Help with cleaning of AC please
Results 1 to 10 of 10
    Sep 2010
    USA NY
    Default Re: Help with cleaning of AC please
    Hi
    The circuit on page 22 fig. 7 assumes that you feed it with a smoothed DC filtered supply. The circuit on page 26 fig.18 shows a negative output supply using a positive regulator but shows the correct components, i.e. a bridge rectifier, reservoir cap. and output decoupling cap for stability. The circuit on page 22 fig. 9 maybe the one that is confusing you. It's confusing me too! A 470 microfarad capacitor straight from the 120 volt AC mains onto the regulator. That really would reduce the ripple, ( when the breaker or fuse went BANG!).
    Sep 2009
    That isn't 120Vac, it is 120Hz... And that is test circuit for Ripple Rejection test.
    Sep 2010
    USA NY
    Hi
    Thank you for pointing out the error. Although in defense of my mistake, the circuit does come under the heading of "Typical Applications' and is scarce on detail. But..... it does read 120Hz which I miss-read as 120volts, the US domestic outlet voltage, nominally! Sorry.
  1. Cleaning up code
    Last Post: - 2nd December 2009, 08:14
  2. Re: Pcb cleaning
    By Steve_88 in forum Off Topic
    Last Post: - 10th March 2008, 09:05
