LED 'Dot' Bargraph Issues - Newbie Code!
Results 1 to 12 of 12
    Default Re: LED 'Dot' Bargraph Issues - Newbie Code!
    When you find yourself writing the same section of code over and over with only changes to the values ....
    It usually means you are doing it the hardest and least efficient way.
    Instead of a bunch of IF/THEN's, use a little math, and a couple FOR/NEXT loops.
    'Initialize variables PIC16F88
        __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
        __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    OSCCON=$60               'Set Internal Oscillator to 4MHz
    DEFINE ADC_BITS 10       ' 10 bit A/D Conversion
    DEFINE ADC_CLOCK 3       ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50   ' 50 uS A/D sample time
    ANSEL  = %00000001       ' Set pin (AN0) to analog input, the rest to digital
    ADCON1.7 = 1             ' Right Justify A/D results
    LED      VAR BYTE
    Row      VAR BYTE
    Col      VAR BYTE
    Idx      VAR BYTE
    Row_Pin  VAR BYTE
    Col_Pin  VAR BYTE
    adval    VAR WORD
    LEDcount CON 35
    Spaces   CON LEDcount + 1
    Margin   CON 1023 / Spaces
        ADCIN 0, adval
        LED = adval * LEDcount                  ; Determine which LED to light
        LED = DIV32 (1023 - Margin) - 1
        Row = -1                                ; Turn OFF all dots
        Col = -1                                ; to prevent ghosting
        GOSUB ShowDot
        Row = LED // 7                          ; convert LED to Row/Column
        Col = LED / 7
        GOSUB ShowDot
    GOTO Main
    ShowDot:
        FOR Idx = 0 To 6                        ; Set Row's
            LOOKUP Idx,[1,2,3,4,5,6,7],Row_Pin
            IF Idx = Row THEN
                HIGH Row_Pin
                LOW Row_Pin
        NEXT Idx
        FOR Idx = 0 TO 4                        ; Set Column's
            LOOKUP Idx,[9,10,11,12,0],Col_Pin
            IF Idx = Col THEN
                LOW Col_Pin
                HIGH Col_Pin
        NEXT Idx
    And, for the two lights on at a time ... you may want to add this ...
    http://www.picbasic.co.uk/forum/cont...ith-hysteresis
    Wow, I cannot thank you enough Darrel! What elegant and efficient code! The difference between a newbie and a master. :-)
    I will study the code and get familiar with LOOKUP (never used that fuction before) as well as understanding how it all works.
    For example, setting Row = -1, I never knew you could set to a minus value. Don't really know what that is.
    Brilliant code. Thanks a ton!!
    Hi Darrel,
    I tried the averaging routine but could not get it to work. In the code is has:
    GOTO OverAverage
    ' -=-=-=-=-=-=  Average Analog values -=-=-=-=-=-=-=-=-=-=
    however, there is no OverAverage routine. Also, I replaced the word "Value" with "adval", but that did nothing.
    Sorry, I am just not seeing this.
    Thanks!
    The OverAverage label is at the end of the code in that thread.
    Maybe you didn't copy enough of it.
    Hi Darrel,
    Here is the entire code on that link:
    '*  Name    : Average_Hyst.pbp                                  *
    '*  Author  : Darrel Taylor                                     *
    '*  Date    : 7/19/2005                                         *
    '*  Version : 3.0                                               *
    '*  Notes   : Modified to use Hysteresis                        *
    '*          : Use as an INCLUDE file                            *
    ' This routine will keep a "Running Average" of 10-bit Analog Values
    ' Instead of adding a bunch of values together and then dividing by the number
    ' of samples, it averages each sample into the final result immediately.
    ' This eliminates the need for 32 bit math.
    ' To allow it to "Catch up" to large changes, set the FAspread to an
    ' acceptable range.
    ' Simply place the new number in VALUE and GoSub Average
    ' The Average (with Hysterisis) will be returned into the same variable VALUE
    '---- [ User Options ] ---------------------------------------------------------
    HystLevel   CON  7      ' 7 = .7 of the Least Significant Digit
                            '    Valid HystLevel is from 6 to 13
    AvgCount    CON  16     ' = Number of samples to average. For best response
                            '    times, keep AvgCount as small as you can
    FAspread    CON  50     ' = Fast Average threshold +/-
                            '  FAspread should be larger than the worst possible
                            '  noise in the A/D conversion.
