need code for ir on/off switch 12f629
Results 1 to 11 of 11
    Oct 2009
    Utah, USA
    Default Re: need code for ir on/off switch 12f629
    There is a pretty good APP NOTE over on the Parallax Basic Stamp web site.
    I tried to attach the .pdf file here but it fails.
    If you google "parallax remote ir" you will get a couple of hits on IR protocol and implimenting IR comms using BASIC.
    PBP is quite similar to the BASIC used in the Basic Stamp microcontroller. So it should not be too dificult to apply what is contained in those app notes to PBP.
    Certainly if the Basic Stamp can do it then most any PIC can do it better
    Dwight
    Oct 2011
    Thank you mr.heckler ...it is realy good site and i got some good ideas from it ...and i traid to write code .. but the main proplem is that thair codecs depend on known ir protocol like sony or rc5 but my need is treating with unknown ir protocol (from any remot control) .................realy i spend 10 hour in one set on net and i failed ....thair are many projects about ir dimmer circuit depend on the same idea but the programmers execuse about orginal code and offer just hex file
    Download this file. It explains all these IR stuff you need.
    Oct 2011
    It is still not solved.....
  1. Toggle switch (latching switch) state
    By craigwb in forum General
    Last Post: - 6th November 2011, 15:18
  2. Switch sensor vs. switch PIC pin
    By fratello in forum Schematics
    Last Post: - 4th August 2011, 12:17
  3. Replies: 6
    Last Post: - 9th January 2011, 16:26
  4. Replies: 6
    Last Post: - 20th September 2008, 13:28
  5. Rotary Hex Dip Switch Code???
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 14:30
