remember I had to set "something".
    No, I didn't Robert. Do I need to do that for all of them?
    Check the Lab X1 schematic, I'm pretty sure there was a jumper for this. It handled all the LEDs at once.
    Is this what you're referring to Robert?
    LED Bargraph
    8 programmable LEDs connected to PORTD and 2 power LEDs are provided by
    the LED bargraph. Resistor pack RP4 provides the current limit series
    resistors for the LEDs. The LED bargraph may be inserted in the socket so
    that the LEDs are lit when the PICmicro MCU pin is in either its high or low
    state.
    To make the LEDs light up when a PICmicro MCU pin is high, insert the LED
    bargraph into the socket with pin 1 toward the edge of the board (this will
    also line it up with pin 1 on the socket and is the default placement).
    Jumper JP2 must have pins 2 and 3 connected (jumper on the top 2 JP2 pins).
    When the LAB-X1 is powered up, the leftmost LED will light up to show that
    power is on. To make an LED light up, set the appropriate PORTD pin to
    output high.
    To make the LEDs light up when a PICmicro MCU pin is low, insert the LED
    bargraph into the socket with pin 1 toward the center of the board. Jumper
    JP2 must have pins 1 and 2 connected (jumper on the bottom 2 JP2 pins). When
    the LAB-X1 is powered up, the second to the leftmost LED will light up to
    show that power is on. To make an LED light up, set the appropriate PORTD
    pin to output low.
    The LED bargraph shares PORTD with the LCD module data lines. If the
    program is not using the LCD module, it can effectively be ignored. If the
    LCD module is also being used, it may leave the LEDs in a different state
    than it found them in. If the LCD is operating on a 4-bit data bus, only the
    top 4 LEDs, 4 - 8, will be affected. If the LCD is using an 8-bit data bus,
    all 8 LEDs will be affected. The proper LED state will need to be reset
    after each LCD access.
    See BLINKX.BAS for a programming example.
    I'll check the jumpers tonight, but it seems like it's an all-or-nothing thing - on my board, the leftmost LED lights up when powered on and the ERROR LED from my code does blink, but a few of the other ones are always on.
    Yup, JP2, that's the one.
    Looking at the board with the power jack on the left and the 16F8777A on the bottom, the JP2 jumper has the top two pins tied together. The LED bargraph has the writing towards me. That would seem to be the pick-pin-HIGH-LED-On scenario described above, so I don't get why the LEDs which aren't referenced are on. <Sigh>
    Dumb question, did you assign initial values to the pins, ADC, CONFIGs, etc?
    Not a dumb question, Robert - I did not. Think I should add 'PORTD =0'?
    I'd use the variables.
    Why the renaming?
    led1 var PORTD.1
    led2 var PORTD.2
    led7 var PORTD.7
    LATE_LED VAR led2t
    HEART_LED VAR led0
    Problem solved:
    ERROR_LED  VAR PORTD.1            ' rename the LED's
    LATE_LED   VAR PORTD.2
    HEART_LED  VAR PORTD.0
    PORTD = 0
  1. USART to PC
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 15th October 2008, 01:09
  2. Usart
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2008, 00:41
  3. Sharing a USART
    By Ron Marcus in forum Serial
    Last Post: - 7th September 2005, 15:48
  4. 9 bit addressable USART
    By barkerben in forum General
    Last Post: - 4th January 2005, 23:57