    AVGchanged  VAR  BIT    ' 1 indicates that the Average Value has changed
                            ' you have to clear this bit after using it
    ADavg       VAR  WORD   ' Stores the current Average
    ADhyst      VAR  WORD   ' Stores the current Value for Hysterisis
    Value       VAR  WORD   ' Input / Output variable to be averaged
    spread      CON  FAspread * 10  ' adjust spread *10 for Hyst.
    GOTO OverAverage
    Average:
        Value = Value * 10                      ' Scale value up for hysterisis
        IF Value = ADavg Then NoChange          ' if they're the same, nothing to do
        IF ABS (Value - ADavg) > spread OR Value < AvgCount Then FastAvg
        IF ABS (Value - ADavg) < AvgCount Then RealClose
        ADavg = ADavg - (ADavg/AvgCount)         ' Subtract 1 samples worth
        ADavg = ADavg + (Value/AvgCount)         ' Add in the new sample portion
        GoTo AVGok
      FastAvg:                                   ' Catch up to the changing value
        ADavg = Value                            ' Set Average to the current value
        GoTo AVGok
      RealClose:                                 ' Reduce the sample size when
        ADavg = ADavg - (ADavg/(AvgCount/4))     ' the average and the sample are
        ADavg = ADavg + (Value/(AvgCount/4))     ' "Real Close"
      AVGok:
        IF ABS (ADavg - ADhyst) > HystLevel then ' If it changed > HystLevel +/-
            ADhyst = ((ADavg + 5) / 10) * 10     ' Round ADavg to get new Value
            AVGchanged = 1                       ' Indicate that Average changed
      NoChange:
        Value = ADhyst / 10                      ' Scale the result down
    OverAverage:
    It may not have been put in there properly. Can you click the link and see what you get?
    From the code, it jumps over the section staring with:
    It does not seem to make sense to me.
    Thanks. :-)
    The label OverAverage is right at the bottom of the code you just posted.
    Usually you include the file somewhere around the top of your program. When the program starts from the beginning it eventually reaches the code which is in the include file. If you don't want it to execute the code at that point you must jump over it and that's exactly what's happening here.
    Then, when you actually WANT to execute the code from within your main routine or whatever you GOSUB Average, that way it will enter the code after the GOTO OverAverage and execute the code until it hits the RETURN which returns the execution to the place it was called from.
    The averaging code is an INCLUDE file.
    Save it to a file called "Average_Hyst.pbp".
    Put the file in the same folder as your project, or the PBP folder.
    Then at the top of the code in post #4, add this line.
    INCLUDE "Average_Hyst.pbp"
    The GOTO OverAverage line just jumps over the code, making sure execution doesn't "Fall Into" the subroutine without being called by a GOSUB.
    Then, change these lines to use the "Value" variable, instead of adval.
        ADCIN 0, Value
        GOSUB Average
        LED = Value * LEDcount                  ; Determine which LED to light
    Edit: Whoops, sorry Henrik.
    Took me an hour to get his darn post to go through.
    The forums going up and down like an elevator.
    Ya beat me to it.
    OK, that is what I thought but could not get my head around it. Too many late nights!
    Thanks, I will give it a shot and see if it works.
    I sure learn a great deal on these forums. I have to start using the LOOKUP command more...very useful!!
    Alrighty, I just implemented the code and for the most part it works real well! Thanks!
    I still get flickering on a single LED now at some in-between value.
    Not sure it this can be gotten rid of and have a nice solid LED. I have these values in:
    HystLevel CON 13 ' 7 = .7 of the Least Significant Digit
    AvgCount CON 32 ' = Number of samples to average. For best response
    FAspread CON 100 ' = Fast Average threshold +/-
  1. Replies: 3
    Last Post: - 24th March 2015, 11:51
  2. Replies: 19
    Last Post: - 26th April 2012, 20:23
  3. Newbie needs example RC code
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 18th March 2010, 02:10
  4. Microchip Code Issues
    By Destovi in forum General
    Last Post: - 20th March 2008, 13:32
  5. BaseBall pitching Code sample - NewBie
    By foxstar in forum Code Examples
    Last Post: - 8th May 2007, 19:29
