LED 'Dot' Bargraph Issues - Newbie Code!
Results 1 to 12 of 12
Threaded View
  1. #4
    Default Re: LED 'Dot' Bargraph Issues - Newbie Code!
    When you find yourself writing the same section of code over and over with only changes to the values ....
    It usually means you are doing it the hardest and least efficient way.
    Instead of a bunch of IF/THEN's, use a little math, and a couple FOR/NEXT loops.
    'Initialize variables PIC16F88
        __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
        __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    OSCCON=$60               'Set Internal Oscillator to 4MHz
    DEFINE ADC_BITS 10       ' 10 bit A/D Conversion
    DEFINE ADC_CLOCK 3       ' Set clock source (rc = 3)
    DEFINE ADC_SAMPLEUS 50   ' 50 uS A/D sample time
    ANSEL  = %00000001       ' Set pin (AN0) to analog input, the rest to digital
    ADCON1.7 = 1             ' Right Justify A/D results
    LED      VAR BYTE
    Row      VAR BYTE
    Col      VAR BYTE
    Idx      VAR BYTE
    Row_Pin  VAR BYTE
    Col_Pin  VAR BYTE
    adval    VAR WORD
    LEDcount CON 35
    Spaces   CON LEDcount + 1
    Margin   CON 1023 / Spaces
        ADCIN 0, adval
        LED = adval * LEDcount                  ; Determine which LED to light
        LED = DIV32 (1023 - Margin) - 1
        Row = -1                                ; Turn OFF all dots
        Col = -1                                ; to prevent ghosting
        GOSUB ShowDot
        Row = LED // 7                          ; convert LED to Row/Column
        Col = LED / 7
        GOSUB ShowDot
    GOTO Main
    ShowDot:
        FOR Idx = 0 To 6                        ; Set Row's
            LOOKUP Idx,[1,2,3,4,5,6,7],Row_Pin
            IF Idx = Row THEN
                HIGH Row_Pin
                LOW Row_Pin
        NEXT Idx
        FOR Idx = 0 TO 4                        ; Set Column's
            LOOKUP Idx,[9,10,11,12,0],Col_Pin
            IF Idx = Col THEN
                LOW Col_Pin
                HIGH Col_Pin
        NEXT Idx
    And, for the two lights on at a time ... you may want to add this ...
    http://www.picbasic.co.uk/forum/cont...ith-hysteresis
  1. Replies: 3
    Last Post: - 24th March 2015, 12:51
  2. Replies: 19
    Last Post: - 26th April 2012, 21:23
  3. Newbie needs example RC code
    By PickyBiker in forum mel PIC BASIC Pro
    Last Post: - 18th March 2010, 03:10
  4. Microchip Code Issues
    By Destovi in forum General
    Last Post: - 20th March 2008, 14:32
  5. BaseBall pitching Code sample - NewBie
    By foxstar in forum Code Examples
    Last Post: - 8th May 2007, 20:29
